Author Topic: A key caps bench:  (Read 3996 times)
Offline itlnstln
A key caps bench:
« Reply #1 on: Tue, 18 May 2010, 15:24:26 »
What kind of switches does it have?
Offline phototristan
    • https://www.youtube.com/phototristan
A key caps bench:
« Reply #2 on: Tue, 18 May 2010, 15:25:51 »
I was wondering that too. I don't know if they depress or not. The keycaps look a bit like Model M kecaps to me though.
Offline itlnstln
A key caps bench:
« Reply #3 on: Tue, 18 May 2010, 15:28:55 »
The article says "click-ready," but since you can't expand the build pics, it's hard to tell.
I'm sure the Mac fans will appreciate that wallet, ripster.  I don't.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
A key caps bench:
« Reply #4 on: Tue, 18 May 2010, 15:29:06 »
Quote from: ripster;183690
You can buy keyboard fabric too.
I'm not gonna do that.
And what font do we think that is?
(it looks suspiciously like Apple keyboards...)
kishy.ca
Offline itlnstln
A key caps bench:
« Reply #5 on: Tue, 18 May 2010, 15:29:31 »
I was only half-joking.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
A key caps bench:
« Reply #6 on: Tue, 18 May 2010, 15:32:59 »
Quote from: itlnstln;183696
Whoops. I had the reply thing open for that long, apparently. Your reply wasn't there when I clicked quote.
kishy.ca
Offline Mental Hobbit
A key caps bench:
« Reply #7 on: Tue, 18 May 2010, 15:42:12 »
Quote from: itlnstln;183686
Must be mechanical. With rubber dome it would be a giant fart cushion.
Typing on blues.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
A key caps bench:
« Reply #8 on: Tue, 18 May 2010, 15:48:28 »
Quote from: ripster;183709
I don't think you guys are getting it.
This is also from the same designer in the OP.  A foam chair that you insert into your back pants pockets and carry around with you.
I find this oddly brilliant.
kishy.ca
A key caps bench:
« Reply #9 on: Tue, 18 May 2010, 15:54:57 »
Would create a great new fun sport for teenagers too: Sneak up on a pedestrian, strip them with one kick and run away.
Typing on blues.
Offline itlnstln
A key caps bench:
« Reply #10 on: Tue, 18 May 2010, 15:57:19 »
Space Invaders:
