Author Topic: Saw the Matias switches on Massdrop, have some questions about building a board  (Read 74548 times)
Offline Willyc277
I've been thinking about building my own board and using a niche switch would make it even cooler. Are there parts readily available for building a board using these switches from scratch? Here is the link on Massdrop https://www.massdrop.com/buy/matias-switches
« Last Edit: Wed, 09 July 2014, 14:12:16 by Willyc277 »
Offline geniekid
Matias is running an interest check for a special 60% keyboard here.  Also, since Matias switches are essential Alps switches, you might also consider trying to get a Kingsaver from Elton here.
Offline jacobolus
Depends how “from scratch” you want to go. If you can order some laser-cut acrylic/wood or water-jet aluminum/steel (or have your own access to such machinery), you can make a plate that accepts Alps (and Matias) switches. Alternately, you can buy old Alps keyboards on eBay to swap switches into / harvest parts from for your own mods.
I’ve been CNC cutting case/plates out of wood, and plan to hand wire the switches, so the only parts needed are generic wire, solder, diodes, wood, and a microcontroller board (e.g. Teensy). That may be more “from scratch” than you’re looking to go though.
More conventionally... as mentioned, Matias is going to run a group buy for a 60% keyboard kit (including optional assembly). And there are some other upcoming commercial keyboard projects from various vendors using Matias switches. Sprit was going to have an Alps-compatible kit at some point, but I’m not sure if that’s happening yet http://geekhack.org/index.php?topic=50580.0.
What exactly are you looking for? What kind of board do you want to build?
Offline Matias
  • * Moderator
    • http://matias.ca
PCBs are also very good for making plates from, especially in small quantities.
Just provide them with the dieline for cutting, and you have a nice strong plate with zero effort on your part.  Some even offer a choice of colours.
Offline tuananh_bkk
i saw someone sold a keyboard (Duck Mini ) with matias switches before on DA.
The Duck mini, viper, and eagle can all accept Matias and Alps switches.
What caps would fit in the alps ergodox though?
