Author Topic: Everyone should go to a Catholic College...  (Read 12517 times)
Offline ch_123
« Reply #50 on: Wed, 19 May 2010, 05:16:04 »
Quote from: ripster;183892
Wow.  That does not look like any controller or case I've ever seen from IBM.  Looks like a 42H/Unicomp main assembly though.  I like the Swiss cheese LED cutouts.
Nope. In the 42H, the controller slots directly into the assembly... That's nothing like IBM ever made, and if IBM made it, why would they bother designing such a completely different case/internals for AT&T?
Offline itlnstln
« Reply #51 on: Wed, 19 May 2010, 07:39:28 »
I still think AT&T may have licensed the technology and built their own.
Offline itlnstln
« Reply #52 on: Wed, 19 May 2010, 07:57:50 »
That, and the AT&T folks seemed to have had a real affinity for IBM stuff back then.  Maybe it was just an attempt to build a better M.  I, for one, like it a lot.  I might keep my eye on eBay for one at some point.
Offline didjamatic
« Reply #53 on: Wed, 19 May 2010, 08:08:39 »
I would really like to know if the resistance is the same on the keys as a Model M or if it's different.
Offline Phaedrus2129
« Reply #54 on: Wed, 19 May 2010, 08:16:28 »
That PCB looks a little like a breadboard. :p
Someone said something about a special jack earlier. Maybe they needed a special controller for whatever machine this was hooked up to?
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline ricercar
  • mostly abides
« Reply #55 on: Wed, 19 May 2010, 11:15:26 »
Quote from: ripster;184069
AT&T ... just Bell South in drag.
Actually there are two baby bells under the covers now. 'Bell South in Drag' was bought by Cingular, which had previously bought Pacific Bell. I'd be SOOOO amused if they also bought Northwestern Bell and Bell Atlantic.
Offline ricercar
  • mostly abides
« Reply #56 on: Wed, 19 May 2010, 13:11:47 »
Used to work in those buildings after they were SGI and before they were Google. Really hard to play ping pong under a metal roof in the rain. Audio cues are pretty much required.
Offline xyzzy
« Reply #57 on: Wed, 19 May 2010, 14:05:21 »
Quote from: dw_junon;78312
AT&T got this patent in '89 for a quieted buckling spring keyswitch mechanism.
Maybe they used that patent after all...
IBM Model F62 (Ellipse's) • PFU HHKB Pro Type S Hybrid • PFU HHKB Pro • Leopold FC660C • IBM Model M SSK 1391472 • IBM Model M SSK UNI04C6 • IBM Model M 1391405 (x4) • Cherry MX 1800 Compact (blue Cherry) • Cherry MX 11900 Touchboard (brown Cherry) • Dell AT102W (black Alps) • Apple Extended Keyboard II (cream Alps) • Acer 6312-TA (black Acer) • Unikey KWD-601 (white Cherry)
Offline JBert
« Reply #58 on: Thu, 20 May 2010, 15:56:40 »
Quote from: ch_123;183278
It's going to be the same. Of course, BS are quite hard to accurately measure so the best thing here is to pop it open and see what's inside.
When measuring, I try to apply some good old-fashioned dithering to make the springs buckle more consistently. The friction in the keycaps would otherwise cause to much variation.
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline MissileMike
« Reply #59 on: Mon, 16 August 2010, 11:17:19 »
Hey guys, I have one of these at&t boards.  This one is pretty dirty and it's missing 3 keycaps.  Sadly, model m keycaps to fin on it, but the color and print are different, so I would have to replace them all.
Mine is a bit different than the OP's, in that the barrels are actually white instead of black.
It is, without a doubt, quieter than any of my other M's, Are there any measurements or photos anyone would like?
BS: 5 Space Savers  ||  9 42H  ||  10 1391401 or similar  ||  1x 1390131  || AT&T 305b  ||  Dell Model M
Cherry: Leopold FC200RC/AB  ||  3 Ducky 1087  ||  PLU ML87 ||  Cherry G80-8113LUVEU-2  browns
Alps: Filco Zero Tenkeyless (fukka)  ||  ABS M1  ||  3x Dell AT101w  ||  Ancer KF-191  ||  6 Vivanco Compact
Misc: NMB RT6855T+  ||  NMB RT101 Space Invader  ||  Dell Quietkey  ||  Ge Fanuc Industrial Metal
Offline MissileMike
« Reply #60 on: Mon, 16 August 2010, 11:49:42 »
Quote from: didjamatic;184076
I measure it at 65g
My Customizer 104 measures 70g
Offline MissileMike
« Reply #61 on: Mon, 16 August 2010, 14:34:40 »
4 images attached, notice the funky retractable legs.
Offline itlnstln
« Reply #62 on: Mon, 16 August 2010, 14:39:00 »
I would love to know the story behind these.
Offline MissileMike
« Reply #63 on: Mon, 16 August 2010, 14:44:00 »
You can also open them up with a regular Philips head screwdriver.
I popped off the right alt key, and the spring went flying into the air, and now I can't find it :( (Was looking to see if they followed through on their patent)
Offline ch_123
« Reply #64 on: Mon, 16 August 2010, 14:47:00 »
Is there a better shot of the label somewhere?
Offline MissileMike
« Reply #65 on: Mon, 16 August 2010, 14:54:26 »
Quote from: ch_123;213178
Here you go, attached.
Btw there is no insert in the springs- it's normal buckling spring.  But definitely quieter.
Offline ch_123
« Reply #66 on: Mon, 16 August 2010, 14:59:48 »
Offline MissileMike
« Reply #67 on: Mon, 16 August 2010, 15:00:20 »
That ebay one is a serial connector.  The one I have is PS2 and works fine in a PC.
Offline ch_123
« Reply #68 on: Mon, 16 August 2010, 15:08:29 »
Only four pins of the serial plug is used. Probably AT/PS/2 with a different connector for vendor lock-in.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #69 on: Mon, 16 August 2010, 15:43:07 »
Quote from: ch_123;213185
Here's a cheap one.
The seller doesn't have to use size 72...
Offline ch_123
« Reply #70 on: Mon, 16 August 2010, 15:55:00 »
FCC IDs always point at the original manufacturer as opposed to the company that OEM'd it, right?
Apparently these things were made by Alcatel-Lucent.
Offline pfink
« Reply #71 on: Mon, 16 August 2010, 16:37:55 »
Quote from: ch_123;213199
The old AT&T Technologies is now part of Alcatel-Lucent.
Offline Necroleachate
« Reply #72 on: Mon, 16 August 2010, 16:59:12 »
Quote from: ripster;213174
Knowing AT&T they probably threatened to sue IBM if they didn't cough up a few thousand Model M internals for them to put in new cases for some ill fated PC.   Still, the custom controller thing is really odd.
AT&T PC6300
Whoah - is this guy playing Berzerk?   Intruder Alert, Intruder Alert!
Looks like it's Nethack.
[SIGPIC][/SIGPIC]
« Reply #73 on: Mon, 16 August 2010, 16:59:55 »
I want one of those computers.
