Author Topic: [IC] Harbour —港口: GB on April 2nd  (Read 246867 times)
Offline kibou store
« on: Wed, 10 February 2021, 11:16:09 »
Harbour —港口: A 65% gasket mounted board designed by Kibou, Hong Kong
Renders:
(Rendered with GMK minimal, GMK WOB)
TABLE OF CONTENTS
IC Form: https://forms.gle/F6rFJk59PTUGQcrU8
1.) Introduction
2.) Specifications
3.) Renders
4.) Design
5.) Current Status & Timeline
6.) Vendors & Pricing
7.) FAQ
8.) Special Thanks
9.) News & Updates
1.) INTRODUCTION
About Kibou.
Kibou, 希望, is the Japanese noun for hope. It is a reflection of who we are: a bunch of hopefuls who believe that our passion for a better typing experience will allow us to make great products.
Why “Harbour”?
The keyboard’s name is a homage to Hong Kong - the place we grew up in. Historically, Hong Kong has long been an entrepτt between east and west - a place of trade, and, more importantly, a place where people of a common interest can gather. We hope Kibou will not only be the premier vendor for all things keyboard, but a community too.
2.) SPECIFICATIONS
Typing Angle: 6.0° typing angle, 16.5 mm front height
Colours: Black, Navy, E white, Lilac Grey (SE Only)
Plate Options: Aluminium, Polycarbonate (Half/ Full)
Case Material: Aluminium
Mounting Style: Gasket Mount
PCB: H65 Designed by hiney (Soldered Only)
Weight: Polished stainless steel / Sandblasted Stainless Steel
Layouts: WK/WKL layout
3.) RENDERS
Rendered with GMK 9009
Rendered with GMK Hanok
Rendered with GMK Kuroge Wagyū
Rendered with GMK Minimal
Rendered with GMK Lavender
Polished stainless weight
4.) DESIGN
Approach.
Our design approach is straightforward: simple design and quality materials. We wanted to design a keyboard that we would want to use ourselves. From the mounting style to the typing angle, the keyboard is designed to deliver the best user experience possible.
Inspiration.
Hong Kong is home to more skyscrapers than any other city in the world. Our skyline is dotted with iconic buildings that helped author the aesthetic style of our keyboard. In particular, the textured layout on the sides was inspired by the BOC building. The numerous skyscrapers facing Victoria Harbour are characterised with smooth window surfaces supported by curtain walls and steel frames. Drawing inspiration from these visual elements, we decided to create a keyboard with a seamless design accompanied by a stainless steel weight.
We also drew ideas from the community. The visual appeal of Gok’s 7V design (the weight in particular) was a concept we wanted to explore and build from.
Mounting Method & Materials.
Using both community feedback and anecdotal experience, we believe that the softer typing feel that the 2mm Poron foam as a Gasket provides is more comfortable.
Assembly.
Aside from the seamless design, we also designed Harbour with the intention of making your assembly process as user-friendly as possible. This includes self-aligning slots between the top and botton case.
Packaging.
Will be revealed in the future.
Forth Colour option poll is now up! https://forms.gle/99ASJrS4qD7P9qvo6
Thanks for all the submissions, new colour confirmed, will be Blue Grey.
5.) CURRENT STATUS & TIMELINE
Current Status
GB On April 2nd
6.) VENDORS & PRICING
Standard: 520 USD / 4070 HKD
SE: 600 USD / 4695 HKD
Layout
WKL/WK
Plates:
PC/ Alu (Half/Full)
Units:
Standard: 300 Units
SE: 90 Units
Colour Available:
Standard:
- Black, Navy, E White
- Sandblasted Stainless Steel Weight
SE:
- All standard colours and Lilac Grey
- Polished Stainless Steel Weight
Sale Time:
SE: April 2, 2022 1:00 PM (HKT)
Standard: April 2, 2022 2:00 PM (HKT)
7.) FAQ
Q: What is the weight of the board?
A: Around 2 kg.
Q: Will it be ISO compatible?
A: For our base kit, the PCB is ISO compatible, but unfortunately the plate is not. However, we will be releasing a universal plate file that will be compatible with ISO.
Q: Are stabilizers, switches, keycaps included?
A: Unfortunately, these are not included in the DIY kit.
Q: Will the plate files be released?
A: Yes, we will open source our plate files.
Q: When will the keyboards be shipped after the group buy?
A: Estimated arrival of around 7 to 10 months (Yet to be confirmed).
8.) SPECIAL THANKS
We would like to give a special shout out and thanks to the following for all the help they provided throughout the design process.
