Author Topic: [please delete] IC moved  (Read 25443 times)
Offline AlcoholEnthusiast
Re: [IC] Kepler
« Reply #50 on: Sat, 20 April 2019, 02:32:42 »
Not a huge fan of TKL, but this looks pretty awesome. Agreed that bezels are a bit thick to me, but I definitely get the appeal. Interested to see what price is. The Lemo connector + Brass bottom can't come cheap. Either way, great design.
Offline Jaxxstatic
  • Haptic Recon
Re: [IC] Kepler
« Reply #51 on: Sat, 20 April 2019, 14:14:30 »
I think the bezels are another thing that sets it apart. I like them honestly
Offline iammeuru
Re: [IC] Kepler
« Reply #52 on: Sat, 20 April 2019, 15:08:14 »
I'm pretty interested as-is, however, I have a feeling that the bottom part is going to end up quite expensive to machine, and if you decided to simplify the the curves (especially around the lemo connector/rear bottom angle), it would become more affordable. I think this is a solid must have for me, so please give as much info as possible in advance so I can budget it in :)
It's a fantastic design.
Offline japanesehorrorwriter
Re: [IC] Kepler
« Reply #53 on: Sun, 21 April 2019, 02:37:13 »
This is it.
100%.
In.
As is. please keep the bottom all pvd....
Offline blawb
Re: [IC] Kepler
« Reply #54 on: Sun, 21 April 2019, 18:36:10 »
Good to see a second board implementing the true isolation methodology for mounting
Sent from my iPhone using Tapatalk Pro
What does this mean?
i hate wet socks
Offline Jae-3soteric
  • https://www.youtube.com/channel/UCAIHiFKJt69HNad6r
    • Jae | Top Clack
Re: [IC] Kepler
« Reply #55 on: Sun, 21 April 2019, 18:45:40 »
My personal board, the J-01 uses exactly this type of mounting as well. Build stream available on YouTube
Offline PotatoTM
Re: [IC] Kepler
« Reply #56 on: Sun, 21 April 2019, 19:23:33 »
Cool mounting style and connector, consider me interested!
Offline MajorKoos
  • 1 life please. Extra large.
Re: [IC] Kepler
« Reply #57 on: Sun, 21 April 2019, 20:02:02 »
I must have one.
Offline blawb
Re: [IC] Kepler
« Reply #58 on: Sun, 21 April 2019, 22:29:20 »
Cool stream. Was cool hearing about all the design decisions. Why do you prefer this method? I did a quick search but I didn't find much.
i hate wet socks
Re: [IC] Kepler
« Reply #59 on: Sun, 21 April 2019, 23:17:44 »
it sounds good but doesn't feel much better than any normal sandwich or top mount board
at least in my experience, i haven't used jae's board
    • Jae | Top Clack
Re: [IC] Kepler
« Reply #60 on: Mon, 22 April 2019, 02:46:58 »
Replying to all of you here.... so wall of text inbound.
It basically feels like a softer sandwich mount. The plate effectively is raised only be the nitrile rubber and penned in from above so it sits on a “skirt” of the gasket around the entire edge of the plate. This means it has some “give” - but is not what you see in terms of flex with other gasket materials.
The use of gaskets have two main aims and depending on the implementation you can bias it in one favour or the other, or create a balance (think front / rear break balancing on a car), with the two options being sound and flex.
This implementation is to heavily favour the sound element by removing any contact of the plate or pcb from the case. On top mount for example the plate can reverberate or vibrate from normal usage and have the sound transferred to the case. This can (but doesn’t always) cause case ping. The idea behind the isolation here is to remove that entirely, and therefore allow sound to be tuned better, whilst adding a small amount of flexibility where the plate rests on the skirt.
In essence it feels like a softened sandwich mount so it’s highly consistent across the board in terms of feel. It’s isolated from the case completely so all the sound you hear is the switch and plate and cap materials. Which then allow you to look at the sound itself.
The inside of the case then becomes a resonance chamber - like the internals of a guitar. You can change the internal shape of the case to change how the board sounds.
If you listen to the J-01 first proto, the sound is slightly higher pitched on the keys to the left and right due to the internal cut out of a chamber not expanding across the full 60% area. It’s tiny in terms of timbre change, but it’s there. For rev2 of the proto, I’ve expanded that chamber across so all keys will have the same sound as the alphas do in the video (or be much closer).
Hope that helps - happy to chat about this if anyone has any further questions.
Offline projectkeyboard
Re: [IC] Kepler (Update: prototype photos)
« Reply #61 on: Mon, 22 April 2019, 10:13:16 »
Second post updated with proto photos.
A few design changes were made after this prototype. Production units will resemble the images in the renders.
Offline ptiede
« Reply #62 on: Mon, 22 April 2019, 10:16:40 »
That's a heavy boye
Offline vonswoopington
« Reply #63 on: Mon, 22 April 2019, 11:10:30 »
wow that's heavy. any shots of it from the side and sitting on a table?
TGR 910 Polycarb | TGR Alice | TGR Unikorn | Lyn EM-7 | VE.A | Kyuu | E7-V1
Offline bball2
« Reply #64 on: Mon, 22 April 2019, 11:21:00 »
11 lbs woah
« Reply #65 on: Mon, 22 April 2019, 14:41:06 »
11 lbs woah
lighter than brass keycult no 1
« Reply #66 on: Mon, 22 April 2019, 14:41:35 »
proto photos further solidified that i don't like the bezels
but the design is ****ing sweet otherwise
seems... very expensive at it stands right now
