Author Topic: [IC] MT3 Serika | IS LIVE! ORDERS CLOSE ON 08/30/19 11:59 PDT  (Read 409928 times)
Offline Zambumon
  • discord.zambumon.com
    • Keyset projects
Re: [IC] MT3 Serika | Launching In August On Drop
« Reply #600 on: Thu, 25 July 2019, 18:08:13 »
Is there any possibility of adding more R5 keys in one of the kits?
R4 is way too steep if you primary hit bottom row modifiers with your thumbs, as is the case for most ortho boards.
Currently the only offering with any R5 is the ergo set, but it only includes 8.
Already addressed this, no plans for more R5 (with the exception of the spacebars when R4C is not available)
I would appreciate it if you could reconsider the R4 keys for ortho layout to be R5. I understand this can be a hard call on which key should go where, but for thumb keys, R4 is not comfortable without a 7 degree incline.
Edit: Looking at it again, the four bottom rows of displayed keys could be changed to R5 and it would be a win overall, unless I'm missing something and 40% users do want double R4.
MT3 was designed to be used with modern keyboards, which typically have a 5 to 7 degree inclination.  And the caps will be indeed uncomfortable if used with flat boards.
I won't be changing the modifier keys for any of the kits, and it is not consistent to swap them for one kit (40%) while keeping them for the rest, and I find that R4 is as comfortable on a 40% as it is on a TKL.
Offline harlekein
« Reply #601 on: Fri, 26 July 2019, 03:59:46 »
Just wanted to make note that I am currently typing on MT3 Godspeed with a slight decline instead of incline and it's very comfortable with R5 thumb keys.
From the source you linked, by Matt3o:
> If you instead like dead flat keyboards, the set won’t be any worse than –say– SA anyway.
Again, it's your call, but I don't think you should be flat out stating that MT3 is inherently uncomfortable for any keyboard without an incline, because me and other ortho users are finding it a comfortable profile on flat or keyboards with a negative tilt. Just not with R4 thumb keys.
Offline Zambumon
    • Keyset projects
« Reply #602 on: Fri, 26 July 2019, 04:22:57 »
I've already stated my position and made up my mind regarding row 5 keycaps, and I think it is clear that changing the kits and the row profile for just ortholinear keyboards is not going to happen.
In my reply I cited Matt3o mentioning that the profile was designed to be used with keyboards with an inclination, and then I pointed out my experience with MT3 and flat keyboards: I find it uncomfortable. If I can't state that MT3 is indeed uncomfortable with flat keyboards, then we can't do the opposite.
Offline walie
« Reply #603 on: Fri, 26 July 2019, 08:57:21 »
On the flip side, I can't type on MT3 without a positive tilt, hated it flat. So R4 bottom row works for me.
Offline spooknik
« Reply #604 on: Mon, 29 July 2019, 13:12:00 »
I know this is using a custom font, but do you think the mods would look good with /dev/tty alphas?
Offline jooobe
« Reply #605 on: Mon, 29 July 2019, 15:55:05 »
August is gonna be wild
Sent from my SM-N960F using Tapatalk
Offline Surefoot
« Reply #606 on: Mon, 29 July 2019, 23:50:24 »
From the OP post..
MT3 Serika features Audacia, a bespoke typeface that is inspired by IBM beamspring terminals and Olivetti typewriters
So i suppose that the answer is "no"...
Offline kgorin
  • Formerly aka_gk
« Reply #607 on: Tue, 30 July 2019, 07:03:59 »
Is start date still Aug 1st? I see all mentions of the 1st were removed, now it's just August
Offline Zambumon
    • Keyset projects
« Reply #608 on: Tue, 30 July 2019, 16:04:29 »
I have never said or mention "August 1st" but just "August"
Offline Zambumon
    • Keyset projects
« Reply #609 on: Tue, 30 July 2019, 16:06:15 »
Doesn't make sense to me to use one font for the alphas and another one for the modifiers. It would be jarring.
Offline easy_rider
« Reply #610 on: Wed, 31 July 2019, 05:57:06 »
Any reason why the i18l kit doesn't have the brackets etc. for Alt-Gr modifiers? The japanese alphas do have the "third" legend on the keys, so it's not a matter of space nor aesthetics. Personally I feel like it kind of misses the point if the brackets and squiggly braces etc. are not there.
Offline Oblotzky
  • Backspace is for people that make mistakes.
« Reply #611 on: Wed, 31 July 2019, 08:44:57 »
Can you add a Blank Cadet Alphas kit please?
Offline Zambumon
    • Keyset projects
« Reply #612 on: Wed, 31 July 2019, 10:12:57 »
No
Offline Zambumon
    • Keyset projects
« Reply #613 on: Wed, 31 July 2019, 10:14:03 »
Any reason why the international kit doesn't have the brackets etc. for Alt-Gr modifiers? The japanese alphas do have the "third" legend on the keys, so it's not a matter of space nor aesthetics. Personally I feel like it kind of misses the point if the brackets and squiggly braces etc. are not there.
The kit doesn't have Alt Gr legends otherwise it would almost double its size.
Offline floatingbear
« Reply #614 on: Wed, 31 July 2019, 11:56:10 »
nice, nice  ;D
Offline easy_rider
« Reply #615 on: Thu, 01 August 2019, 03:22:47 »
Ah makes sense. A shame though.  :thumb:
Offline jooobe
« Reply #616 on: Thu, 01 August 2019, 06:00:34 »
Ooof just got gmk 8008, tell me when I can give you my money
Offline jani80k
  • In the hobby for a good time.