- Gok for providing design inspiration, feedback, and suggestions throughout our design progress
- Hiney for designing our PCB, and support
- RNCables <3
- G14D for his help and suggestions
- Epsilon and his server members for their continuous support and suggestions during our design process
- All of our affiliates, Jintae, Ramen, Kiwi and Bao for their suggestions
- KingK22 for the renders
- And lastly, the HK mechanical keyboard community members for their support
9.) NEWS & UPDATES
Feel free to join our Discord for regular updates. We will also be hosting a giveaway for the board in the upcoming weeks!
 https://discord.gg/nsvsAfGYHe
Or, if you prefer, updates will be available on our website, Kibou.store. Please consider supporting the store, we sell lubes, switches, accessories, and more!
Feel free to support us by adding the banner below! Thank you!
Code: [Select]
[url=https://geekhack.org/index.php?topic=111146.msg3012509#msg3012509][img width=360 height=120]https://i.imgur.com/OW6tB1E.png[/img][/url]
« Last Edit: Wed, 12 April 2023, 23:54:29 by kibou store »
Offline kibou store
Prototype 1
27/7 Progress Update:
- 3rd Prototype Ordered
Front height: 18.5 -> 17
Changes in mounting points
Redesigned internals
20/4 Progress Update:
- Ordered our second prototype
- 50 units of lilac harbour confirmed
- Price might change due to the increase in cost of metals in China
Modify message
29/3 Progress Update:
- In stock units confirmed, 50 Units Worldwide, Lilac Grey, WKL Layout
- First prototype received
- Working on some internal adjustments of the board, reducing the overall compression of the gaskets
- Add more self aligning slots
- Modify the back weight's logo
24/2 Progress Update:
- First prototype should arrive in late March
- Added leaf spring plate, some extra self aligning spots
- Change in the shape of feets
 More pictures and renders will be provided later on! Thanks for everyone's support
« Last Edit: Wed, 12 April 2023, 23:55:06 by kibou store »
Offline JKKEEBS
Love the weight!
Offline kibou store
Thank you!
Offline o3okevin
Cool design!
Offline Fredington
    • Instagram
Yes.
Offline Khaine
I really like the sides of the board, imo it's a really unique characteristic for the board as well as how the weight flows with it too! the universal plate for the ISO is a cool idea, GLWIC!!! :D
Offline shuijiao
  • ergo clear
super nice board! i like it a lot
Peerless80, Type S, Pro 2, Pro 1, Duck Viper v3, Duck Orion V2.5, Matrix 2.0 Additional, Matrix Falcon
Offline shay350
im loving the back
Offline kibou store
Offline kibou store
Thank you!
Offline bthezebra
Super Clean Super Sixty Five
Offline raykcy
    • RnCables
OMG the design is very unique as well as the background story!!! Love the board will definitely get one!
Offline AshF
Looks amazing. Ashame about the lack of ISO plate otherwise this would have been an instabuy. GLWIC
Offline lbassett21
  • Plastic and Metal Enthusiast
Inspired from the Kira80 by ThesisCamper I see! Sucker for those sides. Good luck with your IC!
Discord: Bassett#0001 | Reddit: /u/lbassett_21 | Instagram: BassettKeebs
Current Collection:
Keyboards:
OTD 360 Corsa | Kira80 | FMJ 80 | Matrix 8xv2.0 | Matrix 8xv1.2og | IBM SSK 1395217 (Stock Trading) | Hiney TKL One PC | Hiney TKL One FNF | G81-3077SAU | G81-3007SAU | G80-9039HAAUS | HHKB Pro 2 Type S | Realforce 84ub |  Lunar 2 |  Sord KB-101 | Percent Canoe | G80-3190HSU | Alps64 | Xerox 6085 Keyboard | IBM 5576-001 | IBM Model M 1390131 | IBM Industrial Model M 1394946 | IBM Model M SSK 1393691 (SABRE) | IBM Model M 1393464 | HHKB Pro Hybrid Type S | Dell AT101 | Leading Edge DC3014 | IBM Model F AT | IBM Model F122 | G80-0693 | G80-0528 | G81-3100SDU | G80-1838HPU | DAS 2 (G80-3485LWNUS-2 | Texas Instruments Keyboard (SKCM Brown) | G80-9002LBBXX
Keycaps:
ESA-3000-HASR0 | G81-3077SAU | G81-3100SAU | BMOL 5206 UP (Desko Color) | BMOL 4000 U (Desko) | GMK Solarized Penumbra | Desko Black (1/10) | GMK Beta JS | IBM APL2 w/Box 1395624
Offline MiSo
The design is unique, but maintains a minimalistic feel. Really looking forward to the group buy! Will definitely be participating :)
Offline WilsonWan
Look forward to getting one, good stuf
Offline ShiroMoria
Hmm, i see some inspiration form the AKI-S as well  :))
Offline treeleaf64
    • treeleaf64
I went to Hong Kong and it was nice and I think you have done a decent job with the keyboard.
