Author Topic: best budget keyboard under $50 aud  (Read 5270 times)
Offline GuiseppeAg
« on: Fri, 05 April 2019, 00:54:58 »
need suggestions for a new keyboard, please leave me recommendations and suggestions
Offline the_ambyguous
  • there's a fine line between click and clack
Re: best budget keyboard under $50 aud
« Reply #1 on: Fri, 05 April 2019, 12:58:59 »
full keyboard under 50 bucks? used to be able to grab an anne pro v1 for 60 bucks new. I would recommend getting one second hand off mechmarket. usually comes with gaterons, although now there are a bunch of switch options. the anne pro, or the magicforce. both solid choices around that price range
Magnavox Typewriter | AEK64 | 658-4081 | Leading Edge 3501 | Omnikey Orange | 197Stotle | MPC2000
Offline Lanrefni
« Reply #2 on: Fri, 05 April 2019, 15:38:06 »
Eagletec KG010 is a decent 104 key for around $40,I used mine for over a year with no issues,ended up using it's switches in my BFO-9000,still trying to decide if I want to buy new switches to put in it.
Offline redbanshee
  • actually Dade Murphy
« Reply #3 on: Fri, 05 April 2019, 15:46:58 »
Velocifire TKL02WS Wireless
https://www.velocifiretech.com/product/velocifire-tkl02ws-wireless/
I own this board and id have to say im extremely impressed. I use it in my living room as a HTPC board.
« Reply #4 on: Sun, 07 April 2019, 21:54:19 »
Model M.
They do turn on sometimes in online auction sites.  I got my first two for AUD$32 or so (that's combined, not each).
With a bit of TLC most of them wil turn out great, and last you for years (if they have lasted 30 years so far, they will just keep on going).
Offline subcat
« Reply #5 on: Sun, 07 April 2019, 21:57:46 »
i'd camp gumtree/ebay for a little bit and see if you can't snag an old majestouch or something. gumtree has an fc300r and a ducky zero around $50 at the moment that could be good options.
