Author Topic: [IC] The Knight75 by Robotical  (Read 42526 times)
Offline Aznguyen316
Re: [IC] The Knight75 by Robotical
« Reply #50 on: Fri, 17 May 2019, 11:29:10 »
I like this for the F row not lined up with the num row.
Offline Koobaczech
  • Don't forget to smile :)
    • Pearlboards
« Reply #51 on: Sat, 18 May 2019, 14:07:18 »
Hurry up and make more already so I can get one!
Offline sctang
« Reply #52 on: Sun, 19 May 2019, 03:19:02 »
Whoah didn’t expect this to be UCF related when I opened it. Looks great so far, and only thing I wouldn’t mind is a PC version myself although you touched on that. I know the intent is to keep it simple, but you should definitely consider something like a styled lance, or mounted knight engraving (on the inside?) reminiscent of the old school logo. Will also echo a left blocker as others stated.
Good luck with the process and I’ll definitely be watching this as an alum
« Last Edit: Sun, 19 May 2019, 03:28:06 by sctang »
Offline famguy07
« Reply #53 on: Wed, 19 June 2019, 13:35:21 »
Hey, it's mid June, so I hope the marriage part of your timeline went well. Any updates on the other June items, like prototype V2, videos, or even GB? Thanks.
Offline rondg
« Reply #54 on: Wed, 03 July 2019, 21:37:05 »
Hopefully, this is still a thing and GB would run after August..  ;D
Offline EMC Labs
« Reply #55 on: Wed, 03 July 2019, 21:51:39 »
Looks good!
Offline badboy731
« Reply #56 on: Mon, 15 July 2019, 19:28:47 »
Very interested. Is this still happening?
E7-V1 | TGR Jane v2 CE | HBCP | GSKT-00 | Raine | AOS
Offline Delirious
« Reply #57 on: Fri, 19 July 2019, 07:01:30 »
Hey guys, last time I talked to Robotical, he made some changes to the interior of the case. These changes are determined by extensive daily use so they are for the better in term of consistency and comfort. And as of now he is waiting on the second round of prototypes. He will also update you guys on the changes soon. Meanwhile I just rebuilt my knight75 with vint blacks in 70g.
Here is the full album https://imgur.com/a/h3t9Ola
Offline rondg
« Reply #58 on: Fri, 19 July 2019, 08:01:37 »
Yes! It's still alive!!! ;D
Offline badboy731
« Reply #59 on: Sat, 20 July 2019, 02:57:13 »
Thank goodness I almost lost hope
Offline badboy731
« Reply #60 on: Tue, 13 August 2019, 14:45:46 »
Anyone out there 😔
Offline EMC Labs
« Reply #61 on: Sat, 17 August 2019, 09:27:09 »
What keycap set is the Knight75 using there?
Offline Delirious
« Reply #62 on: Sat, 17 August 2019, 10:42:14 »
GMK Demonic, Ultratec minicom and og Relegendables.
Offline breckstar
« Reply #63 on: Sat, 17 August 2019, 17:06:23 »
Looks good. Interested for sure if price is right.
Offline EMC Labs
« Reply #64 on: Sat, 17 August 2019, 19:58:58 »
Thank you!
« Last Edit: Sat, 17 August 2019, 20:06:25 by Nightcrawler »
Offline rondg
« Reply #65 on: Sat, 17 August 2019, 21:47:19 »
This is till happening, right? But maybe GB will be next year?
Offline EMC Labs
« Reply #66 on: Sun, 18 August 2019, 04:15:01 »
I was having a look at the Ultratec minicom, but couldn't find the model with the correct sublegends as seen on the Knight75. Do you know the exact model? Sorry for hassling.
Offline Robotical
« Reply #67 on: Sun, 18 August 2019, 09:28:19 »
Update time!
I want to first apologize for the delay and I really am appreciative of those with ongoing interest in the project. The project is moving once again after I had to take a bit of a hiatus for various life stuff. In the mean time I finished up my revisions. Manufacturing of the second case prototype is completed and is in my hands! Maarten is working on the PCB design revisions and the pcb prototypes will be ordered as soon as he is finished them up. Final details on that will follow.
First up, let's cover the main changes that you may or may not see.
PCB/Plate Revisions:
  • Plate is still undergoing some fine tuning, so what you see in the prototype may or may not be one of the final plates available. I want to be accommodating as possible with the plate without compromising the feel of the plate.
  • PCB layout support can be seen below
Case Revisions:
  • Inner fillet increased slightly
  • Top round increased slightly
  • Bottom to Top Case fasteners moved inwards and enclosed
  • Side curvature profile raised by 2mm allowing for a bit more grip when lifting
  • WKL variant added
Weight Changes
  • Interior weight design adjusted to fit in case better
  • Interior weight depth changed from 3mm to 4mm to maintain original weight
  • Interior weight fasteners changed from 2 to 4 screws
  • Internal weight sandblasted finish because its not visible
Here are some pics of the new wkl prototype:
Better pictures will follow once I build this thing up with the new pcb.
