Author Topic: [SPRiT] R1 R2 (Shipping 92% Completed)  (Read 1789307 times)
Offline cherpalla
Re: < SPRIT Model 1 > PCB + Case + Parts ... (Preparing to Ship 1st Round)
« Reply #2050 on: Wed, 16 April 2014, 13:38:13 »
Are round 2 invoices going out soon? :)
c h e r
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
« Reply #2051 on: Wed, 16 April 2014, 15:33:44 »
Hello!  cherpalla!
When most of the Round 1 shipped,  I am planning.   This will be OK?   ;)
Offline BlueBär
« Reply #2052 on: Wed, 16 April 2014, 15:39:13 »
Sprit is there a list of which orders have been shipped?
Offline sprit
« Reply #2053 on: Wed, 16 April 2014, 15:45:36 »
I am doing shipping out the small parts Orders Now,   Preparing for the PCB+ Case + Parts orders.
yet too many things to do.    :)    I am trying to focus on quality control.
Simple PCB only orders will ship first,  but depends on the soldering progress.
I am focusing on this.
« Last Edit: Wed, 16 April 2014, 15:49:49 by sprit »
Offline BlueBär
« Reply #2054 on: Wed, 16 April 2014, 15:47:21 »
Take your time :thumb:
Offline lotus1109
Hello!  cherpalla!
Good to hear that Sprit!
Any idea that you actually shipped mine? :) i order pcb + plate + small parts without case fyi
Is there a 75%?
Offline BlueBär
Offline bakteria
Spirit you could skip the soldering for my order if that would help speed things up. I think I'll manage
SS 7G black - Pure red - poker blue (MKC Tray)
Offline IronJoeJac
« Reply #2059 on: Mon, 21 April 2014, 12:38:07 »
I don't know if this has already been asked but would the 60% pcb and and plate fit into any other cases such as a poker one?
CM Quickfire TK (blue)    HHKB PRO 2 Black
Offline Zeal
    • Zeal Generation Inc.
« Reply #2060 on: Mon, 21 April 2014, 13:08:16 »
Yes, sprit's pcb and plate fits in poker style cases.
Offline IronJoeJac
« Reply #2061 on: Mon, 21 April 2014, 13:39:59 »
Thanks, that helps me a lot.
Offline loud_asian
« Reply #2062 on: Mon, 21 April 2014, 19:23:52 »
Does anyone know if the pcb fits into any other cases? Shipping is gonna cost me an arm and a leg if I have to buy a case from sprit.
Offline nuclearsandwich
« Reply #2063 on: Mon, 21 April 2014, 20:06:37 »
What size PCB? The 60% fits Poker / GH60 cases and I think the tenkeyless fits Filcos but I'm not completely sure. That part of the thread was like October ago. Heh.
Offline YongJK
« Reply #2064 on: Mon, 21 April 2014, 21:29:39 »
I noticed I forgot to pay.
Are you able to ship this week?
if yes I will pay asap.
Keyboard: PLU ML87 Mx Blue
Offline Permeability
Sprit can you please update me on my order? Thanks
Keyboards:
'The Cheat' - lubed 62g Clears
Ducky Shine 3 TKL lubed 45g Reds (Work)
Offline taylordcraig
« Reply #2066 on: Tue, 22 April 2014, 00:47:33 »
Hi Sprit hope things are going well.
I still want to order a keyboard from you.
I've just been buying so many other things.
Can anyone tell me if stabs/springs/switches and everything is available so I can buy a complete board? Or how long it will be sold out for?
Thanks in advance.
Offline Zeal
« Reply #2067 on: Tue, 22 April 2014, 00:55:05 »
Thanks in advance.
It seems like custom gold plated springs, PCB mount stabilizers and MX Clear switches are out of stock in R2.
Offline Lubed Up Slug
« Reply #2068 on: Tue, 22 April 2014, 00:55:40 »
So for these plates, acrylic, 1.6 mm, and 4 mm will they allow for switch removal without desoldering?
Also what is the benefit of the 4 mm plate over the 1.6 mm one?  Does it just feel more solid?
Offline loud_asian
« Reply #2069 on: Tue, 22 April 2014, 01:19:06 »
Sorry forgot to mention it was the 87% I was talking about. I don't think it fits into Filcos cause the usb port on the sprit pcb is on the far left while the Filco has its port in the middle
Offline AKmalamute
  • HHKB Scrub
« Reply #2070 on: Tue, 22 April 2014, 01:25:50 »
I'm not sure about the 1.5, but I think the 4mm aluminum is too deep to remove switchtops -- they're completely buried in there. And yes, as has been discussed, it's HEAVY and also stiff -- this has ramifications that entice some, and repulse others.
HHKB-lite2, Dvorak user
« Reply #2071 on: Tue, 22 April 2014, 01:28:37 »
Could I get a plate from the other 60% plate group buy and would it be compatible? Also if I were to get the PCB does it come with a controller?  Would I need to program layers onto it?
« Last Edit: Tue, 22 April 2014, 01:31:49 by Lubed Up Slug »
« Reply #2072 on: Tue, 22 April 2014, 15:10:35 »
Thanks in advance.
