Are your eyes bleeding? You can always change your theme.
Is it possible to make a case for the HHKB?
So PCBs in Spirit GB will fit in these plate/cases?(no one has seen those PCBs or some scheme)
I think I am in for a v8. Will there be an option for 86 key as well as 84 key? Also, will the plates allow for swapping of switch stems?
Quote from: roadblock2thesun on Thu, 21 November 2013, 10:17:16I think I am in for a v8. Will there be an option for 86 key as well as 84 key? Also, will the plates allow for swapping of switch stems?yes, this is base option. Plate now is fixed but if someone want openable sw T_T I'll try.
Oh, I forgot to mention. I'm in for a V7, V8, and V10.I already have to many 60% alu cases.
So when sprit gets around to making a 98/99 key (similar to the quickfire TK layout) pcb, could you design a case for it? The V6 and V8 cases are beauties.
Quote from: Loligagger on Thu, 28 November 2013, 09:31:45So when sprit gets around to making a 98/99 key (similar to the quickfire TK layout) pcb, could you design a case for it? The V6 and V8 cases are beauties.I dont know about this layout. I never see a87 support this? Design this is easy, but i think beastmask dont make any sw upper arrow key... like phantom
new A87? and he will design new PCB because ATMEGA32 upper arrow keys http://cfile27.uf.tistory.com/image/224C363451C3E734318895
Nice case. Is that second color pic of the gray or black? And does this come with those awesome anodized stabilizers too?
How much does the V6 case weigh?
Might be in for two. Damnit, shouldn't have put in my order for 4 SPRiT cases.
It's a good width! If it's half-width it's too narrow, and full-width is too wide.
still waiting for the anodizing samples
Quote from: terran5992 on Mon, 18 November 2013, 02:53:19Is it possible to make a case for the HHKB?No bro, plate in HHKB is a top cover of switch... It's hard to made metal plate like this.
What is the status of this? Will the TKL cases be made?
what happened with this?
You would be an idiot to even consider dealing with this guy...
