Author Topic: E6.5 - 65% custom keyboard (GROUP BUY FINISHED )  (Read 326506 times)
Offline Rob27shred
  • Insane in the Membrane! 👻
Re: E6.5 - 65% custom keyboard (GROUP BUY FINISHED )
« Reply #800 on: Tue, 17 March 2020, 12:13:25 »
http://bit.ly/33rWi8w PCB release
Do these PCBs also include the the side RGB lights the originals had?
Good question! I'd imagine they would, but we'll have to wait for E's answer to be sure. Not a deal breaker for me either way as i very rarely use the LEDs on my E6.5.
Offline excluisve
  • Making & Thinking.
« Reply #801 on: Tue, 17 March 2020, 12:24:10 »
Same like OG one
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #802 on: Sun, 29 March 2020, 15:17:19 »
I am experiencing two issues. First is that the keyboard doesn't show up as an HID Device in QMK Toolbox. Second is when I hit the reset or bootloader mode button on the bottom of the PCB nothing happens.
Any ideas what might be needed to fix these issues?
Offline Rob27shred
« Reply #803 on: Fri, 03 April 2020, 22:49:52 »
Just a heads up to anyone who bought one of the black replacement PCBs, they do not use the same hex files as the original yellow one & the new ones are not VIA compatible. It will show up in VIA & let you map the keys, but the PCB will not output keystrokes after that. Here are links to the proper json & hex file,
json - https://cdn.discordapp.com/attachments/555079607250976798/694199663347236956/black6.5.json
hex file - https://cdn.discordapp.com/attachments/555079607250976798/694199659501060237/black6.5.hex
Also if you want to upload the json to remap it, you'll have to do it on https://kbfirmware.com/ (talk about a blast from the past! LOL) because that are not compatible with QMK configurator. Anyways, hopes this help someone avoid the stress I went through tonight thinking I could use the same jsons & hex files I made for the original yellow PCB.
Offline Rob27shred
« Reply #804 on: Fri, 03 April 2020, 22:57:42 »
Do you have to original yellow PCB or the new black one? With the new black new it will not show up as a HID device in QMK toolbox till you reset it. To reset it you have to short the two copper through hole pads directly above where it says reset since there is no reset button on the black PCBs. If it is the original yellow PCB (which does have a reset button if I am remembering correctly) then it may be a dud. In that case I would send Exclusive a DM on Discord or here (Discord has been the easiest place to get a hold of him IME). Anyways GL getting your PCB up & running man!
Offline 8six753o9
« Reply #805 on: Sun, 05 April 2020, 19:33:41 »
I'm working on doing a PR for the Black PCB to QMK and VIA soon.  Almost done.
Offline Rob27shred
« Reply #806 on: Sun, 05 April 2020, 22:36:35 »
Awesome to hear! Please post a link when you get it finished.
Offline PocketAces
« Reply #807 on: Sat, 11 April 2020, 11:16:53 »
Hey, I wanted to hop on here to see if anyone is having the same issue that I am with this board.
I've got an ansi with no blockers. with the winkey. the right side of my spacebar has an  Alt and then a Ctrl key. The default config seems to have that right control key acting as an FN to access the layer with F row keys and other settings, but my right control key does nothing when pressing it with anything in switch hitter to test it.
I made a file where I added media control keys to that first layer as well--again with the right control acting as a momentary turn on for layer 1. I flashed the board with it, and it appeared to be successful as I didn't get any errors, but the right control key still seems to do nothing. Am I doing something wrong? This is my first time using QMK, but I followed the instructions from Mechmerlin's video series.
Thanks for any help and suggestions in advance.
Offline Starius
« Reply #808 on: Sat, 11 April 2020, 17:39:33 »
This might be something simple you overlooked, but I would double check to see that the pins of that switch didn't actually get bent and not making contact on the pcb - that would be a simple cause for those issues you're experiencing.
Offline evilsharky
« Reply #809 on: Mon, 13 April 2020, 13:35:18 »
Looking to buy an e-white version!
Offline BigBabyJesus
« Reply #810 on: Tue, 14 April 2020, 03:45:44 »
Looking to buy the PC one!
Offline dzbro
« Reply #811 on: Fri, 01 May 2020, 14:57:51 »
Anyone know what tool I need to unscrew the back of the board? I just bought one someone on Reddit and I'm stumped..
Offline dzbro
« Reply #813 on: Fri, 01 May 2020, 16:06:51 »
I used the H1.5 from this set https://www.amazon.com/Nanch-Precision-Screwdriver-Smartphone-Electronics/dp/B00QZLV03O?ref_=s9_apbd_orecs_hd_bw_b2Jwu&pf_rd_r=3W74VBAN2AJZYEVG464P&pf_rd_p=6e4d9b8c-4111-590f-8aaf-f17fa8bd5a04&pf_rd_s=merchandised-search-10&pf_rd_t=BROWSE&pf_rd_i=553344:
Hmm, thanks. I'll give that a try. I'm starting to think the screws are stripped.... If they are, know where to get replacements?
Offline nghiahc
« Reply #814 on: Sat, 09 May 2020, 22:26:05 »
Offline Riskymilk
« Reply #815 on: Tue, 15 September 2020, 23:01:14 »
Looking to buy a PC Plate (Full or Half)!
Offline Riskymilk
« Reply #816 on: Mon, 21 September 2020, 18:36:39 »
I found a pc plate! looking for a black pcb now :P
Offline bball2
« Reply #817 on: Sat, 14 November 2020, 15:53:10 »
Does anyone know if there will be another round of PCB's in the future? Or any third party PCB's that's compatible? Mine has been having all sorts of problems since trying to flash to a VIA compatible firmware (key presses are only registering like 50% of the time) randomly across the board =\
Offline ic33hot
« Reply #818 on: Sat, 09 January 2021, 13:13:11 »
Please sell me your wathet blue badge and weight!
