Author Topic: [IC] GMK Ashes [2/25 Basalt Kit Added Back] (GB starts March 2nd)  (Read 202835 times)
Offline Tyson
« on: Fri, 06 September 2019, 22:44:00 »
Hello Geekhack!
Group Buy / Vendors
Group Buy Starts March 2nd, 2020 - March 31st, 2020
This is my first Interest Check for a keyset, GMK Ashes, A volcanic ash set with soft colors.
Oceania: DailyClack
Asia: iLumkb
GB thread is up, further discussion on the set can be found here: https://geekhack.org/index.php?topic=104895.0
Keyset Pricing
NA [ProjectKeyboards] (USD)
Base Kit- $130.00
Ghost Kit- $66.00
Novelties Kit- $38.00
40s Kit - $35.00
Spacebars Kit- $32.00
EU [MyKeyboard] (EUR)
Base Kit- €139,00
Ghost Kit- €69,00
Novelties Kit- €39,00
40s Kit - TBD
Spacebars Kit- €33,00
ASIA [iLumKB] (SGD)
Base Kit- $181.00
Ghost Kit- $92.00
Novelties Kit- $53.00
40s Kit - TBD
Spacebars Kit- $45.00
Oceania [DailyClack] (AUD)
Base Kit- $194.00
Ghost Kit- $99.00
Novelties Kit- $57.00
40s Kit - TBD
Spacebars Kit- $48.00
Design & Inspiration
This idea originally began as a dark keyset, I was working with a lot of dark gray and red pantone colors, after rethinking what I was trying to achieve I decided to look at other keysets to get ideas, I decided to try to invert the colors similar to GMK Honeywell to test out that idea and really liked the look of it. I threw out the red because it just didn't fit in well with the set but kept the gray colors. Then I started messing with more with different shades of gray and came to love the final result of colors!
I present to you GMK Ashes:
Kit Design
Ashes Kit
Support standard layouts, basic ISO Support, Full Size, TKLs, 75s, 65s, WKL boards etc!
Ghost Kit
Mod Colored Alphas, with basic ISO support and standard layout support when combined with Base Kit.
Caldera Kit
Accent - Novelties Kit.
Basalt Kit
40s - UK-ISO - Extension Kit.
Lahar Kit
Spacebars - Alice Support Kit.
Deskpads
Adventure Deskpad
Ghost Deskpad
Artisan Collaboration:
Custom Cables by SpaceCables
  • Both Cables will be the same length and Color, only difference is going to be connector type
  • Type C Cable: 4ft, Coil v3, Dark Grey front half with coil/Light Grey Back half
  • Mini B Cable: 4ft, Coil v3, Dark Grey front half with coil/Light Grey Back half
Artwork for GMK Ashes by @hiki_draws on instagram
Thanks
Many thanks to the following for your help and support during the design of this set:
BlindAssassin111 for feedback and support on the set guiding me on how to make an IC!
OneFiveNine for giving me ideas on what to theme the set after, running the set and helping me out with the set!
The Texas Mechanical Keyboard Discord for all the feedback and support everyone has given me in there!
MetallicCharles for helping me out with these amazing renders of the set! (More renders on the way by him and other renders in the community!)
UndercoverBrother for the sick render of the Kepler FC65!
HamKenobi, DixieMech, Kristmascane, Koriko, Erin and Gus along with others from the Houston Discord for being there for me for these past two years!
N E Renders Avail?
Full Album with more renders!
Next Steps
Add more renders
Get a feedback form added [Feedback has been great! I have been reading every single message everyone has been sending me in the form! Thank you!]
Deskmat designs being worked on currently.
Adjust kits
Talk to Artisan Makers about making custom cw artisans for the keyset
Speak with Cable Vendor to supply custom cw cables for the keyset
Set a date for the GB (Q1 2020)
Wait for GB to start on March 2nd!
Check for Updates on my Discord
If you want to support this project, please consider adding the following to your signature:
Code: [Select]
[url=https://geekhack.org/index.php?topic=102338.0][img]https://i.imgur.com/9JrH2n9.png[/img][/url]
« Last Edit: Fri, 28 February 2020, 20:17:39 by Tyson »
Offline DuellM
  • Keyboard Fatty
Re: [IC] GMK Ashes
« Reply #1 on: Fri, 06 September 2019, 22:51:09 »
Nice!! So many nice sets coming
Sent from my Pixel 3a using Tapatalk
Offline Georgeotj
Re: [IC] GMK Ashes
« Reply #2 on: Fri, 06 September 2019, 22:53:45 »
Insta buy for me 😍
Offline ymaaan
Re: [IC] GMK Ashes
« Reply #3 on: Fri, 06 September 2019, 22:55:25 »
insta cop
Offline HarutoHiroki
Re: [IC] GMK Ashes
« Reply #4 on: Fri, 06 September 2019, 22:58:05 »
Looks very nice. Interested!
Offline mrkantz
Re: [IC] GMK Ashes
« Reply #5 on: Fri, 06 September 2019, 23:05:26 »
Definitely interested, looks great
Offline IOVERCALLHISTIOCYTES
Re: [IC] GMK Ashes
« Reply #6 on: Fri, 06 September 2019, 23:06:36 »
Rama volcano cap?