So are there just stock switches [red/blue/brown/black] and no different weight springs? We get plate mount stabilizers? Are they Cherry or Costar? I don't know much about stabilizers. Thanks for your time.
Offline Zeal
« Reply #2073 on: Tue, 22 April 2014, 16:20:48 »
Thanks in advance.
I said PCB mount stabilizers.  :p The majority of Korean boards use PCB mount.
And yes, only the "standard" switches are available. Plus, I don't think you will be lacking any custom springs :P
Offline Cottonsox
« Reply #2074 on: Thu, 24 April 2014, 01:02:00 »
anychance on a quick update, just in general.
I understand things are busy and moving slowly. Be good to just know a little bit of information in regards to where things are at in regards to round 1 and how close to shipping these orders might be.
Offline lotus1109
Received mine. Should start assembling now! :)
What is the key to switch on the led for facew?
Offline fatchoi
Do you mind telling what have you ordered?
Good for you to enjoy!
Offline lotus1109
FaceW Pcb and switches + springs :)
It was at my home since last week I guess but I was away for 2 weeks:(
Offline fatchoi
Sounds good! I order similar stuff. Fingers crossed for my stuff. (PCB, case, switch, spring, lub)
Offline Pacifist
  • on hiatus
« Reply #2079 on: Mon, 28 April 2014, 00:06:55 »
are you going to make 75% metal cases?
« Reply #2080 on: Mon, 28 April 2014, 00:07:40 »
Does the plate allow for switch removal without desoldering? Could I use another 60% plate with this PCB?
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
« Reply #2081 on: Mon, 28 April 2014, 00:46:54 »
According to pictures sprit has provided it looks like its switch removable. You should also be able to use another plate for the 60% such as a beast plate! Just remember if you use leds in your switches you cant remove them either way.
Very busy with studies atm.
« Reply #2082 on: Mon, 28 April 2014, 00:48:48 »
you can if you use SIP headers in your switches.
edit: I meant sip sockets
« Last Edit: Tue, 29 April 2014, 18:03:33 by dorkvader »
« Reply #2083 on: Mon, 28 April 2014, 00:53:47 »
Firstly, yes the acrylic plate seems to support it, I was just wondering about the aluminum ones, I should have been more clear.
Second on the topic of LEDs, I was under the impression that through the magic of modification, you could mod switches to allow for LEDs and removal, by removing the LED ring thingy.  As shown in this video https://www.youtube.com/watch?v=TEAzBbVU-yE
Third, what are SIP headers and how do they relate to this?  Please enlighten me, I am new to this.  (Yes I googled it, nothing helpful)
Offline Cottonsox
Sip sockets
http://geekhack.org/index.php?topic=51792.0
Sip sockets
Ah thank you.  Very interesting.
Offline lotus1109
I am using hammer plate:)
Offline swill
  • builder & enabler
    • swillkb.com
Unless you use SIP sockets, which I will be using on this board and would recommend.
Offline swill
  • builder & enabler
    • swillkb.com
I was told that the switch tops are removable on these plates by sprit.
Offline TheMoonUnderWater
Excuse my extreme ignorance but is there a particular type/spec of SIP socket to use?
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Of course not all sip sockets are made to fit keyboards but many do like these ones: http://www.ebay.com/itm/3Pcs-Single-Row-40Pin-2-54mm-Round-Female-Pin-Header/140910386490?_trksid=p2052191.m2067&_trkparms=aid%3D555003%26algo%3DPW.CAT%26ao%3D2%26asc%3D23%26meid%3D3295674393841359663%26pid%3D100028%26prg%3D1009%26rk%3D4%26rkt%3D15%26sd%3D221186042943%26 They are confirmed to work!
Offline Vintage
« Reply #2091 on: Tue, 29 April 2014, 08:58:01 »
Wow... never knew you could do that. Will have to look into that xD
CM QFR w/ MX Reds  | Logitech G900
Offline swill
  • builder & enabler
    • swillkb.com
There is a thread on here dedicated to sip socket implementations. I am on my phone, so I can't easily link it right now. There are lots of ways to work with the sockets, so check that thread for more details. I did a little video to show how I use them.
Offline Cottonsox
I linked it a few post back.
Offline lotus1109
I do try fn+caps / esc+caps according to faceu guide but it seems that it is not working on facew. Anyone could tell me which keys to trigger the led mode? Thanks
Offline sprit
Hi! Lotus!   ;)    Please,
- Check the positive legs of LEDs  You got.  it's usually the longer one.
- FN + Caps should work as You know
« Last Edit: Wed, 30 April 2014, 01:55:11 by sprit »
Offline fatchoi
Hello Sprit, is there an estimated schedule of shipping out the stuff please?
I'm waiting for the lub to assembly my some other keyboard. :(
Offline thestage
« Reply #2097 on: Thu, 01 May 2014, 15:35:56 »
if I source my own switches and stabilizers for this, do I need PCB mount, plate mount, or either?
Offline Zeal
« Reply #2098 on: Thu, 01 May 2014, 15:40:15 »
Stabilizers are PCB mount. Switches can be either PCB or plate, depending on your configuration.
Offline thestage
« Reply #2099 on: Thu, 01 May 2014, 22:49:46 »
does anyone have a picture of what the "frosty" color option looks like for the plate or case?
