Author Topic: [IC] GMK Ashes [2/25 Basalt Kit Added Back] (GB starts March 2nd)  (Read 200586 times)
Offline Tyson
Re: [IC] GMK Ashes [1/3 Final Kit Renders! Update] (GB starts Feb. 15th)
« Reply #250 on: Mon, 06 January 2020, 16:11:08 »
Beautiful definitely going to pick this up. I'm a sucker for greys.
Thank you! I've been working today on contacting Artisan Makers to get some collaborations going for the keyset! I also sent another message to Rama about a potential Rama Cap for the set. We will see how that goes! Hopefully this is the one! It's a alternative Novelty that didn't make it into the set.
« Reply #251 on: Mon, 06 January 2020, 16:56:24 »
I am also in. Love the color scheme and homage to Dark Souls. Interested in the pad as well. Looking forward to participating.
Offline jooobe
« Reply #252 on: Mon, 06 January 2020, 17:47:49 »
Ghost desk mat is crisp
Sent from my SM-N960F using Tapatalk
Offline Tyson
« Reply #253 on: Tue, 07 January 2020, 14:53:28 »
There are minor discrepancies, I need to remove the Alpha colored Esc key from the Ashes kit, add a 1.25u Enter Key and 1.75u Enter Key to the Basalt Kit, and add a accent numpad enter to the Caldera kit. After this there will be no more changes to the kits. These changes were suggested to me and seemed minor enough for me to make. I'm hoping for the best prices possible with these kits.
Thank you everyone for your feedback!
I am also excited to let you all know that there will be some artisan collaborations happening with this keyset! I have been in talks with a few artisan makers to design caps for this set! More information will be coming on in the next couple of weeks on those collaborations, along with the cable collaboration that we will be having for this set!
Offline MrFurrior
« Reply #254 on: Sat, 11 January 2020, 11:05:13 »
Sad the UK ISO keys got moved to the 40's kit
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #255 on: Sat, 11 January 2020, 13:43:39 »
As two kits, both struggle to meet MOQ.  Combining them to make one kit should reduce the odds of all these keycaps being canceled.
Offline Myteethfeelweird
« Reply #256 on: Sat, 11 January 2020, 20:54:44 »
Definitely in on this. Have been looking forward to this for a long time!
Offline MrFurrior
« Reply #257 on: Sun, 12 January 2020, 04:18:11 »
The UK ISO was originally in the base kit, which would have been handy
« Last Edit: Sun, 12 January 2020, 04:20:13 by MrFurrior »
Offline Tyson
« Reply #258 on: Mon, 13 January 2020, 09:02:52 »
I cut a lot of things out of the base kit to try and reduce cost for the over all kit, I added UK ISO to the Caldera Kit to try and give iso, ext, and 40s a good chance to all make it, I apologize that it got moved, but I want to try to get all kits to make it at a reasonable price, and thought that this would strategically be the best way to get UK ISO and 40s made.
Offline eggplant-chan-
« Reply #259 on: Thu, 16 January 2020, 01:54:57 »
ngl this looks pretty nice
Offline Tyson
« Reply #260 on: Thu, 16 January 2020, 09:17:29 »
Thank you! I'm working on some finishing touches! :D
Offline ymaaan
« Reply #261 on: Tue, 21 January 2020, 10:44:00 »
Any updates for the pricing?
Sent from my SM-A505GN using Tapatalk
Offline Tyson
« Reply #262 on: Tue, 21 January 2020, 11:04:32 »
Actually just spoke to OneFiftyNine today about this, he mentioned that he is going to fix the renders for the Ashes kit (removing the alpha colored esc key) and the Basalt kit (adding the 1.25u enter and 1.75u enter that are missing from the kit right now), then send the renders off to GMK to get quotes, after that him and I will discuss pricing and post it as soon as possible to prepare people. :)
Offline Tyson
Re: [IC] GMK Ashes [1/21 Cable Update] (GB starts Feb. 15th)
« Reply #263 on: Tue, 21 January 2020, 16:16:51 »
Just a quick update today! Hope everyone is doing well! I have been in contact with SpaceCables for quite some time now and have been working with him on collaborating for this set! There will be two coiled cables for the set one in mini b and one in type c, to make sure most keyboards work with the cable. They will both the the same length and color. I am currently working with him on getting samples (he lives like 2 hours away from me so managing this is going to be a piece of cake, I might even help him make the cables by hand :D). I will post pics of the cables in here once everything is finalized for them! I also wanted to let everyone know that OneFiftyNine and I just ordered a sample mat for the main deskmat, I am not too worried about the Ghost Deskmat since it is an extremely simple design. I'll post pics of the real deskmat once it comes in, it should arrive either right before the GB starts or during the GB. Thanks for having patience with this GB and I look forward to posting the next update! :D
Offline jooobe
« Reply #264 on: Tue, 21 January 2020, 16:18:46 »
That's dope
Offline Tyson
« Reply #265 on: Mon, 27 January 2020, 10:48:28 »
Contacting GMK today to find out if all the Novelties are within spec. I am worried that the Bonfire Novelty will not be within their standards, if that is the case I have a alternative novelty that will replace that bonfire. More info after they reach out to me. :)
« Reply #266 on: Mon, 27 January 2020, 10:54:17 »
I really hope bonfire makes it: its basically the main reason for me to buy it.
