Author Topic: Recommend my a keyboard & store  (Read 1099 times)
Offline Ollum
« on: Tue, 28 June 2011, 15:21:58 »
Have u tried this one?
http://www.keyboardco.com/
EDIT: I found my keyboard and my store I just had 2 read and look some things in google up
EDIT2: I can confirm that keyboardco.com has the keyboards u want http://www.keyboardco.com/keyboard_search.asp?SG=10031 for example or tis one http://www.keyboardco.com/keyboard_search.asp?SG=10038
« Last Edit: Tue, 28 June 2011, 15:26:11 by Ollum »
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Recommend my a keyboard & store
« Reply #1 on: Tue, 28 June 2011, 15:34:58 »
You could get a Leopold from Leopold Japan for approximately $130 shipped that meets all of your requirements. Another option would be to look at whats available on PCHome. Of course there is our classifieds too. You may find a seller that has what you are looking for that will ship to Sweden. If all that fails you've got TaoBao.
Offline arc2
« Reply #2 on: Tue, 28 June 2011, 15:40:39 »
If you are looking for ANSI, tactile, clicky and TKL surely this is a good match ... http://www.keyboardco.com/keyboard_details.asp?PRODUCT=835
Just one in stock, quick!!!
« Last Edit: Tue, 28 June 2011, 15:42:45 by arc2 »
Offline Orteko
« Reply #3 on: Wed, 29 June 2011, 04:43:10 »
I may as well piggy-back on this thread and ask a similar question :)
Looking for a full-size brown or red switch keyboard but i'm having no luck finding one with either no windows/menu keys (not likely I know) or at least smaller (alphanumeric size) windows/menu keys.
The closest i've found has been the XArmor U9BL-S but i've heard some concerns about the build quality - Not really bothered if it has usb ports/media keys/backlighting or not.
Essentially what I want is a Filco with the smaller keys - anyone know of anything like this? Any insider info on if the upcoming full-size Leopolds will have this layout style?
