Author Topic: [GB] [CLOSED] Klippe 2019  (Read 160319 times)
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
« on: Tue, 07 May 2019, 18:44:53 »
Product page:
https://mekanisk.co/collections/klippet/products/klippe
Teaser:
More affordable. Base price $120.
Better design for USB port
New colors
Finer finish
New anodizing methods
Part of Spring/Summer 2019 collection
More++
More info soon.
« Last Edit: Sat, 08 February 2020, 14:52:04 by LeandreN »
Offline ArchDill
Re: [GB] Klippe 2019
« Reply #1 on: Tue, 07 May 2019, 19:23:48 »
Sweet, I love the design of the Klippe.
Offline chive_
« Reply #2 on: Tue, 07 May 2019, 21:56:43 »
Looking forward to more info!
Offline p_blaze
« Reply #3 on: Tue, 07 May 2019, 22:23:42 »
please have red
Offline voight-kampff
« Reply #4 on: Tue, 07 May 2019, 23:03:07 »
Great
Sent from my MIX using Tapatalk
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
« Reply #5 on: Wed, 08 May 2019, 09:48:45 »
https://www.reddit.com/r/MechanicalKeyboards/comments/bm5emg/sneak_peak_of_the_2019_klippe_hope_you_like_it/
Posted the picture on reddit, so we can see what kind of feedback we get.
I aim to launch this, and Fjell Classic R4 at the same time, very soon.
I am thinking of doing a Fjell Pro live stream where I build the prototype and show you what I am working with. Thank you.
Offline p_blaze
« Reply #6 on: Wed, 08 May 2019, 22:51:21 »
Does the Klippe 2019 being modular mean an option to have WKL blockers?
Offline Von Steve
« Reply #7 on: Thu, 09 May 2019, 02:27:52 »
Would it be possible to make the standoffs screwable so we can remove and add them depending on pcb? Kind of how like the standoffs work for a computer case for mounting a motherboard. Also will the connection cutout still be large to accomodate mini usb or are you going towards the usb-c route now?
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
« Reply #8 on: Fri, 10 May 2019, 07:42:35 »
It will be updated, however it will still support Mini USB.
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
« Reply #9 on: Fri, 10 May 2019, 17:58:25 »
Offline p_blaze
« Reply #10 on: Fri, 10 May 2019, 19:28:50 »
I'd love to see a render of the purple klippe with sa laser
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
« Reply #11 on: Sat, 11 May 2019, 08:33:10 »
Me too :)
Offline Von Steve
« Reply #12 on: Sat, 11 May 2019, 14:39:11 »
Would you consider also selling 60% plates in anodized aluminum? Pretty much the same colors as the cases.
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
« Reply #13 on: Sat, 11 May 2019, 18:08:57 »
I'll look at the option.
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
« Reply #14 on: Sat, 11 May 2019, 18:09:58 »
If you use Instagram, follow @mekaniskco :)
Hope you all are has hyped as me to get this started! Should be the best 60% case at this price point!
Offline growler
« Reply #15 on: Mon, 13 May 2019, 13:32:25 »
All over this like a tramp om chips
growler
Don't just stare at it ...
Offline aroostercat
« Reply #16 on: Sun, 19 May 2019, 07:43:08 »
Would it be possible to get a nickel plated fjell like the newer klippe and could you please answer any of my emails regarding my previous Gon pcb order?
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
« Reply #17 on: Sun, 19 May 2019, 14:40:20 »
Next email crunch is on Tuesday :)
Still playing with the options of a brass fjell :)
Online Rob27shred
  • Insane in the Membrane! 👻
« Reply #18 on: Sun, 19 May 2019, 16:02:30 »
At $120 you have my attention now! I really liked the previous Klippe & Fjell designs, but always felt they were a bit on the expensive side for tray mount cases. With the price reduction here I am hopefully gonna pick one up before they sell out, I bet these move crazy fast! :thumb:
Offline p_blaze
« Reply #19 on: Sun, 19 May 2019, 21:44:50 »
I remember it mentioned somewhere that it is unlimited this time
Offline Aznguyen316
« Reply #20 on: Mon, 20 May 2019, 03:34:08 »
I’m ready.
Offline growler
« Reply #21 on: Mon, 20 May 2019, 04:49:19 »
The Fjell Pro though.... Should I just save up? I guess a bird in the hand is worth two in the bush and all that.
growler
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
« Reply #22 on: Mon, 20 May 2019, 14:16:06 »
The Klippe is basically unlimited.
The Fjell Pro is won't be ready for any of the coming buys right now
Offline aroostercat
« Reply #23 on: Tue, 21 May 2019, 20:13:45 »
Didn't get a notification you replied, but no worries :thumb:
Fingers crossed for a brass fjell!
