My Topre Realforce all-45g EliteKeyboards edition (
http://elitekeyboards.com/products.php?sub=topre_keyboards,rftenkeyless&pid=rf_se19e0) arrived yesterday, and I'm a bit mystified.
I immediately noticed that some of the keys were quite significantly lighter. Especially the
Right Alt and
Left Windows keys require no effort to press down compared to other keys.
So I did some tests with a digital scale and weights, and tested different keys with their caps on. The significantly lighter keys go down at
33-35g (L.Win at 38g) and the bump is not really that pronounced. Most keys on the keyboard go down at
50-55g and the bump at the beginning of the key travel is noticable.
Where it gets really odd is that for example in the middle of the keyboard, the h-key goes down at
48g (and has a light bump) when the g-key next to it requires
56g of weights before giving way (and has a pronounced bump). This is noticable while typing. The left hand side of the keyboard felt stiffer when I stared typing, and I first thought it was just me. But when I measured it, it really is stiffer. All the keys on the left side of the home row hold themselves up at
55g when half the keys on the right can't even hold
50g. Then for example the Esc-key requires only
41g and most of the top row F-keys get pressed down at
46g. There is variation like this all over the board which makes for an odd feel when typing, and there are keys that don't fit into any weight category.
So, what's the deal here? Is the all-45g model not really all-45 but mostly-same-weights-here-and-there instead? Do I have a keyboard with random monday parts thrown into it? Or is the quality control of the switches refererred to as the "Mercedes of the keyboard world" so bad that they might differ by whole weight categories? I've thought about things like break-in and how the keys might even out a bit over time. If the switches were within 3g of eachother I would believe it's just variation and having to break them in, but if switches that are supposed to be the same differ as much as the weights they manufacture (30,35,45,55cN according to deskthority wiki) it's a bit hard to believe.
Does anyone here have an all-45g model they could test this with (if not anything comprehensive, at least something really obvious like the \ key)? Or does anyone know how to identify what switches are used? The switches themselves each have a letter on them but I have not been able to find any pattern. I emailed EliteKeyboards after initially measuring the lightest keys yesterday but have not heard back from them yet.
Update: I heard back from EliteKeyboards. They confirmed what thegunner100 said about Topre's tolerances in manufacturing, but said that the differences measured here are unusually big. It's common for the keys to start on the heavier side and loosen up a bit after some use, but the light keys can't really get heavier. A replacement board would be an option, but it is not offered in this case as I live outside the US. They have asked Topre to weight in, but unless they are interested in getting involved, the options EK is suggesting are either a small discount or replacement domes for the switches.
I'll let you know when I hear more.