« Reply #617 on: Thu, 01 August 2019, 08:23:02 »
Wow, this set is really nice.
Offline Zambumon
    • Keyset projects
« Reply #618 on: Thu, 01 August 2019, 12:59:16 »
IMMINENT
Offline Zambumon
    • Keyset projects
« Reply #619 on: Thu, 01 August 2019, 12:59:44 »
<quote snipped>
No.
« Last Edit: Mon, 12 July 2021, 13:48:14 by HoffmanMyster »
Offline AlcoholEnthusiast
« Reply #620 on: Thu, 01 August 2019, 13:14:08 »
When is this going live?
Offline eksuen
  • Ambassador of explosions.
« Reply #621 on: Thu, 01 August 2019, 13:22:46 »
Prelaunch today. Live on Monday, 8/5.
Offline jooobe
« Reply #622 on: Thu, 01 August 2019, 14:01:01 »
Nice, either way I'm eating 99 cents ramen for a month
Offline Zambumon
    • Keyset projects
Offline OkKarma
Re: [IC] MT3 Serika | Launching Goes Live on August 5
« Reply #624 on: Thu, 01 August 2019, 15:46:05 »
Zambumon, did we ever get an answer on the concave 2U spacebar?
Offline forevermadrigal
« Reply #625 on: Thu, 01 August 2019, 16:14:09 »
That pricing is bonkers, how can you say no?
Offline Zambumon
    • Keyset projects
« Reply #626 on: Thu, 01 August 2019, 16:23:18 »
No paying would be a good start.
Offline Zambumon
    • Keyset projects
« Reply #627 on: Thu, 01 August 2019, 16:23:45 »
Concave R4 2.00U will be used
Offline kmicu
« Reply #628 on: Fri, 02 August 2019, 10:54:35 »
Hi Drop person. Is there any chance to move some units to EU stock for EU shipping pretty please? 🙏
Offline hottrout
  • I'd Hit Dat Key
« Reply #629 on: Fri, 02 August 2019, 12:03:45 »
Fantastic prices.  So looking forward to this kit.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline eksuen
« Reply #630 on: Fri, 02 August 2019, 12:10:59 »
Sorry, not for this product.
« Reply #631 on: Fri, 02 August 2019, 14:11:04 »
Yeah prices are solid. Especially with the breaks that I am guessing will get it. I'm feeling pretty good about final price for what I want in the 115-125 range which is great for the number of kits and keys I am interested in.
Offline jooobe
« Reply #632 on: Fri, 02 August 2019, 16:53:32 »
Where are y'all even seeing the prices
Offline Zambumon
    • Keyset projects
« Reply #633 on: Fri, 02 August 2019, 17:10:16 »
Offline Zambumon
    • Keyset projects
« Reply #634 on: Fri, 02 August 2019, 17:10:52 »
That was my goal.
Offline mellen
« Reply #635 on: Fri, 02 August 2019, 17:33:53 »
wish the text arrows was the separate kit and the base was with icon arrows, but it's fine it's not that much cost extra and I'm sure there is a good reason
Offline jooobe
« Reply #636 on: Fri, 02 August 2019, 19:21:57 »
Oh I see the charts now, so will people get price difference refunded after the price drop? Just wondering
« Last Edit: Fri, 02 August 2019, 19:53:46 by jooobe »
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #637 on: Fri, 02 August 2019, 21:42:59 »
You will be charged as soon as the GB ends, no sooner.  Note that there may be complications if you use PayPal, see Drop's explanation.
If you didn't see them yet, you might find these price graphs interesting.
Offline jooobe
« Reply #638 on: Fri, 02 August 2019, 22:45:12 »
Thank you sir, you are gentleman and a scholar
Offline kmicu
« Reply #639 on: Sat, 03 August 2019, 05:35:50 »
Anyone familiar with customs duties for folks from EU? How much of additional costs should I assume for ~120$ of MT3 Serika keycaps?
Any hints or pointers appreciated.
Offline Oblotzky
« Reply #640 on: Sat, 03 August 2019, 05:47:04 »
Different per country.
VAT (e.g. 19% in Germany, 20% in UK) + processing fees (very different from country to country)
Offline Zambumon
    • Keyset projects
« Reply #641 on: Sat, 03 August 2019, 10:25:03 »
Regarding PayPal: I cannot recommend using PayPal for keycap drops. If you want to use Paypal, do not modify your order. Cancel it and place a new one.
Price drops could also cause issues with PayPal.
Offline jooobe
« Reply #642 on: Sat, 03 August 2019, 10:53:28 »
Ok, will use card straight up
Offline mellen
« Reply #643 on: Sat, 03 August 2019, 15:09:36 »
is it frowned upon to not get the sublegends (katakana)? kinda like WK is frowned upon when WKL is an option?
« Reply #644 on: Sat, 03 August 2019, 15:43:35 »
Not at all. I'm getting just Latin.
Offline Possumx
« Reply #645 on: Sat, 03 August 2019, 19:41:40 »
Good to know guess ill use my CC aswell
« Reply #646 on: Sun, 04 August 2019, 00:55:50 »
Nah man, get whatever looks best to you.
Offline Zambumon
    • Keyset projects
« Reply #647 on: Sun, 04 August 2019, 04:32:19 »
The set was designed so you could get either of those.
Offline OkKarma
« Reply #648 on: Sun, 04 August 2019, 16:09:18 »
The 4U spacebar, does it have 4 stems?
Offline Zambumon
    • Keyset projects
« Reply #649 on: Sun, 04 August 2019, 18:15:58 »
I don't have a 4.00 spacebar at the moment, I will try to check tomorrow afternoon.
