Author Topic: TIL - Topre sliders are stabilized.  (Read 1112 times)
Offline bpiphany
  • former PrinsValium
« on: Tue, 13 September 2011, 08:35:21 »
I actually hadn't thought about the possibility, 38 screws later...
Topre 2X+ stabilizer by Fredrik Atmer, on Flickr
The Caps Lock stabilizer is a bit unique. Some of the screws goes into the brass risers. Most of them however only sneaks through black plastic holes formed between the slider inserts and are mounted directly into the plate. There is one hole there between A and S. The plate is 1.3 mm thick.
Topre Caps Lock stabilizer by Fredrik Atmer, on Flickr
The mounting plate holes are actually not quite square making it impossible to put the slider inserts the wrong way.
Realforce 105U, Mounting plate by Fredrik Atmer, on Flickr
The right Shift rubber came off when I opened the board up. It's a mess fitting everything together again if the cups come off. I did this with my HHKB to scan the PCB, and it had enough of cups to keep straight.
Realforce 105U, PCB top with Rubber Cups by Fredrik Atmer, on Flickr
Nothing very surprising. I think the PCB on the HHKB is >2 layers. This one looks like ordinary 2 layers though.
Realforce 105U, PCB back by Fredrik Atmer, on Flickr
Details of the controller circuitry. I have higher res pics if anyone is interested. Today I also learned about multiplexers..
Realforce 105U, controller detail 1 by Fredrik Atmer, on Flickr
Realforce 105U, controller detail 2 by Fredrik Atmer, on Flickr
Offline RiGS
« Reply #1 on: Tue, 13 September 2011, 10:51:38 »
I wonder why topre switches lack the annoying friction. The slider moves in that switch case in a similar fashion as the slider of cherry switches.
« Last Edit: Tue, 13 September 2011, 10:54:10 by RiGS »
Offline redpill
« Reply #2 on: Tue, 13 September 2011, 12:34:16 »
Them Topre folk know how to put a keyboard together.
^ Current Favorite ^  Topre Realforce 87UB 55g  |  Topre Realforce 103UB 55g | KBC Poker/Browns/Sanded KeycapsDucky 1087 | Filco MajesFoam-2 | IBM Model M 1390131 Feb '87 | Still Love: Microsoft Trackball Explorer x3 | Now Unused:  Microsoft Natural Ergo 4k x2
Offline bpiphany
« Reply #3 on: Tue, 13 September 2011, 13:40:06 »
Quote from: ripster;415548
Someone should put a link to this TIL in the Topre Wiki.
Otherwise it will fade away like most keyboard forum posts.
Actually, anyone feel free to add the photos or links there, I don't like messing around largely with other peoples wikis...
Offline bpiphany
« Reply #4 on: Tue, 13 September 2011, 13:44:56 »
Quote from: RiGS;415486
Probably the larger area of interaction smooths over imperfections better. Also when hitting a key a bit off center, and the sliders being wider, the levering force "jamming" the slide might be smaller. Differences in materials and tolerances could surely play a role too.
Offline simon_C
« Reply #5 on: Tue, 13 September 2011, 13:55:44 »
TIL topres are rubber dome
Offline Daniel Beaver
« Reply #6 on: Tue, 13 September 2011, 14:14:16 »
Yep, that's why they're so damn nice. Incidentally, also why the Dell Quietkeys are so nice.
Home: Topre Realforce 87W45  /  Mionix Naos 3200
Work: Topre Realforce 87B  /  Microsoft Intellimouse Explorer 3.0
Offline bpiphany
« Reply #7 on: Thu, 15 September 2011, 08:27:10 »
Ever wondered how large the capacitance of the Topre switch really is? Yeah, me too... This multimeter might do the trick I hope. Looks like a baseline of 5pF.
Capacitance of unconnected wires by Fredrik Atmer, on Flickr
I had to cut the traces to isolate the switch from the circuitry. I was aiming for Scroll Lock, but missed only by a hair =P Soldered in probe wires.
Close-up of Topre switch capacitor by Fredrik Atmer, on Flickr
8pF while released, minus those 5 lets say <~5pF.
Topre switch capacitance, released by Fredrik Atmer, on Flickr
14pF while pressed, so lets say ~10pF.
Topre switch capacitance, pressed by Fredrik Atmer, on Flickr
I don't really know anything about electronics, but if my measuring method is nearly okay that would mean at least a doubling in capacitance. Wouldn't be too hard to detect, would it? I need to take an electronics course...
Offline RiGS
« Reply #8 on: Thu, 15 September 2011, 08:47:25 »
I wonder if it's possible to replace the wimpy topre springs to a stiffer custom made one. That way the all 30g topre domes with a 65g spring could be a nice linear switch combo, but without the annoying friction.
Offline bpiphany
« Reply #9 on: Thu, 15 September 2011, 09:16:55 »
Quote from: RiGS;416473
My layman answer would be that metals are all pretty much the same when it comes to affecting the gap properties of the capacitor. So yes I wouldn't see any greater problems doing it. Even if the properties are slightly different that could probably be adjusted for by changing some resistor somewhere. Didn't Topre announce a keyboard with a trim wheel? =)
Offline thebilgerat
« Reply #10 on: Thu, 15 September 2011, 09:45:26 »
TIL people are perfectly willing to cut trace and solder leads to a 300+ dollar keyboard to double check capacitance figures.  Without much electrical experience.  Which is awesome!
Offline bpiphany
« Reply #11 on: Thu, 15 September 2011, 10:09:11 »
I'm not completely noob with soldering and physics in general =) Just not a lot of electronics knowledge in specific. And "double check", are there numbers somewhere? And they are at least a little less than $300. I haven't done anything irreversible, yet...
Online suprsmo
  • Sydney, Australia
« Reply #12 on: Tue, 24 April 2012, 21:51:58 »
Cheers for this. Found it a google search for Topre Stabilizers.
Poker Poker QFR
QuickFire Rapid
Realforce 86u Black Variable - For sale