Once again, thanks for the continue interest.
I believe it is the Ultratech Minicom IV, you can find a few on ebay.
Offline badboy731
« Reply #68 on: Sun, 18 August 2019, 12:06:08 »
I’m so glad I didn’t give up hope. Looking great
Offline beekey
« Reply #69 on: Sun, 18 August 2019, 12:17:08 »
Looks great. Might be my first 75%, and I hope the split space support stays.
Offline EMC Labs
« Reply #70 on: Sun, 18 August 2019, 17:51:19 »
WKL prototype looks amazing! Can't wait for GB.
I found the right Ultratec minicom, thank you!
« Last Edit: Sun, 18 August 2019, 17:55:19 by Nightcrawler »
Offline rondg
« Reply #71 on: Sun, 18 August 2019, 22:47:01 »
I assume that there will be different top options because of the layout options?
The board looks great!  ;D
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #72 on: Thu, 29 August 2019, 00:50:09 »
Still suuuper excited. Now that I've messed with Alps a bit that's definitely what I will be shooting for with this board. Thanks again for the updates and I look forward to the GB!  ;D Also grats on the marriage!
« Last Edit: Thu, 29 August 2019, 00:54:44 by Kokaloo »
Offline zantetsuken9000
« Reply #73 on: Thu, 29 August 2019, 02:12:18 »
Very keen on this board as my first 75%. Looks great!
KBD67 - Zealios 67g - GMK Bento
Offline guzzi
« Reply #74 on: Thu, 29 August 2019, 04:10:35 »
Since this seems to going to be an unlimited GB, I assume extra PCBs and plates will be available?
The new Hiney IC on the Alps caps got me thinking about getting two to switch between an MX and an Alps build.
Offline Robotical
« Reply #75 on: Thu, 29 August 2019, 06:04:22 »
I am going to have an option to purchase extra plates and PCBs for those that would be interested in doing so. Plate files will also be available if you want to go try out a material not offered.
Offline EMC Labs
« Reply #76 on: Thu, 29 August 2019, 07:15:11 »
Great to hear, very excited for this GB.  :thumb:
Offline rondg
« Reply #77 on: Thu, 29 August 2019, 08:00:38 »
Same! Excited for this. I just hope GB runs are spread out.
Offline YellowHalo
  • See You Starside
« Reply #78 on: Thu, 29 August 2019, 19:56:12 »
Is it too late to suggest one in yellow?
Offline Robotical
« Reply #79 on: Fri, 30 August 2019, 07:47:34 »
I am sorry, but yellow will not be an available option.
Offline lush_bunny
« Reply #80 on: Fri, 30 August 2019, 08:38:10 »
This is a very sexy board. Do you have a target price OP?
Offline EMC Labs
« Reply #81 on: Fri, 30 August 2019, 08:51:50 »
I highly encourage you to refrain from using such language, or not.  :blank:
Offline jrs
« Reply #82 on: Fri, 30 August 2019, 13:46:26 »
Does the Alps plate support MX style stabilizers?  Some Alps keycap sets use MX stabilizers.
Offline Robotical
« Reply #83 on: Wed, 04 September 2019, 10:58:55 »
Are you referring to the upcoming Hineybush WoB dsc for alps or the Alpines Winter set from a while back? The plate files will be open source so that can be included that in the published plate files. Please note there are 2 restrictions:
1. Support pcb mount MX stabs only
2. Support caps made by SP only. DOES NOT support OG caps, those caps have different spacing than mx standard anyway so they wont fit in the first place.
Offline _swagfrog
« Reply #84 on: Tue, 22 October 2019, 20:51:51 »
Nice! I was looking for a 75% like this.
Offline jani80k
  • In the hobby for a good time.
« Reply #85 on: Fri, 25 October 2019, 04:12:00 »
I am very interested in this board. There are sadly not many 75% boards with ISO support at the moment.
I would be super happy if we could make the typing feeling somewhat forgiving... not totally flexy like plateless but not too stiff either.
Offline kaisn
« Reply #86 on: Sat, 26 October 2019, 09:20:09 »
I'm also very interested.
ISO, split L-Shift, full R-shift is not often found around here  :p
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #87 on: Sat, 26 October 2019, 10:21:12 »
IC filled out, huge +1 for the ALPS support!
Offline Robosculpts
« Reply #88 on: Sun, 03 November 2019, 10:47:20 »
Oh man I'm in 75% heaven with this, the 7V, and Dawn.
