Author Topic: [IC] Shark Keyboards 40% Aluminum Case - The Short One  (Read 3377 times)
Offline Wood_Cables
    • Wood/Cables
« on: Mon, 06 May 2019, 12:16:33 »
Firstly, to clarify, this is NOT part of the Shark PCB Group Buy. This is a stand-alone product which can be used with the Shark PCB, but we wanted to offer it separately.
Shark PCB Group Buy Thread
Some quick details:
- Designed by/with GH user Gondolindrim
- Aluminum 6061, natural finish.
- Anodized in Gray, Black, Purple and Cyan - Feedback on this is appreciated.
- Will accept the Shark PCB and Switch Plate, along with other 19mm-spaced PCB's.
- Switch Plate sits on top of the case, fitting flush.
- Unique mounting system utilizing both PCB and Switch Plate mounting holes.
- Will ship with M2 screws(10) and rubber feet(4).
- Price will be $60.
- MOQ of 100 units, will have 25 of each color mentioned above.
Gray prototype and example of purple color
« Last Edit: Mon, 06 May 2019, 12:23:58 by Wood_Cables »
Offline OkKarma
Re: [IC] Shark Keyboards 40% Aluminum Case - The Short One
« Reply #1 on: Sun, 12 May 2019, 12:52:53 »
Photo URL seems dead.
Offline Lensibne
« Reply #2 on: Sun, 12 May 2019, 23:24:20 »
It's very good with what you are doing right now.
Offline Xynerorias
  • Lubin' with glicerin
« Reply #3 on: Mon, 13 May 2019, 04:50:50 »
Broken imgur link
Sent from my ONE A2001 using Tapatalk
