Author Topic: RSI vs keyboard height/angle adjustments  (Read 2847 times)
Offline macguy80
« on: Wed, 17 April 2019, 18:21:05 »
Am I correct in guessing that it is easier on my wrists to leave a keyboard flat when possible as opposed to using the feet on the keyboard (because they would cause me to have to bend my wrists more)?
Offline mounds
  • Builder of things and stuff
    • The Mounds Abides
Re: RSI vs keyboard height/angle adjustments
« Reply #1 on: Thu, 18 April 2019, 20:15:42 »
Most information I know of says yes.
Also probably good to peruse the ergo-centric sub board for more tips :)
I switched from mostly 5 degree / OEM profiles to preferring flat / XDA for heavy work use. RSI is mostly gone for me, using Colemak in conjunction with XDA and a zero-angled Planck.
Tada68 (Jailhouse Aristotles) / MiniVan (Jailhouse Aristotles) / Planck (Aristotles) / Teensy m0116 (Matias QC) / ALPS64 ('Pine' SKCM White) / Teensy NeXT Non-ADB (SKCM Cream) / ALPS HHKB (SKCM Orange)
Offline macguy80
« Reply #2 on: Fri, 19 April 2019, 01:52:08 »
Thanks, mounds, on a couple different levels. I didn't know about the ergo sub board, and I just so happen to have a set of XDA caps on order!
Offline kurplop
  • THE HERO WE DON'T DESERVE
« Reply #3 on: Fri, 19 April 2019, 06:53:56 »
The need for a neutral or negative tilt has everything to do with typing style and user orientation. If you’re a floater, with your hands not touching the keyboard except at the fingertips and with your body high enough to not encourage wrist extension, a positive tilt can be desirable. If you’re a planter, where you prefer your wrists or forearms anchored to palm rests, a tabletop, or chair armrests, then a neutral or negative tilt  is desirable. Avoiding excessive wrist extension is the goal.