Offline Tyson
« Reply #267 on: Mon, 27 January 2020, 10:56:26 »
It's staying on the deskmat and the bandoleer for sure! After looking at some other GMK novelty kits it looks like it might be fine, just want to double check for sure.
Offline ymaaan
« Reply #268 on: Mon, 27 January 2020, 10:58:17 »
Any update regarding prices for this one?
Offline Tyson
« Reply #269 on: Mon, 27 January 2020, 11:04:51 »
Still working on fixing the renders then going to email GMK for quotes, we probably won't know until a week before the keyset got live. If we know sooner I will update you :)
« Reply #270 on: Mon, 27 January 2020, 11:37:25 »
I meant novelties kit, haha. After reading my post again, I understand it can be misinterpreted, oops! In for the Ashes/Adventure regardless!
Offline jpg2401
« Reply #271 on: Mon, 27 January 2020, 14:58:53 »
I am sorry if I am just missing it, but is there any word on pricing for the kits yet?
Savage 65 | GSKT-00 || Valhalla | X60 V2
Offline Tyson
« Reply #272 on: Mon, 27 January 2020, 15:13:36 »
Offline OBL17
« Reply #273 on: Mon, 27 January 2020, 17:09:36 »
this and future funk are my most anticipated sets of the new decade
Offline Norato
« Reply #274 on: Tue, 28 January 2020, 18:43:03 »
I wish the Basalt kit had an R2 accent colored Esc key
Offline Tyson
« Reply #275 on: Wed, 29 January 2020, 09:10:09 »
Kits have been corrected and added to the IC, we are currently waiting to hear back from GMK on pricing and will update everyone as soon as we find out!
Offline MrFurrior
Re: [IC] GMK Ashes [1/29 Corrected Final Kits Update] (GB starts Feb. 15th)
« Reply #276 on: Wed, 29 January 2020, 14:31:12 »
I know UK ISO was previously pushed to the 40's kit, but now essentially all the keys are in the base minus 2 which are in the 40's. Meaning you have to buy that kit for 2 keys which is a pain
Offline Tyson
« Reply #277 on: Fri, 31 January 2020, 16:38:49 »
Unfortunately it's too late to add the keys as the keyset goes live in 15 days. I would have loved this feedback earlier in the IC. I also tried slimming down the base kit to help cut costs while also trying to make kits that would help out everyone, normally it's really hard for 40s kits to hit MOQ, so to help that out I combined the 40s, UK-ISO keys and 2 extension keys for WKL layout boards, hoping that everyone would be willing to work together to help this kit hit MOQ.
Offline Tyson
« Reply #278 on: Mon, 03 February 2020, 11:17:33 »
Minor update to add the rows and sizes for the kits. :)
Offline Tyson
Re: [IC] GMK Ashes [2/3 Artisan Collabs Announced] (GB starts Feb. 15th)
« Reply #279 on: Mon, 03 February 2020, 14:50:26 »
Added all the confirmed artisan collabs for the set! Hopefully the next update will have pricing for the set and details on giveaways planned for the set!
Artisan Collaboration:
Tiny: https://www.instagram.com/tinymakesthings/
CozCaps: https://www.instagram.com/cozkeycaps/
NavaCaps: https://www.instagram.com/navacaps/
SodieCaps: https://www.instagram.com/sodiecaps/
Archetype: https://www.instagram.com/archetype_mk/
RathCaps: https://www.instagram.com/rathcaps/
Offline Ooga Booga
« Reply #280 on: Wed, 05 February 2020, 00:46:46 »
Any update on the RAMA keycap?
Offline Kiba
« Reply #281 on: Wed, 05 February 2020, 04:56:35 »
I'm in.
Offline Tyson
« Reply #282 on: Thu, 06 February 2020, 11:28:55 »
GB date has been pushed back to March 2nd, I apologize for this inconvenience and understand if you are upset with this decision. Some things need to be flushed out before the GB begins. I have failed to hit my intended GB date, I am sorry.
Offline FaKe_VirTual
    • Virtual Designworks
Re: [IC] GMK Ashes [2/6 Important Update] (GB starts March 2nd)
« Reply #283 on: Thu, 06 February 2020, 11:35:13 »
No worries, this set is defintely worth the extra waiting!
« Reply #284 on: Thu, 06 February 2020, 11:42:31 »
Personally, it actually makes it even better. February was looking rather tough money-for-keeb-stuff wise.  :thumb:
Offline bd_slade
« Reply #285 on: Thu, 06 February 2020, 12:09:57 »
Works great for me! Thanks for the update and good luck getting the final details sorted!
Offline surfmurder
  • MILK
« Reply #286 on: Thu, 06 February 2020, 14:27:14 »
gonna link the flame march 2nd
Matrix 1.2og - IDB - Ogre
Offline hkiri
« Reply #287 on: Thu, 06 February 2020, 14:41:16 »
My bank account appreciates this decision.
