Author Topic: [IC] GMK Delta  (Read 55420 times)
Offline upas
Re: [IC] GMK Delta
« Reply #100 on: Mon, 26 August 2019, 21:17:53 »
I'm pretty sure I'm going to stick with the CR base color for the mods.
How do you guys feel about this deskmat design?
Offline eskimojo
    • KeycapLendar
Re: [IC] GMK Delta
« Reply #101 on: Mon, 26 August 2019, 22:17:45 »
Gorgeous  :D
Offline gautema
Re: [IC] GMK Delta
« Reply #102 on: Tue, 27 August 2019, 01:22:25 »
I love it.
Offline v4rg
Re: [IC] GMK Delta
« Reply #103 on: Tue, 27 August 2019, 01:34:28 »
This is absolutely gorgeous
Gesendet von meinem EVA-L09 mit Tapatalk
Offline Kawamashi
Re: [IC] GMK Delta
« Reply #104 on: Tue, 27 August 2019, 04:56:44 »
Oof !
Offline MdotMaxson
Re: [IC] GMK Delta
« Reply #105 on: Tue, 27 August 2019, 07:34:11 »
Sorry to double post. The original poster had said something like “stay tuned “ when I asked about ortho. Is ortho a possibility?
Offline moonux
Re: [IC] GMK Delta
« Reply #106 on: Tue, 27 August 2019, 17:17:32 »
I favor the black mods too, hope that's happening.
Sent from my SM-G975U1 using Tapatalk
Offline upas
Re: [IC] GMK Delta
« Reply #107 on: Tue, 27 August 2019, 17:59:58 »
This spacebar kit should have ortho compatibility:
Let me know if something is missing
I think most feedback has been neutral or positive, so we will go with it.
Offline MdotMaxson
Re: [IC] GMK Delta
« Reply #108 on: Wed, 28 August 2019, 00:21:42 »
Thank you!!!
Offline MdotMaxson
Re: [IC] GMK Delta
« Reply #109 on: Wed, 28 August 2019, 00:24:29 »
A mod colored ‘ and \ wouldn’t hurt but now I’m just being picky. I’m thankful the data out enter and shift made it in space bars. I will be purchasing a few to help with moq
Offline upas
Re: [IC] GMK Delta
« Reply #110 on: Thu, 29 August 2019, 13:09:33 »
Hey guys, just a quick update:
I talked to GMK, they've already color matched SP's VBV in the past. It's the same teal used on the original SA Hyperfuse.
https://matrixzj.github.io/docs/sa-keycaps/HyperFuse/
It's also been used in Hyperfuse Origins
https://matrixzj.github.io/docs/gmk-keycaps/HyperFuse-Origins/
and in Hyperfuse Remix
https://matrixzj.github.io/docs/gmk-keycaps/HyperFuse-Remix/
If you're curious about the color, doing a search on r/mk for any of those will show you what the teal will look like. It will look a bit different when put against the black CR. Context matters when it comes to color. It's a nice bright teal, and should really pop, and provide an awesome accent color as well.
This is great, because it means this set won't have to spend time doing many rounds of color matching. The colors have already been matched!
« Last Edit: Thu, 29 August 2019, 13:13:19 by upas »
Offline nasp
Re: [IC] GMK Delta
« Reply #111 on: Thu, 29 August 2019, 13:12:14 »
Thanks for including ortho! It's perfect!
Offline ymaaan
Re: [IC] GMK Delta
« Reply #112 on: Sun, 08 September 2019, 04:28:12 »
Any update on this one?
Offline upas
Re: [IC] GMK Delta
« Reply #113 on: Sun, 08 September 2019, 07:41:03 »
There are still the two kits, and we still plan on running in November.
Base
Spacebar Extension Kit
The colors will be CR, WS2, and VBV from SP (which is the same as the hyperfuse origins color)
Offline leexy
Re: [IC] GMK Delta
« Reply #114 on: Sun, 08 September 2019, 10:16:31 »
so...gmk tokyo days?
Offline ymaaan
Re: [IC] GMK Delta
« Reply #115 on: Sun, 08 September 2019, 20:06:32 »
Base
Oh okay thanks! How about the prices? Are there already an estimate on how much they will cost?
Offline upas
Re: [IC] GMK Delta
« Reply #116 on: Tue, 10 September 2019, 21:40:57 »
Base
No prices yet - still deciding on a few final things with the kits, then will submit for quotation!
