Author Topic: KC_HYPR - Zeal60  (Read 2342 times)
Offline Dr Xav
KC_HYPR - Zeal60
« on: Fri, 12 April 2019, 11:32:31 »
Hi all,
I just completed a zeal60 build (rev4), and I am pretty close to get it all up and running. I missing an important thing though! I am not able to get my hyper key configured.
I can't find any documentation as to why it wouldn't be working. Any suggestions welcome :)
cheers.
Offline Dr Xav
Re: KC_HYPR - Zeal60
« Reply #1 on: Fri, 12 April 2019, 18:08:45 »
I was also wondering if I can get more than 4 layers. I am using the default set up and made the configuration through the .bat file on windows.
Offline Dr Xav
« Reply #2 on: Sat, 13 April 2019, 14:06:56 »
well, sorted! I just needed the standard qmk firmware :)
