Author Topic: FC660M replacement keycaps.  (Read 5822 times)
Offline Hemanse
« on: Tue, 16 April 2019, 12:43:33 »
Tried asking this on the mk subreddit, but all I got was a downvote, so thought I might find help here :)
My FC660M have a few fading caps and a cracked that's not usable anymore, so I would like to replace the keycaps. I am using QMX clips, so the replacement caps should also be Cherry profile.
I would love to get a GMK set or similar, but I do not have the funds for that sadly. I know the FC660M have some odd keys like the right shift, which I guess makes the search a bit more narrow.
Tried maybe finding a set from another FC660M user who replaced the caps, but with no luck.
https://kprepublic.com/products/cherry-profile-dye-sub-keycap-set-thick-pbt-plastic-black-yellow-gentleman-for-gh60-xd64-xd84-xd96-tada68-87-104-razer-corsair
Would something like this fit, the XD/TADA set seems like it would have all the keys for my board?
Thanks in advance  :thumb:
Offline thearctican
Re: FC660M replacement keycaps.
« Reply #1 on: Tue, 16 April 2019, 13:28:03 »
Caps for the FC660M should be pretty easy to find, but it kind of depends on when you got your FC660.
There was a cutoff where the spacebar stabilizer spacing was different. Can you take a photo of the back label and/or take off the space bar and take a photo of the switch and stabilizer?
We'll sort it out.
Offline Hemanse
« Reply #2 on: Tue, 16 April 2019, 13:38:21 »
We'll sort it out.
I sure can, this is the label on the back of my board: https://i.imgur.com/BrXilHP.jpg
I am currently using the spacebar from the keycap set i have on my GK64, so i think it should be the normal spacing :)
Offline thearctican
« Reply #3 on: Tue, 16 April 2019, 22:17:19 »
We'll sort it out.
If the space bar works on the other board, then you likely have a 2nd gen in which case most any gmk set will work. Most sets for that matter. The only oddball is the 1u super key on the left.
Offline Hemanse
« Reply #4 on: Wed, 17 April 2019, 12:43:44 »
We'll sort it out.
I ordered the set i linked, should work fine atleast. GMK sets are a bit out of my pricerange :) The only exception im making is if Skeletor comes back, i want that set.
Offline thearctican
« Reply #5 on: Wed, 17 April 2019, 12:53:05 »
We'll sort it out.
As long as you got the full kit you'll be fine ;)
