Author Topic: [IC] GMK Nord (GB June 10th)  (Read 344627 times)
Offline vffems2529
Re: [IC] GMK Nord (GB June 10th)
« Reply #600 on: Wed, 03 June 2020, 13:24:44 »
Novelty kit does a pretty bad job at covering Tsangan/HHKB layouts. No 1.5u Alt keys, no 1u OS keys, no R3 1.75u Ctrl. Can't say I've seen people use 1.5u OS keys very often, so I'm not sure why those are there.
Some of that weirdness is in the base kit, too. 1.5u Super keys? Two 1u Meta keys? Why the focus on 1.5u OS keys?
Also interested in HHKB layout and a bit lost as to what I'd have to buy to cover
Offline norabu
« Reply #601 on: Fri, 05 June 2020, 00:50:14 »
It's my first time entering into a GB, how long would this take to ship? Should I buy temporary keycaps for the wait?
Offline bobdenard
« Reply #602 on: Fri, 05 June 2020, 02:45:40 »
I think you’re looking at around 10 month wait right now with GMK.
Offline ideus
  • Björkö.
« Reply #603 on: Fri, 05 June 2020, 08:57:36 »
Is the base color for the alphas any close to the standard Dolch's? Just wondering if the Norde kit in this GB may be fitted along an OG Dolch set. I appreciate your feedback.
Offline Gtrx
« Reply #604 on: Sun, 07 June 2020, 14:38:38 »
It's too blue to be used with dolch sets.
Offline Gtrx
« Reply #605 on: Sun, 07 June 2020, 14:39:13 »
As someone said, definitely buy "temp caps"
Offline ideus
  • Björkö.
« Reply #606 on: Sun, 07 June 2020, 16:11:52 »
Thank you for the feedback pal.
Offline jimboytacos
« Reply #607 on: Wed, 10 June 2020, 00:52:31 »
Just made my purchase via MKUltra.click!
Incredibly excited for this set!
Offline Rhk
« Reply #608 on: Wed, 10 June 2020, 03:04:53 »
Is it just me or does CandyKeys not have the setup yet?
Offline elmo
  • Hello I like keyboards
    • Elmo's keyboards
« Reply #609 on: Wed, 10 June 2020, 03:09:37 »
Looks like they are still asleep.
Also kinda bummed by the "artisans".
Only two colors and they don't even look good...  :(
Offline Solertia
« Reply #610 on: Wed, 10 June 2020, 08:35:20 »
Kinda wack that they still show the image with the variety of color options but then only have two to choose.
Offline Gtrx
« Reply #611 on: Wed, 10 June 2020, 08:43:25 »
That's because having all the colors would drive up manufacturing costs a whole bunch. in the IC, I said that only 2 or 3 colors would be chosen based on ic responses. Those colors were purple and blue for the stripe.
Offline ogWalker
« Reply #612 on: Wed, 10 June 2020, 08:56:26 »
GLWGB
Offline BanEmAll
  • My Very Personal Text
« Reply #613 on: Wed, 10 June 2020, 09:20:22 »
Came for the deskmat, left with the keycaps as well. This got expensive fast.
Keyboards:
XENO Full Plate with MaxKey Blue and Gray SA keycaps and 67g Healios
DasKeyboard Professional 4 - Lubed MX Brown
Offline elmo
    • Elmo's keyboards
« Reply #614 on: Wed, 10 June 2020, 09:51:37 »
Blue stripe would have been nice. But I don't see that available anywhere...
Only "Purple" and "Dark"
Offline konstantin
  • Formerly constexpr
« Reply #615 on: Wed, 10 June 2020, 10:06:07 »
Gtrx, there's an omission in your base kit. You included a second 1u Ctrl instead of a second 1u Alt. This means that Mac and some HHKB users won't be able to cover their bottom rows correctly (it requires 2× 1.5u Super and 2× 1u Alt), unless they use Meta keys. It's still not too late to fix this mistake, though; you will likely be able to talk to GMK to have the second 1u Ctrl key replaced with 1u Alt (without altering the quotes, since the number of keys stays the same and all key sizes stay the same).