Like it. There once was a set that appears dead called Achromatic, and this scratches the same sort of itch. Hope to see more.
Offline kema
  • Designer
    • kevinmadesign
Re: [IC] GMK Ashes
« Reply #7 on: Fri, 06 September 2019, 23:10:10 »
Looks great with the function row dark grey/black accent!
Offline bthezebra
Re: [IC] GMK Ashes
« Reply #8 on: Fri, 06 September 2019, 23:19:14 »
Do like nice job!
Offline scoopbb
Re: [IC] GMK Ashes
« Reply #9 on: Fri, 06 September 2019, 23:54:10 »
pictures show up as broken links for me
Offline Mcnos
    • GMK Fuyu
Re: [IC] GMK Ashes
« Reply #10 on: Sat, 07 September 2019, 00:00:53 »
You know I like gray.
You considering doing a white alpha base as well?
Offline BlindAssassin111
  • I design keyboards and stuff.
    • Viktus
Re: [IC] GMK Ashes
« Reply #11 on: Sat, 07 September 2019, 00:01:31 »
I think that is on your end, I have had that issue before but not sure how to solve...
Offline holysht_itschris
Re: [IC] GMK Ashes
« Reply #12 on: Sat, 07 September 2019, 00:15:43 »
Beautiful set. Can't wait!
Offline Dead Encryption
  • Dead...
    • Twitch Channel
Re: [IC] GMK Ashes
« Reply #13 on: Sat, 07 September 2019, 00:31:00 »
Count me in boi!!!!
Offline DuellM
  • Keyboard Fatty
Re: [IC] GMK Ashes
« Reply #14 on: Sat, 07 September 2019, 00:34:07 »
Would love to see a render of this on a white keyboard
Offline scoopbb
Re: [IC] GMK Ashes
« Reply #15 on: Sat, 07 September 2019, 00:43:29 »
could it be that im not part of that discord server or something since they are discord links?
Offline japanesehorrorwriter
Re: [IC] GMK Ashes
« Reply #16 on: Sat, 07 September 2019, 00:56:36 »
I am so down for this.
Will look great against a ton of colors.
Offline DetectiveNio
Re: [IC] GMK Ashes
« Reply #17 on: Sat, 07 September 2019, 01:01:53 »
I need this to complete the theme for my Volcano660
Offline Tyson
Re: [IC] GMK Ashes
« Reply #18 on: Sat, 07 September 2019, 01:41:02 »
It could be that Discord is blocked on your network. I suggest trying on a different network.
Offline Tyson
Re: [IC] GMK Ashes
« Reply #19 on: Sat, 07 September 2019, 01:42:52 »
Added White OSA renders to the IC. :)
Offline steezkeez
Re: [IC] GMK Ashes
« Reply #20 on: Sat, 07 September 2019, 03:13:35 »
Very nice!
Offline vicissitude
Re: [IC] GMK Ashes
« Reply #21 on: Sat, 07 September 2019, 07:10:07 »
nice.
I love this idea.
Offline jooobe
Re: [IC] GMK Ashes
« Reply #22 on: Sat, 07 September 2019, 08:12:33 »
Yes I like it 10/10 would get
Sent from my SM-N960F using Tapatalk
« Last Edit: Sat, 07 September 2019, 08:44:19 by jooobe »
Offline onefivenine
    • Project Keyboard LLC
Re: [IC] GMK Ashes
« Reply #23 on: Sat, 07 September 2019, 09:20:57 »
Offline stoic-lemon
Re: [IC] GMK Ashes
« Reply #24 on: Sat, 07 September 2019, 09:31:28 »
This is greyt.
Offline break
Re: [IC] GMK Ashes
« Reply #25 on: Sat, 07 September 2019, 09:34:14 »
Love this - matches a lot of boards, mods look almost blue-gray, all-white would be amazing on e-white. Looking forward to more.
Offline scoopbb
Re: [IC] GMK Ashes
« Reply #26 on: Sat, 07 September 2019, 10:03:32 »
its def not blocked. im in a bunch of discord servers and the app/ every other thread works fine and displays. super weird
Offline Jonny_Lopez
Re: [IC] GMK Ashes
« Reply #27 on: Sat, 07 September 2019, 10:46:34 »
I really like this design <3
Offline AlcoholEnthusiast
Re: [IC] GMK Ashes
« Reply #28 on: Sat, 07 September 2019, 10:51:25 »
Weird, pictures showing up broken for me too.
Offline phunktional
Re: [IC] GMK Ashes
« Reply #29 on: Sat, 07 September 2019, 11:04:49 »
The images are currently hosted on Discord's CDN. They should probably be moved somewhere else.
Offline pixelpusher
Re: [IC] GMK Ashes
« Reply #30 on: Sat, 07 September 2019, 11:05:20 »
I like it a lot.  Looks like Zambumon is doing the reverse too
https://www.instagram.com/p/B2AMnAIo7UL/?utm_source=ig_web_button_share_sheet
« Last Edit: Sat, 07 September 2019, 11:09:43 by pixelpusher »
Re: [IC] GMK Ashes
« Reply #31 on: Sat, 07 September 2019, 11:18:13 »
Doesn't Zambumon's set have a bit of green in it?