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
« Reply #24 on: Wed, 22 May 2019, 07:07:52 »
When we open this GB, I would prefer if you used klippe2019@mekanisk.co to contact me about this group buy.
We are very close, a couple more hours.
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
« Reply #25 on: Wed, 22 May 2019, 08:31:21 »
Offline realxmlforce
« Reply #26 on: Wed, 22 May 2019, 08:36:22 »
Done. Super excited for the Klippe limited edition  ;D
Thanks for offering this!
Offline growler
« Reply #27 on: Wed, 22 May 2019, 08:52:40 »
The 4 data fields on the create account page arent labelled, or they are using some html standard not known by android chrome. Are they:
First Name
Last Name
Username
Password
Otherwise I can't check out!
growler
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
« Reply #28 on: Wed, 22 May 2019, 08:56:56 »
First Name
Last Name
Username
Password
growler
Hi!
I will check this up asap.
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
« Reply #29 on: Wed, 22 May 2019, 08:58:25 »
First Name
Last Name
Username
Password
growler
First Name
Last Name
Username
Password
This is the correct order. I will try to fix the colors.
Offline clik_clak
« Reply #30 on: Wed, 22 May 2019, 09:10:54 »
Ordered a limited edition! That shipping cost is extreme, but I'm happy to be able to get my hands on such a pretty case!
Offline growler
« Reply #31 on: Wed, 22 May 2019, 09:24:44 »
I got held up checking out with my limited edition, when I finally registered, all gone :(
growler
Offline Zurg Eon
« Reply #32 on: Wed, 22 May 2019, 12:46:55 »
Tried to order one but I get "We don’t offer shipping to Norway." Hmm.
Offline babooshka
« Reply #33 on: Wed, 22 May 2019, 14:24:14 »
Has Fjell Classic R4 been pushed back slightly or will it still be launched very soon with Klippe?
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
« Reply #34 on: Wed, 22 May 2019, 15:12:36 »
Yeah, send me an email, I try to swallow the TAX for Norwegian so you get the VAT/MOMS discounted 😌
Offline clik_clak
« Reply #35 on: Wed, 22 May 2019, 15:26:13 »
I put in my order for my limited edition without adding a plate because I was worried I would miss out. Can I add a plate now and have it combined with my other order by chance?
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
« Reply #36 on: Wed, 22 May 2019, 17:36:57 »
Email klippe2019@mekanisk.co
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
« Reply #37 on: Wed, 22 May 2019, 17:37:28 »
Thank you for all the orders today :) !
Offline diorite
« Reply #38 on: Wed, 22 May 2019, 19:05:20 »
Is this the same as the purple fjell? Do you have any more renders of the different colors. Kinda hard for me to decide on a color at the moment.
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
« Reply #39 on: Thu, 23 May 2019, 00:39:43 »
Its the purple fjell color, if course colors will vary between batches.
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
« Reply #40 on: Thu, 23 May 2019, 12:49:40 »
Just reminding you to check out Mekanisk.co, I don't want any of you to miss out and message me after the group buy has ended(which always happen) :)
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
« Reply #41 on: Sat, 25 May 2019, 06:08:29 »
Some of the material has arrived!
Orders are still open, on mekanisk.co.
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
« Reply #43 on: Tue, 28 May 2019, 11:15:56 »
I want to say, thank you for all your orders. I am glad to see that this case is so popular!
Offline Kaktus
« Reply #44 on: Wed, 29 May 2019, 02:11:39 »
Those render 2 posts before are the black version am I right?
It looks like its not 100% dark black but more like a very dark grey which would be perfect for me.
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
« Reply #45 on: Wed, 29 May 2019, 05:24:45 »
It will be anodized black. Black aluminum is not percieved as perfect black through your eye. I tried to replicate however it will never be perfect in renders.
Offline Kaktus
« Reply #46 on: Wed, 29 May 2019, 09:42:20 »
Are you shipping from within the EU? Probably not right^^
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
« Reply #47 on: Wed, 29 May 2019, 09:46:18 »
No, I am not. It is shipping directly from the factory. Even if I shipped from here it would be outside the EU :/
Offline LeandreN
  • Mekanisk.co
  • * Moderator
    • Mekanisk
Re: [GB] [CLOSED] Klippe 2019
« Reply #48 on: Thu, 30 May 2019, 06:42:12 »
The cases are in production! Look forward to your case coming July-August.
Offline growler
« Reply #49 on: Thu, 30 May 2019, 07:01:57 »
\o/
growler
