Author Topic: CM Storm Novatouch Pre-Launch Showcase & First Impressions & Typing test  (Read 41462 times)
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
Re: CM Storm Novatouch Pre-Launch Showcase & First Impressions & Typing test
« Reply #50 on: Fri, 11 April 2014, 09:54:09 »
i've be very interested to see how very thick lube affects the 45g. really thick krytox is basically a solid and actually increases actuation force. might work well with the lighter domes? might be worth trying on a typeheaven.
Offline YuukiHaruto
« Reply #51 on: Fri, 11 April 2014, 13:50:29 »
Interesting. The only lube I have is some silicone lube. I have used it before for lubing my MX keyboards and it's fine
Otherwise, what else can I add on to this thread  ;D
« Reply #52 on: Sat, 12 April 2014, 08:25:54 »
If you look on deskthority you will find that CM Bram said that if the 45g sells well, 30g and 55g might be in the pipeline
30g?
Sweet, first board that you can type with waving your hand over the keys!
Offline YuukiHaruto
« Reply #53 on: Sat, 12 April 2014, 09:42:39 »
30g?
._.  :))
Offline Hypersphere
« Reply #54 on: Sat, 12 April 2014, 16:48:13 »
This new keyboard has great potential. Topre-switch boards have been hampered by a relative lack of replacement or custom keycaps. Here are some things I would hope to see, either in the forthcoming CM Topre-switch board or other models that might follow:
1. Ability to switch Backspace with Backslash (\), including a keycap swap for these positions.
2. Ability to convert Caps Lock to Control, including keycap swap.
3. Ability to exchange Win with Alt, Ctrl, or Fn.
4. Split Right Shift, putting Fn to the right of a shorter Right Shift.
5. Silenced Topre switches option.
6. 55-gram Topre switches option.
7. Non-rubberized case (is it so already?).
8. Micro-USB connector with plenty of room to connect third-party cables (is it so already?).
Future options:
1. 60% form factor, preferably with HHKB layout or DIP switch/programmable to HHKB layout.
2. Bluetooth or other wireless option.
3. High-profile two-tone color scheme dye-sub PBT keycaps with tasteful and attractive font, e.g., Helvetica.
4. See other options above.
Offline avtar
« Reply #55 on: Sat, 12 April 2014, 17:09:34 »
That is quite the wish list. #4 ever becoming a reality would be unfortunate because it will mean keycaps sets will need to accommodate a HHKB type layout. I would be surprised if #1 - 6 get implemented on the upcoming model since CM has been hinting that the Novatouch will cost less than $200.
I do hope that it doesn't ship with a rubberized finish. The grey case is looking pretty good.
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #56 on: Sat, 12 April 2014, 17:13:56 »
All the newer pictures I have seen of the Novatouch it has a black case (Although I pray they also have a gray case option).
Also the OP in his review said that his pre-production model does in fact have a rubberized case :(
Some of Ye ole  Keyboards -->
OTD Koala:  62g Old MX-Blacks   |   LZ-GH V2:  MX-?62g   |   KMAC2:   62g Tactile MX-Greys   |   LZ CLS s:   62g Vintage MX-Blacks   |   X60:   62g Vintage MX-Blacks   |   GON NerD 60:  62g Old MX-Clears   |   Filco MJ2 (Beige) TKL's:  62g MX-Clears  &   62g Vintage MX-Blacks   |   IBM '91 SSK
WTB/WTS/WTT ---->
Offline avtar
« Reply #57 on: Sat, 12 April 2014, 17:20:57 »
A CM rep shared that picture of the grey case in a Novatouch thread so it might happen.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #58 on: Sat, 12 April 2014, 17:35:58 »
it's not properly gray, just reflection on that ****ty rubberized finish
Offline avtar
« Reply #59 on: Sat, 12 April 2014, 17:38:10 »
Hopes dashed :'(
Offline Sniping
« Reply #60 on: Sat, 12 April 2014, 22:02:32 »
Is swapping with the QFR top case possible?
Offline YuukiHaruto
« Reply #61 on: Sat, 12 April 2014, 23:02:28 »
Future options:
1-4, what's the point of doing that?
5, Maybe.