Everyone must pay the cat tax
Offline MIGHTY CHICKEN
Intersting sides
Offline 10peaches
Good work guys. I can see where you draw your inspiration from. Very well structured IC. Looking forward to see the first proto.
Offline kibou store
Thank you all for your support! We will look into different colour options, and we are on track to receive our first prototype by early April.
We understand that not having an ISO plate option may be a deal breaker for some, but we strongly believe that a fixed layout will be able to provide better sound. However, the PCB supports ISO layout and the plate files will be open sourced. If there is enough demand for ISO, we may consider adding it as an option.
Offline Hawksmoor
could i request consideration of a non-metallic plate material if not already please?
E.g. Poly
Very cool design. Well done, team! And I love Hong Kong and miss the place so much, I’m in.
Offline Chippy
  • sus chef
Interesting take on this theme, I appreciate the colorways you're doing.
1.2og | Buddy 6xx | Le Fishe V1 Proto | xyz60 Rev2 | Quartermaster | Chimera65 | Satisfaction75 | Realforce 84u | Zenith Z-150 | Realforce 86u | 378
This and the swiss cheese keyboard is the next generation of keyboards
Offline Livid
E.g. Poly
it says PC will be a plate option!
also i'm really liking this so far, especially the silver  :D
Offline keystream
    • keystream.me
Wow, I love the design of this board. Super clean, great job!!
Offline kibou store
E.g. Poly
E.g. Poly
Thanks for the responses guys! Yes a PC plate option will be included, we will also try out other plate options and test them once our prototype arrives!
Offline kiwoli
In this for the design on the weight alone.
Offline Lysol_
nutty sides. me likey
Offline deedz
WKL 65%?! Say no more
Offline despairsray
This looks really clean. That Lavender render though, god damn.
Offline hdbui120
Sick! ;D
Offline soloplayer
do you have exploded view?
also could you offer CF full or half plate?
i'm very interested  :thumb:
Offline kibou store
Exploded view will be released soon! And yes we will be offering half plates, we will be testing out different plate options when we receive our prototype, stay tuned for updates!
Offline sexton
Love the clean look, especially the black. Any thoughts to more colours? Think a dark blue would really look nice
Offline jmepstein
Looks absolutely incredible -- loving the WKL silver in particular. Looking forward to the GB!
Do you have any measurements of the front height?
Offline dllm
So... being an US immigrant from HK who misses HK very much, I just feel that if I don't get this board I'm actually going to have to dllm...
Offline G14D
  • Ars gratia arits
lmfao sosad :thumb:
Offline alspdx
Such a nice design, love that side profile! Would definitely buy if it were 60%.
Offline kibou store
We will look to add 1 or 2 more color options if there are enough demand for other color ways :thumb:
The front height measures at around 18.5mm without feet installed.
Offline gautema
Looks fantastic! With a regular WK tsangan bottom row as an option it would be absolute endgame, but I'm going for it anyway
Edit: just saw that WK was an option! I'm so in!
« Last Edit: Thu, 11 February 2021, 02:10:15 by gautema »
Offline Hawksmoor
E.g. Poly
mb. i did look for it and just missed it. i'm blind
Offline Jinho
  • hello
    • i used to build keyboards
looking forward to trying a proto :)
iu / jinsoul / xiyeon / ogre / nunu / 378 / x60 v2 / derivative / unikorn hk / lamy / calliope / dolice / harbour / xeno / 87u
Offline the_ream
This and the frusta fundamental, HK keyboard scene is killing it
Offline oTEMPE5To
  • I make fancy keycap yoinkers
I love this, the sides remind me of the stealth pattern of my Spyderco Chaparral 2, as well as being low profile enough to not be in your face. Its very clean  :D Good luck with IC!
Offline kibou store
<3
Offline kibou store
Updated with exploded view!
Offline kibou store
lmfao sosad :thumb:
No worries, I will take care of the diu lo mo part <3
Offline Senbeii
  • Swiggity Swag Whats In Da Bag
    • Keyoto
Oh my... that side profile... its quite sexy  :thumb:
