Author Topic: Alternative Case for Massdrop ALT  (Read 2206 times)
Offline misterL2
« on: Tue, 26 March 2019, 13:32:09 »
I was wondering if there were some other cases that might fit the Massdrop ALT
Offline shiroshiro
Re: Alternative Case for Massdrop ALT
« Reply #1 on: Wed, 27 March 2019, 01:44:14 »
Yes, there are. But you MUST swap the plate as well. Namely the Fanoe from taobao, or even Tada68 (but you will need to make a custom plate for this one)
Offline misterL2
« Reply #2 on: Wed, 27 March 2019, 20:59:15 »
Thanks for the help!