6, 55 gram if the 45g sells well.
7. I prefer the rubberized case
8. huh? It IS a micro USB plug.
3) This keyboard is for people to swap keycaps anyway so why would they bother installing PBT keycaps from the get-go?
Offline RESPRiT
  • HHKB = ❤
« Reply #62 on: Sun, 13 April 2014, 01:18:49 »
Future options:
5, Maybe.
1-4 are common alternative preferences. You come off as really defensive when rjrich is giving some really good commentary btw :P
Offline YuukiHaruto
« Reply #63 on: Sun, 13 April 2014, 05:57:07 »
Future options:
5, Maybe.
Then technically speaking should every board have it. But, BIG (Like CM) manufacturers are just going to stick to standards. (yes, standards.)
Offline Candyflip
« Reply #64 on: Sun, 13 April 2014, 06:05:29 »
"Technically speaking" topre switch with MX stem is not that much standard...
Offline pexon
  • El Jefe of Sleeving
    • Pexon PCs
« Reply #65 on: Sun, 13 April 2014, 07:38:24 »
55 gram plz
Micro USB is cool too
Am I being stupid, I've just flitted through this thread, but did I miss a rough price of this bad boy?
Offline Candyflip
« Reply #66 on: Sun, 13 April 2014, 08:02:39 »
55 gram plz
From the PAX video the CM guy says between $150-170 roughly.
Offline pexon
    • Pexon PCs
« Reply #67 on: Sun, 13 April 2014, 09:05:18 »
Thats a damn fair price if you ask me. I'm sure it will translate to 150-170GBP though lol
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #68 on: Sun, 13 April 2014, 09:13:52 »
55 gram plz
Would you happen to have the link for that video?
WTB/WTS/WTT ---->
Offline Candyflip
« Reply #69 on: Sun, 13 April 2014, 09:17:29 »
Somewhere after 3:50 in the video
« Last Edit: Sun, 13 April 2014, 09:19:26 by Candyflip »
Offline avtar
« Reply #70 on: Sun, 13 April 2014, 09:19:03 »
Heads-up, it's pretty loud
Edit: too slow :P
« Last Edit: Sun, 13 April 2014, 09:20:55 by avtar »
Offline pexon
    • Pexon PCs
« Reply #71 on: Sun, 13 April 2014, 09:31:27 »
Thanks for the link to the video guys. It will be interested to see if it is compatible with existing TKL after market cases.
It baffles me as no-one from CM utters the word 'Topre,' they don't even hint it, it comes across to me that the CM representatives believe they developed the switch themselves.
Offline HPE1000
  • Keycap Paparazzo
« Reply #72 on: Sun, 13 April 2014, 09:45:44 »
Summer/Q3  >:D
Offline Candyflip
« Reply #73 on: Sun, 13 April 2014, 09:50:29 »
They have actually said that it is made by Topre, they just don't want to specify that when promoting the board for some reason.
Offline YuukiHaruto
« Reply #74 on: Sun, 13 April 2014, 11:09:29 »
We're talking about layouts  ;)
Summer/Q3  >:D
AFAIK It won't be that late ... I'm pissed if it's that late.  >:D
Offline avtar
« Reply #75 on: Sun, 13 April 2014, 11:22:12 »
Summer/Q3  >:D
We're pretty much two weeks away from May. A summer release sounds like a safe bet if they're still addressing USB issues and another CM rep mentioned something or the other about the keycaps font.
Offline YuukiHaruto
« Reply #76 on: Sun, 13 April 2014, 11:30:43 »
Summer/Q3  >:D
I already said it's a micro USB. It's very easy to detach and latch the usb connector.
Offline avtar
« Reply #77 on: Sun, 13 April 2014, 11:37:30 »
Check that thread.
"The current one is actually quite nice, but look at the way it turns when plugged into the keyboard. I think they moved the socket during development but didn't alter the cable to match."
Offline YuukiHaruto
« Reply #78 on: Sun, 13 April 2014, 11:45:59 »
Check that thread.
 I see what you mean. Basically the right angle plug is the problem?
