Author Topic: White French ISO Keycaps for Backlight  (Read 5705 times)
Offline Miirane
« on: Wed, 17 April 2019, 04:12:02 »
Hello there (General Kenobi ?)
So i'm here today because i'm looking for a full Keycaps set in White for my Razer Blackwidow Chroma first gen, but it's always QWERTY set, I can't find AZERTY set :(
I already email Maxkeyboard and WASD to ask if its possible to make it with the custom set but they can't do White keycaps with transparent letters for backlight...
I also saw a Ducky set but its not available in white now.
So that's why i'm here, if someone know where I can find it, even if its custom set, I can do the template etc
Thanks for your support and sorry if someone already asked it before.
Miirane.
Offline seville57
Re: White French ISO Keycaps for Backlight
« Reply #1 on: Wed, 17 April 2019, 08:23:41 »
Miirane.
If you even had found a White  Ducky keycaps set, they will not fit on your keyboard because razor chroma don't have a standard bottom row size, standard bottom row size = Ctrl, Win, Alt and FN/Menu is 1x1.25 and Spacebar is 1x6.25. 99% of the keycaps sets will not fit on your keyboard. The Ducky, Das row  in the link have a standard bottom row size.
http://www.maxkeyboard.com/mechanical-keycap-layout-and-size-chart.html
« Last Edit: Wed, 17 April 2019, 08:37:26 by seville57 »
Offline Miirane
« Reply #2 on: Wed, 17 April 2019, 08:32:55 »
Yes that's true, but it's really difficult to find a full compatible set so... I think its okay, the most important are all the other keys, i can repaint the bottom Ctrl, Alt, Spacebar etc
« Reply #3 on: Fri, 26 April 2019, 02:17:30 »
J'ai un set Ducky blanc AZERTY ABS Backlight jamais ouvert (ref. S9C8-S109-FRRADW) à ta dispo Miirane si tu cherches toujours.
PM moi si tu es intéressé(e).