Offline pixelpusher
Re: [IC] GMK Ashes
« Reply #32 on: Sat, 07 September 2019, 11:31:05 »
I mean, they are quite different but still in the same vein. Zeitgeist
Offline ossetepo
Re: [IC] GMK Ashes
« Reply #33 on: Sat, 07 September 2019, 11:50:08 »
The base is nice.  The ghost kit is amazing.  Really hope this runs!
Offline Tyson
Re: [IC] GMK Ashes
« Reply #34 on: Sat, 07 September 2019, 12:41:45 »
Just moved all the photos to an Imgur album!
« Last Edit: Sat, 07 September 2019, 13:21:02 by tyson522 »
Offline Visionaire
Re: [IC] GMK Ashes
« Reply #35 on: Sat, 07 September 2019, 15:54:55 »
First thing I thought when I saw the renders was how I’d break it up to pair with other sets. :)
Offline mikyo
  • Thanks
Re: [IC] GMK Ashes
« Reply #36 on: Sat, 07 September 2019, 16:56:59 »
Love art first site
insta cop
yea, okay, uh huh, sure
Re: [IC] GMK Ashes
« Reply #37 on: Sat, 07 September 2019, 16:58:49 »
Yep. This and minimal? Or nines. What were you thinking?
Offline Mcnos
    • GMK Fuyu
Re: [IC] GMK Ashes
« Reply #38 on: Sat, 07 September 2019, 17:37:04 »
If the white alphas make it, I'll be replacing the alphas on my Honeywell.
Offline Tyson
Re: [IC] GMK Ashes
« Reply #39 on: Sat, 07 September 2019, 17:37:21 »
Just updated the post with renders of Left Centered Mods, I really like the way it looks and am heavily considering sticking with it for the rest of the renders. What do you guys thing about it! Please let me know!
Also, will over looking the responses to the google form I noticed that someone picked up on one of the themes of the set. ;) Originally I was given the idea of The Ashen One, the main character from Dark Souls 3, I ended up scrapping the idea because I didn't want to deal with copyright issues, I also thought about calling it GMK Grayscale, but that's too similar of a name to ePBT Grayscale then thought about GMK Ashen, which happens to also be another set, Maxkey SA Ashen. So I settled for the original idea that was ashes from a volcano.
Going back on the Souls idea I could look into a Souls inspired novelty kit for the set if there is interest in that.
Thank you guys so much for the positive feedback, I really didn't know if this set was going to be a good idea, it looks like it's shaping up really well!
Offline Tyson
Re: [IC] GMK Ashes
« Reply #40 on: Sat, 07 September 2019, 17:38:17 »
They aren't white they are Pantone 428c, a ultra light grey.
Offline Mcnos
    • GMK Fuyu
Re: [IC] GMK Ashes
« Reply #41 on: Sat, 07 September 2019, 17:51:09 »
Oh, misread the thread. Still a nice addition.
Offline FredBananaz
Re: [IC] GMK Ashes
« Reply #42 on: Sat, 07 September 2019, 17:52:42 »
Interested
I'll definetly keep an eye on this thread.
Offline kema
  • Designer
    • kevinmadesign
Re: [IC] GMK Ashes
« Reply #43 on: Sat, 07 September 2019, 18:11:20 »
Should definitely reach out to vendors and set that GB date ASAP! There should be plenty of time to fine tune kits and stuff :D
Offline jooobe
Re: [IC] GMK Ashes
« Reply #44 on: Sat, 07 September 2019, 18:24:48 »
Just not so soon cuz August was expensive
Re: [IC] GMK Ashes
« Reply #45 on: Sat, 07 September 2019, 18:29:26 »
I think the name and fit with the colors is great. (Rama Volcano cap.)
Left centered mods is ok by me. Or not. Either way. Same goes for R0/R5.
Offline break
Re: [IC] GMK Ashes
« Reply #46 on: Sat, 07 September 2019, 18:40:56 »
Oh man the Rama artisan possibilities...
Pantone 428C sounds like a great Cerakote idea. If only I knew a good cerakoting service for keyboards...
Offline Tyson
Re: [IC] GMK Ashes
« Reply #47 on: Sat, 07 September 2019, 18:42:54 »
hmmmm, I can't think of any off the top of my head.  :)
« Last Edit: Mon, 27 January 2020, 11:10:51 by Tyson »
Offline break
Re: [IC] GMK Ashes
« Reply #48 on: Sun, 08 September 2019, 10:45:54 »
hmmmm, I can't think of any off the top of my head.  :)) Be on the look out for more rounds of Ceraklack!
Nice! My Lunar is ready once I get some Cerakote swatches.
Anyway this set is awesome - in for base + white alphas. Looking forward to the artisan and novelties.
Offline hansikhouse
Re: [IC] GMK Ashes
« Reply #49 on: Sun, 08 September 2019, 11:21:58 »
Great job on the IC presentation. Would love to pick up a base set!
