Author Topic: SA profile Keycap Set  (Read 4420 times)
Offline tedfs3
    • No Mercy Given
« on: Sun, 28 April 2019, 06:04:57 »
I've copied a PCB design as best as possible from user [null] here: https://geekhack.org/index.php?topic=97883.0
Mine has moved the numpad to the left side using KiCad here: https://github.com/Tedfs3/104LH_v3.3 I'm very interested in checking out an SA profile keycap set to use with the switches I've purchased but have no idea if there is a complete, 104 key set out there to try with a 6.25u Space. Neutral or retro colors are preferred, something like the SA Restor set, however that has a 6.0u Space and I need a 6.25u Space. Could change the design if needed but so many hours have gone into this already that finding a keycap set that fits out of the box would be a plus. Not a deal breaker on redesign but would like to avoid it if possible.
Any suggestions or recommendations on the unit layout pictured below ?
218123-0
Offline garbo
Re: SA profile Keycap Set
« Reply #1 on: Sun, 28 April 2019, 07:46:16 »
In terms of keycap coverage your layout is about as basic as it gets. I don't think there's a single SA set without a 6.25u spacebar (some might include additional 6u spaces, but only fairly exotic boards would need one).
Offline tedfs3
    • No Mercy Given
« Reply #2 on: Sun, 28 April 2019, 16:21:02 »
Well, I found a set that I liked but it has a 3u, 6u and 7u spacebar options. That's why I was wondering.
Offline garbo
« Reply #3 on: Mon, 29 April 2019, 04:09:00 »
I'm assuming you're talking about SA restor, since that's in the first post.
Kbdfans didn't made it very clear, but the image you're getting those spacebar sizes from only shows what would be an extras/extended kit, with less common key sizes. The 6.25u space is included with the alphas, instead.