Offline DERBS
  • N E 3u bars avail?
« Reply #288 on: Fri, 07 February 2020, 02:42:04 »
Any chance that Ghost kit gets numpad support :D
Offline Tyson
« Reply #289 on: Fri, 07 February 2020, 08:25:34 »
0 chance, sorry, I am trying to keep the kits cost as low as possible, which is why I made the entire F-Row Ghost colored in the base kit so we wouldn't have to put any F-Row keys in the ghost kit. I am trying to slimline things down right now to lower the cost even more for the other kits too.
Offline Tyson
« Reply #290 on: Mon, 10 February 2020, 16:16:43 »
I've been seeing a little bit of concern for the Ghost Deskmat, people saying that it will get dirty real quickly and collect dirt. This is not true, I used a white NASA deskpad at work for over a year before I switched it out with a white GMK Space Cadet mat. I've had this one on my desk for the past 3 months and no dirt marks or anything, it's still the same color as it was the day I got it! The chances of it getting dirty are the same as any other deskpad! I'm still waiting on samples of the Adventurer Deskpad but due to the Coronavirus it is currently delayed. Hopefully we can get it in to QC it during the group buy so we can make any changes on it if necessary. I will be in Japan for the last half of the GB, so OneFiftyNine will have to QC the mat for me to let me know if everything looks good on it!
Offline Scriba
Re: [IC] GMK Ashes [2/10 Small Deskpad Update] (GB starts March 2nd)
« Reply #291 on: Thu, 13 February 2020, 07:28:24 »
what's the estimated shipping date?
Offline Tyson
« Reply #292 on: Thu, 13 February 2020, 08:41:17 »
I wouldn't know, we aren't even in GB yet, usually we can find out when we submit the order to GMK. It also all depends on when GMK gets their 4th machine up and running, if it's before Ashes hits production (hypothetically speaking because idk if the set will hit MOQ) then the queue time will be faster than what it is right now, I think there was an update on GMK Night Runner saying that it got delayed to July Shipping, the set was supposed to ship this month but GMK is so backed up right now that they pushed it back 5 months. If the new machine isn't up and running by the time Ashes start we might be looking at a Q1 2021 release date, or a Dec 2020 release date. I really hope not but who knows.
Offline Magas
« Reply #293 on: Thu, 13 February 2020, 08:54:53 »
Oh it's going to. I'm buying one if not two of each kit for sure. THEN I'm going to ask for it again in KAT to buy one or two more full sets!
Offline Scriba
« Reply #294 on: Thu, 13 February 2020, 09:48:43 »
Crazy the delay! I'm just wondering then why in the GMK Apollo Thread there was said September/October. Modern Dolch light is stated at late Q4 2020.
Offline azulyf
« Reply #295 on: Fri, 14 February 2020, 13:16:33 »
Is it too late to ask for 1.25 blank in space bars?
Offline Tyson
« Reply #296 on: Fri, 14 February 2020, 16:49:04 »
Yes, sorry. It is way too late, the kits are 100% finalized and pricing is being made for them right now. I am working on trying to get the pricing up soon so people can prepare their wallets for two weeks from now when the Group Buy starts!
Offline Tyson
Re: [IC] GMK Ashes [2/17 Basalt Kit Removal Update] (GB starts March 2nd)
« Reply #297 on: Mon, 17 February 2020, 12:57:52 »
Good Afternoon everyone,
I just wanted to update the IC to announce that I will be removing the 40s kit from the set. After working on pricing it was discovered that the initial cost for the set to work on a 40s board was going to be over $200. With that being said there would have been a very slim chance of the kit hitting MOQ. Pricing along with giveaways will be announced soon.
Thank you for the continued support,
Tyson
« Last Edit: Tue, 18 February 2020, 09:02:58 by Tyson »
Offline CustomerSupport
  • 🕸 developer
    • Discord
« Reply #298 on: Mon, 17 February 2020, 17:02:24 »
Interested. Would prefer to have 1.5u Code/extra 1u Alt for HHKB in the base set, but 🤷🏻‍♂️
Offline Tyson
Re: [IC] GMK Ashes [2/18 Pricing] (GB starts March 2nd)
« Reply #299 on: Tue, 18 February 2020, 10:17:56 »
Got word on the pricing for all regions!
NA [ProjectKeyboards] (USD)
Base Kit- $130.00
Ghost Kit- $66.00
Novelties Kit- $38.00
40s Kit - $35.00
Spacebars Kit- $32.00
EU [MyKeyboard] (EUR)
Base Kit- €139,00
Ghost Kit- €69,00
Novelties Kit- €39,00
40s Kit - TBD
Spacebars Kit- €33,00
ASIA [iLumKB] (SGD)
Base Kit- $181.00
Ghost Kit- $92.00
Novelties Kit- $53.00
40s Kit - TBD
Spacebars Kit- $45.00
Oceania [DailyClack] (AUD)
Base Kit- $194.00
Ghost Kit- $99.00
Novelties Kit- $57.00
40s Kit - TBD
Spacebars Kit- $48.00
« Last Edit: Tue, 25 February 2020, 23:23:21 by Tyson »