Offline avtar
« Reply #79 on: Sun, 13 April 2014, 11:52:12 »
You're in a better position to tell us ;)
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #80 on: Sun, 13 April 2014, 11:54:51 »
that has been reported to CM
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #81 on: Sun, 13 April 2014, 22:26:52 »
55 gram plz
Thanks for the video.
Looks like they are putting rubber on the fold out feet :thumb:
WTB/WTS/WTT ---->
Offline Polymer
« Reply #82 on: Sun, 13 April 2014, 22:43:15 »
It looks like the keyboard sits really high..sort of like the CM Pro....I hope it just looks like that...
Offline YuukiHaruto
« Reply #83 on: Sun, 13 April 2014, 23:03:20 »
Same profile as QFR.
Offline Pacifist
  • on hiatus
« Reply #84 on: Sun, 13 April 2014, 23:04:55 »
anybody know if it has the same profile as all the other TKLs before, ie can I put it in a custom case already on the market
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #85 on: Sun, 13 April 2014, 23:34:16 »
The back of the case looks different from the QFR's.
Pic from the OP
WTB/WTS/WTT ---->
Offline mkawa
« Reply #86 on: Mon, 14 April 2014, 01:31:03 »
all i can really say about this board is that it's the first new board i've been super excited about in quite a while. can't wait till i can get ahold of one!
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #87 on: Mon, 14 April 2014, 01:34:12 »
c'mon. 45g Topre. Really?
Offline mkawa
« Reply #88 on: Mon, 14 April 2014, 01:39:20 »
I AM EXCITE
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #89 on: Mon, 14 April 2014, 01:40:39 »
well, let's hope they fix the few issues before releasing it.
Offline Polymer
« Reply #90 on: Mon, 14 April 2014, 02:06:36 »
Is it?  So the front bezel is the same height as the QFR?  That'd be good but it doesn't look like that in the pics..but with all the different angles it is hard to tell...
Offline blackbox
« Reply #91 on: Mon, 14 April 2014, 05:45:22 »
Video from linus techtips:
The CM rep dosent mention Topre until Luke asks him about it.
« Last Edit: Mon, 14 April 2014, 05:54:09 by blackbox »
The LAN table!
« Reply #92 on: Mon, 14 April 2014, 05:49:05 »
The CM rep dosent mention Topre until Luke asks him about it. :rolleyes:
Hint: GH doesn't like the YouTube with https - change it to http and the preview window should appear :)
Edit 1: Oh, you already did.  Good job!
Edit 2: Still not good, how about this ...
« Last Edit: Mon, 14 April 2014, 05:50:40 by rowdy »
Offline blackbox
« Reply #93 on: Mon, 14 April 2014, 05:55:31 »
Thanks! It didnt like a video from a playlist (and https).
The LAN table!
« Reply #94 on: Mon, 14 April 2014, 06:00:37 »
It's a bit picky, isn't it.
A good rep - makes me want to buy one!
Offline blackbox
« Reply #95 on: Mon, 14 April 2014, 06:08:48 »
A good rep yes. But I had the feeling that he had talked for some hours (I know how that feels)
The LAN table!
Offline paco
« Reply #96 on: Mon, 14 April 2014, 07:01:08 »
Why do they say there is a tactile bump similar to a MX Brown switch? They say you have an initial resistance and than there is a bump like in MX Brown. Topre isn't like that at all.
But they keep on saying "based on Topre switches"... so they might NOT be Topre switches.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #97 on: Mon, 14 April 2014, 07:12:41 »
because people think mx brown are the go-to switches and they want to catch the commoners.
they are topre. the PCB is also topre branded.
Offline Polymer
« Reply #98 on: Mon, 14 April 2014, 10:21:21 »
I think it is because it has a tactile bump but isn't clicky...so the closest thing to it that people can relate to in the mechanical world is brown...although I think Alps are probably closer...and obviously a normal rubber dome keyboard is pretty similar in feel as well but they're not about to say that...
Offline davkol
  •  Post Editing Timeout
« Reply #99 on: Mon, 14 April 2014, 12:18:52 »
It's a partnership between Topre and CM Storm, if I understand it correctly. I suppose PFU wouldn't be very happy, if CM Storm made a budget-level HHKB.
OTOH Carter has mentioned that they'd consider a 60% design, if NovaTouch *is* successful.