Edit: To be clear, it's not like the second 1u Ctrl is useful to begin with. No modern ≥60% layouts use two 1u Ctrl keys.
« Last Edit: Wed, 10 June 2020, 10:20:50 by konstantin »
Offline Spicemaster
« Reply #616 on: Wed, 10 June 2020, 10:18:22 »
Anyone else not able to find deskmats/artisans for sale on MKUltra?
Edit: Found them! For anyone else who missed, you need to click on "Nord are you waiting for?" on the homepage which gives you the option to select caps, deskmats, or artisans. Hope this helps.
« Last Edit: Wed, 10 June 2020, 10:24:36 by Spicemaster »
Offline gt1989
« Reply #617 on: Wed, 10 June 2020, 10:20:14 »
Yeah, I was wondering about that too.
Offline oldcat
  • 65% is Life
« Reply #618 on: Wed, 10 June 2020, 10:25:23 »
Open?
Offline fishbiscuit13
  • do you realize ???
« Reply #619 on: Wed, 10 June 2020, 10:25:37 »
They’re not linked on the front page, just search “Nord” and you’ll find them.
Offline Eipplepod
« Reply #620 on: Wed, 10 June 2020, 10:26:51 »
Does anyone know whats up with Candykeys? Still no GB online
Offline Spicemaster
« Reply #621 on: Wed, 10 June 2020, 10:27:57 »
Just found it. I edited my post above with the solution because you can also click on "Nord are you waiting for" on the homepage to get options for caps, deskmats, or artisans.
Offline gt1989
« Reply #622 on: Wed, 10 June 2020, 10:28:14 »
Thanks, yeah I see it's purple and dark. However I thought it was supposed to be blue instead of dark?
« Reply #623 on: Wed, 10 June 2020, 10:35:56 »
I'm going to toss my hat in with the artisan complaints. I was very interested in getting these to go with Dots, but with the purple on the far end of lavender and the blue being replaced with "dark", that's a no go. I just feel like those are possibly the two weakest color options, and will either look out of place or get lost amid the full set.
Offline jayiskuhl
« Reply #624 on: Wed, 10 June 2020, 11:01:47 »
What happened with the artisans? These are a big disappoint after what I was expecting. The original colors were vibrant and had good color options. Then on release we get 2 dull, muted options.
Rukia (?) | gaff. 60 | Pandora | Praxis | Bauer 2
Offline Missingnumber
« Reply #625 on: Wed, 10 June 2020, 11:50:35 »
Still no Group Buy thread? I thought the interest in this one would have it competing with Oblivion, but there's not much fanfare. Plus the price for the base set and the US retailer. I really love the colorway and theme though.
Offline gt1989
« Reply #626 on: Wed, 10 June 2020, 12:10:54 »
GB threads sometimes take awhile to get approved.
Offline scoopbb
Re: [IC] GMK Nord
« Reply #627 on: Wed, 10 June 2020, 12:11:59 »
So - Due to the continuous pushbacks on prototypes of certain products, pushbacks due to COVID and just generally kind of nutty lead times, GMK Nord will start on June 10th. On CandyKeys, MKUltra, Deskhero, Zfrontier and Oceania is pending.
The prices look to sit at for USA at
55$ NORDE
50$ Novelty
125ish-130$ Main Kit
35$ Numpad Kit
20$ Space Kit
and for EU at
55 EUR NORDE
50 EUR Novelty
123 EUR Main Kit *Nice Update*
32 EUR Numpad Kit
28 EUR Space Kit
150 EUR Assembly Kit
CandyKeys will be offering 15 EUR EXPRESS Americas shipping, and these prices above are ink. Tax. Meaning that non EU Customers pay 19% less on our prices.
site not showing 15 euro shipping for America orders. Still has 24.99e
« Reply #628 on: Wed, 10 June 2020, 12:15:24 »
Oh, I didn't know that. Thanks for the heads up.
Offline tominabox1
« Reply #629 on: Wed, 10 June 2020, 13:10:17 »
Is there a discord for this set?
A discord will most likely be created when the gb starts.
You may have to report the post for the mods to do something. Worked for Space Cadet
« Reply #630 on: Thu, 11 June 2020, 03:52:16 »
