Author Topic: Spots of rust on the board  (Read 2061 times)
Offline lanox
« on: Sat, 27 April 2019, 22:53:52 »
Hi,
I am sure this has been asked before, however I couldn’t  t find answer. I have fc660c and topre 87u, today I decided to give them a nice complete clean, upon removing the keycap I noticed there is few rust spots on both keyboards. I was wondering is there anything I  could do to prevent it from happening more ? Also should I do something about it or not to worry ?
Thanks
Offline lanox
Re: Spots of rust on the board
« Reply #1 on: Mon, 29 April 2019, 00:59:25 »
Anyone ?
Offline Coreda
« Reply #2 on: Mon, 29 April 2019, 01:13:33 »
Oil can help with preventing corrosion. Would want to avoid getting it on the PCB though, probably. Maybe others who've encountered this with keyboards specifically have some thoughts.
Offline Riverman
« Reply #3 on: Mon, 29 April 2019, 10:54:17 »
I had a Filco that had a few small rust spots on the metal plate.  I sanded the rust off with a spot sanding pen and touched up the bare spots up with some automotive touch-up paint I had lying around.  The sanding pen I used is a 3M product that has very small fiberglass bristles, but I've seen the same thing for sale at Harbor Freight.  It's pretty cool for sanding precise things.
Offline lanox
« Reply #4 on: Mon, 29 April 2019, 19:44:33 »
Thanks, will have a look in to it.
