What switches would those be using? When I had previously stumbled across mentions of keytronic before it turned out that they were just rubber domes of supposed better quality than usual, but those were generally 90's vintage. I'd assume what the ad is talking about would be something else.
I think the Key-tronic version of capacitive switches were of the "foam and foil" variety which were the forerunner of todays membrane keyboards(they did not have truly individual switches).....so not exactly Topre quality.
If it's the same generation as my wang keytronic capacitive (mine is from 1983) then the switches are all plate mounted and separate. I really like how light the springs are and how they can easily make heavier spring switches for "reset" etc.
As far as I can tell, Keytronic started phasing out reed switches from their normal computer keyboards at about this time. They persisted much longer in industrial applications however (for example, gilbarco keyboards, before gilbarco switched to cortron hall effect).
