Author Topic: [IC] SA SAIL R2  (Read 54009 times)
Offline Fredington
    • Instagram
[IC] SA SAIL R2
« on: Fri, 11 September 2026, 13:43:26 »
Hi everyone. Long time.
I figured there might be some interest in a rerun of this, so let's get into it.
IC Form
Kits
A new <> key has been added for ISO users.
Some positions in the 65% column have been moved around for aesthetic reasons and to help streamline new mold costs for the 40s kit below.
Special thanks to HaiZeus for his help on this 40s kit and for getting the ball rolling on this rerun in the first place.
The idea here is that this is a fully self-contained 40s kit so that 40s users won't have to also buy the Modifiers kit to cover their boards like in the past. We've also made use of SAIL's agnostic legends to further help with coverage.
The 00 has been adjusted from R1.
Photos of R1
Signature
If you'd like to support this project, you can use the signature banner below:
Code: [Select]
[url=https://geekhack.org/index.php?topic=127104.0][img]https://i.imgur.com/uXFvTSK.png[/img][/url]
Offline Fredington
    • Instagram
Re: [IC] SA SAIL R2
« Reply #1 on: Fri, 11 September 2026, 13:44:01 »
Reserved
Re: [IC] SA SAIL R2
« Reply #2 on: Fri, 11 September 2026, 13:57:24 »
Do you already have vendors in mind?
Offline Meepergon
Re: [IC] SA SAIL R2
« Reply #3 on: Fri, 11 September 2026, 14:37:33 »
WE ARE SO BACK
I'VE BEEN SITTING ON A MOD KIT FOR A FEW YEARS WITH NO ALPHAS TO MATCH
RAHHHHHHHHHHHHHHH
Offline IOVERCALLHISTIOCYTES
Re: [IC] SA SAIL R2
« Reply #4 on: Fri, 11 September 2026, 15:32:53 »
Probably completely unrealistic given current GB numbers, or those for SA, etc…
Can those of us who bought during R1 get something new? Deskmat? Alert row? Still one of my favorite sets years later.
Offline pixelpusher
Re: [IC] SA SAIL R2
« Reply #5 on: Fri, 11 September 2026, 16:19:06 »
Was thinking the same thing.  I would love to support this as much as possible.  I own R1 and would love to see some new offering the round.
Offline MikeTheTiger
Re: [IC] SA SAIL R2
« Reply #6 on: Fri, 11 September 2026, 17:42:20 »
Alphas, 40’s, bars. I’m in.
"all the numbers or none of them cmon man" -Kokaloo
Offline rowie
Re: [IC] SA SAIL R2
« Reply #7 on: Fri, 11 September 2026, 18:27:47 »
I’m all in for sure! Finally an SA set. It’s been awhile since there was an SA drop. Hoping this one becomes a reality. 🙏
Offline nebulazy
  • i heart keyborb
Re: [IC] SA SAIL R2
« Reply #8 on: Fri, 11 September 2026, 19:13:54 »
goated set i'm so in
Offline tunb
Re: [IC] SA SAIL R2
« Reply #9 on: Fri, 11 September 2026, 23:21:51 »
so good
Offline ibabo
    • yeaaaaaaahh
Re: [IC] SA SAIL R2
« Reply #10 on: Sat, 12 September 2026, 01:30:45 »
I havent bought a set in years. ive been waiting for this. LFG!!!
ahaaaa, keyboard. HOVA
Offline guinnesstour
Re: [IC] SA SAIL R2
« Reply #11 on: Sat, 12 September 2026, 04:59:09 »
I'm in, but I prefer the 40s kit from the first run
Offline krikun98
Re: [IC] SA SAIL R2
« Reply #12 on: Sun, 13 September 2026, 05:02:27 »
I don't even like SA, but this is so gorgeous I've been kicking myself for missing out on the R1 for years - I have no choice but to get it.
Any chance of adapting the design to DSS or MTNU?
Also, would it be possible to add a couple of 1.5U bars (for Corne-like splits) to the spacebar kit?
« Last Edit: Sun, 13 September 2026, 05:17:33 by krikun98 »
Re: [IC] SA SAIL R2
« Reply #13 on: Sun, 13 September 2026, 10:19:55 »
Mold costs vs MOQ for those profiles is a rough ratio.
I’d gladly pay 185-200$ for mtnu sail but there aren’t 249 others.
Offline Alexrouber
Re: [IC] SA SAIL R2
« Reply #14 on: Sun, 13 September 2026, 20:40:52 »
Throw in some novelties — an SA kit is soulless without them.
