Author Topic: [GB] Granite Set ~ Sublimated Full PBT (spacebar included)  (Read 1950670 times)
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« on: Wed, 26 March 2014, 09:04:30 »
GB Order Page
GB Ended! Now to production!
The final look and feel will be close to this. 3D render of a poker-like keyboard with Icon modifiers.
And with Text modifiers, red WASD and RGB mods.
Final pricelist
green = MOQ reached
Spread the word
If you like this set and want to help spreading the word, follow these instructions http://geekhack.org/index.php?topic=56354.msg1277510#msg1277510 and add a link to this page to your signature!
Please read carefully the whole post!
The full set is in PBT material (arguably the best for keycaps) including the spacebar. Legend are dye sublimated.
Keycaps thickness is very good. Look at this picture, the blue key is PBT.
SP did a really fine job with the PBT spacebar. It's definitely one of the less bent I've seen so far.
6.25u spacebar (the standard one) is included in the "Common kit", but you may want to grab an additional one. If you need 7u spacebar you have to grab it separately (it is not included in any other set). We do not have an universal spacebar.
The keycaps profile is DSA.
It's a low spherical top profile. The height of the keys is approx the same as DCS Row 3, but it's thicker. All keys are on the same row meaning that you can put any key in any position making it ideal for custom keyboards and less common layouts (colemak, qzerty, ...).
Color is pure gray. The base color codes are GKK + GDE.
ISO Enter is in DCS profile. SP doesn't have ISO Enter in DSA, but the DCS one works pretty well. Here is the DCS ISO Enter close to DSA keys.
Number of keys and their size are final, but legend color, positioning and thickness may change a bit. Also the Nerdom kit may see some different legends!
Order Form
The Group Buy is handled directly by Signature Plastics (the keycaps manufacturer), this should grant an overall better buying experience and better pricing. The system is still relatively new, if you encounter any problem please contact SP directly!
GB Order Page
How and when my money is taken from Paypal account?
Funds on Paypal are placed "on hold" for the maximum value of all the kits you ordered but they are not actually taken from the account.
When the Group Buy ends only the real, final value is billed.
No thread-crapping
If you don't like the DSA profile, this whole set or SP ordering system please refrain from thread crapping. Simply don't buy! You may discuss any of those arguments elsewhere on this very same forum. Thanks.
What kits do I need?
Unless you plan on taking a blank/otaku set the bare minimum you need is the Common Kit
All modifiers are available in TEXT and ICON variants. Choose your fragrance and grab one (or both) of the Icon or the Text modifier kits.
You now covered a Tenkeyless keyboard (such the Filco Majestouch).
If you have a full standard keyboard, take the numpad too.
Highly recommended kits!
To make your purchase future proof (and to raise the value in case of resell) remember to also take the Icon or Text Pro Modifier kits
They will cover less common layouts (1.50u modifiers, KBT Pure, etc...) and they include keys to swap Caps lock with control or FN. I highly suggest to grab one Pro kit!
Remember to get a 7u spacebar if you have 1.50u modifiers. I'd also take an additional 6.25u, just in case...
Being the keyboard pure gray a bit of color may help break the boredom. The Blue Enter is a nice little addition to the mix.
Nice to have
Let's try to reach high tier on the Nerdom kit, 18 Novelty keys to feed the nerd in you.
If you want to add even more color I suggest the RGB kits
And for gamers the WASD kit
Let's go multi-lingual
Granite set supports 11 languages!
First of all get an ISO Enter. The 1.25u shift is included in the base modifier kit, the Alt Gr (if you need it) is in the Pro kit.
Then pick the kit which includes your lingo.
Ergodox
The Granite set is one of the few with a full legended Ergodox kit. The full Ergodox experience is: Common Kit + Text modifiers + Ergodoxian (and eventually add 1 half-ergodox kit for some blanks).
It should include approx 70% of your keys, all that you miss can be covered by the Half-Ergodox Kit.
If you only want blanks on your Ergodox remember to grab two of these!
More madness
More keys if you hadn't enough. Remember the Apple kit if you are a Mac user and the Extra Homing to cover less common keyboard layouts! The extra homing also includes a homing arrow key extremely useful in case of 65% and 75% layouts!
Blanks
Last but not least, for all the otakus out there, here come the blanks!
Don't forget the keypuller
You can now also add a keypuller to your order. Both wired and plastic keypullers are available but if you need it I strongly suggest to get the wire one!
Good hunting!
If you have any question don't hesitate to ask!
GB Order Page
« Last Edit: Thu, 17 April 2014, 15:19:23 by Matt3o »
Offline skuko
Re: [GB] Granite Set ~ Sublimated Full PBT (spacebar included)
« Reply #1 on: Wed, 26 March 2014, 10:22:51 »
cannot wait man!
Offline Vibex
  • Love y'all
« Reply #2 on: Wed, 26 March 2014, 13:23:49 »
Will there be additional keys for people using Colemak and Dvorak? If so, I'm totally in! :thumb:
Offline HendyZone
  • HHKB Elite
    • MechanicalKeyboards.co.id
« Reply #3 on: Wed, 26 March 2014, 13:27:25 »
Ouh man can't wait for the pricing :cool:
Offline intelli78
« Reply #4 on: Wed, 26 March 2014, 13:28:06 »
Sorry if I missed in the other thread, but can you show the thickness of these caps?
Offline Zeal
    • Zeal Generation Inc.
« Reply #5 on: Wed, 26 March 2014, 13:28:22 »
I recall seeing extra scooped keys for the other formats  :)
Offline ideus
  • Björkö.
« Reply #6 on: Wed, 26 March 2014, 13:30:00 »
All the keys have the same profile, then you can move any key around, and there will be a set with extra homing keys. Just check if they fit your preferred layout.
Offline Vibex
  • Love y'all
« Reply #7 on: Wed, 26 March 2014, 13:34:11 »
Awesome, but what about things like additional backspaces to replace caps lock on colemak?
Offline HendyZone
  • HHKB Elite
« Reply #8 on: Wed, 26 March 2014, 13:34:33 »
Are keycaps thick?
Pretty much yes. Actually the same thickness of ABS DSA. The blue spacer below is PBT
http://geekhack.org/index.php?topic=55314.960
Offline intelli78
« Reply #9 on: Wed, 26 March 2014, 13:42:45 »
Looks good, thanks.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #10 on: Wed, 26 March 2014, 13:44:16 »
This is one great looking set. matt3o has really outdone himself on this one.
Offline ideus
  • Björkö.
« Reply #11 on: Wed, 26 March 2014, 13:46:24 »
You may use one of the alternate 1.75u keys in the icon pro set.
Offline Vibex
  • Love y'all
« Reply #12 on: Wed, 26 March 2014, 13:47:49 »
I can live with that. ;D
Offline admiralvorian
  • DIY
« Reply #13 on: Wed, 26 March 2014, 15:48:37 »
Darude Status:
☐ Not Sandstorm
☑ Sandstorm                                               wts wtt wtb
Offline Lastpilot
  • Power stance
« Reply #14 on: Wed, 26 March 2014, 16:13:37 »
SP does windowed keys now?!
« Reply #15 on: Wed, 26 March 2014, 16:25:45 »
I've been following the IC - the amount of work he has put into this is unbelievable.
But it has all paid off! :)
Offline Razor Lotus
« Reply #16 on: Wed, 26 March 2014, 16:48:30 »
I'm reading that DSA caps are quite tight on the stems.
Anyone has any input on this? As long as I don't break my stems I'm alright I guess
Offline StylinGreymon
  • Keyboard Hipstar
« Reply #17 on: Wed, 26 March 2014, 17:20:13 »
My paypal account is locked and loaded.
Let's go let's go let's go!
If today had been a hippo, then you'd really have to worry about tomorrow.
« Reply #18 on: Wed, 26 March 2014, 19:16:45 »
Item 22 in SP FAQ: http://www.keycapsdirect.com/faq.php#22
This has been addressed by SP: http://geekhack.org/index.php?topic=54334.msg1270259#msg1270259
Offline Belfong
« Reply #19 on: Wed, 26 March 2014, 19:35:29 »
I'm really into Topre and would like to minimize MX stuff but I can't resist the pull of this color and that it is PBT! Oh man!!
Thanks for pulling this together matt3o - I've been following in IC thread as well and appreciate the community input to make this happens.
Offline ideus
  • Björkö.
« Reply #20 on: Wed, 26 March 2014, 19:39:17 »
Topre??, LOL, just joking, MX is all the fun bro...
Offline Belfong
« Reply #21 on: Wed, 26 March 2014, 19:51:17 »
I KNOW! Ha ha.. So I'm just buying and putting them on displays. Lol.
« Reply #22 on: Wed, 26 March 2014, 21:45:16 »
Just wait for the Topre sliders that are compatible with MX keycaps!  Best of both worlds.
Offline bianco
« Reply #23 on: Wed, 26 March 2014, 21:49:01 »
interested! looking forward to a numpad kit to go along with it.
Offline sakai4eva
« Reply #24 on: Thu, 27 March 2014, 03:53:17 »
I would like to thank the community for the ergodoxian option.
