Author Topic: IntelliStation Z Pros  (Read 14037 times)
Offline InSanCen
« Reply #50 on: Sun, 23 May 2010, 18:02:21 »
Quote from: EverythingIBM;185579
The server rooms I've been in were virtually silent: I was shocked not to hear the SCSI drives all grumbling and making noises.
I'd love to see your reaction to the processing areas of any respectable datacentre. I've never worked in a quiet one, and have been in a couple that were bordering on requiring hearing protection. 15K spindles need serious cooling too, although the storage arrays are generally quieter than the processing arrays.
If you lived in then UK there is a renderfarm that is notorious among local network tech's/sysadmins for being painfully loud after prolonged exposure. Your ears ring like you have been to a fairly loud gig when you come out of it. The fact that 190CFM Delta's were specced for the cooling inside the nodes is a large factor, as these are over 60dB individually. 4 per node, 250 nodes (Cooling 4P 3.2Ghz Prescotts based Xeon's IIRC, due to be upgraded to Opteron 6172's shortly).
Currently Using :- IBM M13 1996, Black :
Currently Own :- 1391406 1989 & 1990 : AT Model F 1985 : Boscom 122 (Black) : G80-3000 : G80-1800 (x2) : Wang 724 : G81-8000LPBGB (Card Reader, MY) : Unitek : AT102W : TVS Gold :
Project's :- 122 key 1389620 Wireless ESP32 :
'Pooter :- Xeon E5-2680v4 : Machinist MR9A : 2x16GB DDR4 : Radeon RX6600 : NVME & Spinning rust :
Offline ch_123
« Reply #51 on: Sun, 23 May 2010, 18:04:18 »
If you've ever been in a quiet server room, then you weren't in a server room. Case closed.
Offline EverythingIBM
« Reply #52 on: Sun, 23 May 2010, 18:16:33 »
Quote from: webwit;186139
Webwit is always trying to fit in...
Offline ch_123
« Reply #53 on: Sun, 23 May 2010, 18:17:06 »
Quote from: EverythingIBM;186123
EDIT: and yeah, the task bars should be at the bottom, since the top is reserved for the title. Not at the TOP. Otherwise you'd either have to put the title at the bottom, or end up stacking the title at the top with the task bar at the top... highly inefficient and messy.
Well, the taskbar occupies the same amount of space irrespective of where it's placed. I put it on top out of personal preference arising from Linux use, but it works well either way.
And you must have some pretty crazy OCD if a rounded window edge bothers you. I mean, when I use a computer, I use it do stuff, not stare at the decor...
« Reply #54 on: Sun, 23 May 2010, 18:19:06 »
Quote from: ch_123;186146
The only good interface is the windows 9x one. Case closed.
Offline ch_123
« Reply #55 on: Sun, 23 May 2010, 18:22:49 »
Quote from: EverythingIBM;186148
The only interface I know how to use is the windows 9x one. Case closed.
Fixed that for you. No need to thank me.
Offline J888www
« Reply #56 on: Sun, 23 May 2010, 18:33:22 »
OTT.
 ' I want this, I want that, I want it now ! ' attitude.
Some people have some serious attitude problems in this World.
Often outspoken, please forgive any cause for offense.
Thank you all in GH for reading.
Keyboards & Pointing Devices :-
[/FONT]One Too Many[/COLOR]
Offline ricercar
  • mostly abides
« Reply #57 on: Sun, 23 May 2010, 18:57:14 »
Maybe a case of insanity.
« Reply #58 on: Sun, 23 May 2010, 19:04:39 »
Quote from: ricercar;186167
After awhile you just get tired of flashy graphics (and backgrounds) when it interferes with work. There's a lot of people who like windows classic.
Offline ricercar
  • mostly abides
« Reply #59 on: Sun, 23 May 2010, 19:05:49 »
I use Windows classic on xp, vista, and 7. That doesn't make it a good interface.
Offline ch_123
« Reply #60 on: Sun, 23 May 2010, 19:13:04 »
Quote from: EverythingIBM;186172
Reminds me of a good friend of mine gives out to me whenever she uses my computer because I don't use Ad Block Pro, claiming that she finds ads distract her from what she's doing. I usually retort "Well, I just don't look at the ads I guess..."
Sooner or later I will switch to tiling window managers...
« Reply #61 on: Sun, 23 May 2010, 19:24:11 »
Quote from: ch_123;186175
Well if that person is going on websites plastered with ads, I doubt it's any sort of professional work... so then what's the point? Do you honestly need focus for something like facebook or twitter? No!
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #62 on: Sun, 23 May 2010, 21:37:23 »
Not using Ad Block Plus is a cruel way of punishing oneself.
kishy.ca
« Reply #63 on: Sun, 23 May 2010, 22:10:17 »
Quote from: kishy;186214
I just use IE8 without flash installed. Gets rid of most of the ads from hotmail.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #64 on: Sun, 23 May 2010, 22:25:46 »
Using IE is a cruel way of punishing oneself.
kishy.ca
« Reply #65 on: Sun, 23 May 2010, 22:29:47 »
Quote from: kishy;186231
The only problem I encountered with IE was opening huge pages of text, I mean tomes all on a single HTML page totalling hundreds of MB. Otherwise it's fine.
But I use firefox mostly now, it can handle huge text documents with ease.
Offline ricercar
  • mostly abides
« Reply #66 on: Sun, 23 May 2010, 22:35:54 »
Adblock appears to work on Hulu toolu.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #67 on: Sun, 23 May 2010, 22:41:29 »
Quote from: EverythingIBM;186234
The problems are the ones you can't see.
kishy.ca
Offline ch_123
« Reply #68 on: Mon, 24 May 2010, 06:24:34 »
Quote from: EverythingIBM;186179
Said person doesn't use those sites. Ads are everywhere on the internet. They even used to be here at one point. And then -
Hotmail? I think we done gots ourselves a contradiction.
I see them. Then again, I also see dead people, so I probably shouldn't be considered the average representative sample.
« Last Edit: Mon, 24 May 2010, 06:29:57 by ch_123 »
Offline J888www
« Reply #69 on: Mon, 24 May 2010, 10:21:37 »
I migrated to Firefox from IE, but they are both not comparable to Chrome for speed and stability ATM.
Example:- Play Youtube videos on Firefox and IE and you'll find they both crash, whereas Chrome is stable.
I always liked Firefox especially with the Noia theme Add-On installed, but until Firefox 4.0 is released, I'll be sticking with Chrome.
Offline itlnstln
« Reply #70 on: Mon, 24 May 2010, 10:24:46 »
Chrome is nice.  It's fast and simple, but I think at times it's a little too spartan.  The tweakability is pretty lackluster (cache and history handling, e.g.) and I really miss a dedicated search bar.  That said, other than not looking like a native app, the animations and other graphical details are very nice.
Offline J888www
« Reply #71 on: Mon, 24 May 2010, 10:52:08 »
I like Chrome especially the Browser Synchronization between my Desktops and the Laptop (use one comp and the Bookmarks ecetera are automatically updated on other comps), neat. I will switch back to Firefox when version 4.0 releases, mainly because of its' vast array of Add-Ons.
Silly me have become sentimentally attached to the Blue Shade Background/Cleaner Look (no and Border in Toolbar) options of Noia 2.0 Extreme. Clear sunny sky look. Beautiful.
Curious as to what IE 9 .............
Offline ch_123
« Reply #72 on: Mon, 24 May 2010, 10:58:20 »
Quote from: itlnstln;186361
To me, the latest version of Opera is like Chrome without a lot of the bad points.