Like, really thank.
Offline sth
  • 2 girls 1 cuprubber
« Reply #25 on: Thu, 27 March 2014, 03:54:25 »
hhkb option?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #26 on: Thu, 27 March 2014, 04:00:53 »
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #27 on: Thu, 27 March 2014, 04:34:45 »
I've added the list of all kits (you better maximize your browser window) and cleaned up the thread a little
Offline bianco
« Reply #28 on: Thu, 27 March 2014, 04:42:58 »
another wonderful set Matt3o.  :thumb:
Offline skuko
« Reply #29 on: Thu, 27 March 2014, 04:54:05 »
placeholder for my order:
Common Kit
Text Modifiers
Text RGB
WASD
Blue Enter
6.25u spacebar
Lost+Found
this is gonna be WICKEEEEEEEED
« Last Edit: Thu, 27 March 2014, 04:56:48 by skuko »
  • Keyboard Hipstar
« Reply #30 on: Thu, 27 March 2014, 05:02:58 »
Here's mine:
Common
Text Mods
Icon Mods
Text Pro
Icon Pro
Text RGB
Icon RGB
Blue Enter
Numpad
Offline skuko
« Reply #31 on: Thu, 27 March 2014, 05:28:52 »
nice one....personally, i ain't too hot on the icons, even though they're very well thought out. maybe i'll add them - depends on the pricing.
  • Keyboard Hipstar
« Reply #32 on: Thu, 27 March 2014, 05:40:24 »
I simply haven't seen anything like them, so I have to get them.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #33 on: Thu, 27 March 2014, 05:46:16 »
I really wonder how much this set will end up costing. Hopefully I can afford it... would be nice to try DSA.
« Last Edit: Thu, 27 March 2014, 05:50:30 by epzy »
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #34 on: Thu, 27 March 2014, 05:55:22 »
A TKL should go around $60
Offline epzy
  • HHKB Fiend
  • ded
« Reply #35 on: Thu, 27 March 2014, 06:22:40 »
Not bad, not bad. :) Will probably need some extra kits though!
Offline mougrim
« Reply #36 on: Thu, 27 March 2014, 06:58:21 »
Cool! Nice-looking kit AND with russian/ukrainian variant. Hmmm... I'll be waiting for this. I know I will.
P.S. Hope shipping to Ukraine won't cost an arm and an leg :)
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #37 on: Thu, 27 March 2014, 08:22:40 »
Updated first post. Now just waiting for SP green-light.
Offline mougrim
« Reply #38 on: Thu, 27 March 2014, 08:41:11 »
I have some question about first post - if I want russian layout, i need to buy common kit + cyrillic kit? Jr there are some other variants?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #39 on: Thu, 27 March 2014, 08:47:40 »
yes, you need the common kit anyway. Common + cyrillic + text or icon mods. What do you mean by "other variants"?
Offline mougrim
« Reply #40 on: Thu, 27 March 2014, 08:57:01 »
Like if common kit will be in cyrillic variant - so I could just order it. But, as I see, it's not an option.
You see, I wait for my Poker II and looking for keyset for it beforehand.
Offline justnits
Ducky DK9008 Shine 2 Gateron Red w/ Korean 55g gold lubed spring & custom LED | Ergodox with Aluminium top plate | IBM Model M SSK | GHPad | GON's Nerd TKL | Filco Majestouch 2 TKL MX Blue
[Sold]Keycool 87 PBT White Cherry MX Blue | [Sold]ikbc F-104 Cherry MX Brown
Offline Belfong
Offline ideus
  • Björkö.
« Reply #43 on: Thu, 27 March 2014, 11:08:55 »
Where are the mods sets?
Offline justnits
« Reply #44 on: Thu, 27 March 2014, 11:10:25 »
eh...seems like not all the kits are in yet?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #45 on: Thu, 27 March 2014, 11:11:02 »
Please wait!
I'll let you know when everything will be up and running
Offline mougrim
« Reply #46 on: Thu, 27 March 2014, 11:13:08 »
I humbly asking fellow GH-ers, what combination I need to cover my Poker II? Basic kit + modifiers?
Offline epzy
  • HHKB Fiend
  • ded
« Reply #47 on: Thu, 27 March 2014, 11:14:21 »
Ya, but if your Poker 2 has a ISO layout you'll need the ISO kit as well.
Offline justnits
« Reply #48 on: Thu, 27 March 2014, 11:17:08 »
Please wait!
 :thumb:
but the price for the kits shown now is final right?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #49 on: Thu, 27 March 2014, 11:18:38 »
Please wait!
 :thumb:
so it seems
