Author Topic: [IC] LeFishe | Updated 8/8/22  (Read 136530 times)
Offline Lysol_
« on: Mon, 07 February 2022, 14:16:01 »
Welcome to the LeFishe interest check
^^^banner^^^
Code: [Select]
[url=https://geekhack.org/index.php?topic=116208.0][img width=327 height=120]https://i.imgur.com/H3louyX.png[/img][/url]
Change Log
● 3/22/22 - Added vendors for NA, SEA, and OCE
● 3/22/22 - WK and WKL options will be available from the IC results
● 4/1/22 - Price will be based on the included custom bag from the IC results
● 5/2/22 - Adding Baby blue as an option for colors(Pantone 645c)
● 8/4/22 - original manu has been bad with communication so currently getting pricing from a new one.
● 8/8/22 - Soundtests from Ankit are added
Introduction(skip if you don't care)
Lysol here, been working on my ideal 65xt board for the last 9+ months, I made a couple of prototypes with another one
on the way of this version, I wanted to see if anyone would be interested in a run of this design I made.
I like xt layout 65%s but wanted said layout with the 0.75u symmetrical blockers as first seen on the Bauer by Omnitype. I felt like there
was a lack of 65s that had this option and wanted to make/design one myself. which ultimately leaded to the making of... LeFishe
IC FORM
Board Specs
● Layout:WKL 65xt with 0.75u symmetrical blockers (a non WKL top option will be offered if there's interest.)
● Case Materials: 6063 Aluminum with Brass through weight
● Typing Angle: 7 degrees
● Mount Style: Dual Mount - Top mount with option of o'ring gummy worm gasket mounting
● Plate Materials: Anodized 5052 Aluminum, PC(undecided if frosted or clear) or FR4
● PCB: QMK & VIA/VIAL compatible PCB
● Board Weight: 2.2kg built/1.9kg unbuilt
● O-Rings Included: 60a & 30a 230mmOD CS3.5mm o-rings
● Price Target: $399USD @ 150 moq
● Kit Contents: 1x Aluminum Top and Bottom Case, 1x anodized plate 5052 alu Plate, 3M bumpons, 2x daughterboards & 2x cables(unsleeved),
1x MX+Alps solderable PCB(alps plate files will be supplied), 1x 30a & 60a o-rings, silver m3(m2.5 for the plate) stainless hardware and Custom carrying case with foam inserts
● Effective Keyboard Height(not including bumpons) - 24.52mm
● WKL top Case Layout Options:
● WK top Case Layout Options:
● Plate Layout Options:(dedicated ISO plate files will be made available at the time of gb)
● PCB Layout Options:
● Daughterboard: custom daughterboard designed by XYZ, creator/a maintainer of VIAL,
 but modified by me to include a resetable fuse in its design(mainboard has the ESD chip)
files for the daughterboard will be open-sourced and ill be selling them
myself for those that don't want to get them made themselves.
Board Colors(this will be updated with pics of color samples when i get them from the new manu.)
● Silver - Manufacturer Stock Color
● Grey Top, Silver Bottom aka "NCR"
● Grey/Dark Silver - Manufacturer Stock Color
● Burgundy - Pantone 188c
● Green - Pantone 4209c
● Pink - Pantone 189c
● Baby Blue - Pantone 645C
Buy Info
● Vendors - TBA, currently reaching out to vendors.
     ● NA   - Paramountkeeb.com
     ● EU   - Mykeyboard.eu
     ● SEA - Mecha.store
     ● OCE - Allcaps.store
● Units - 150 moq with a cap of 300 units for the current price target but could change depending on interest
● GB Date - TBA
● Lead Time - 5 to 6 months ideally if there are no delays.
Contact Info
You can reach me at Lysol#5640 on Discord
I also have a discord server in case you want to closely follow the progress on this and my other designs.
Renders
(Case Color Renders by Pontus)
(Case+Keyset Renders by Dudeship)
(rip taiga latin kit)
Prototype Pics
this is a previous version of the board, there were some issues I found and iterated on for the final version this IC is for.
some changes include refining the o-ring mount for better o-ring friction on the sides of the inside of the board, changing interior weight
fillets & weight position, and moving weight screws over, and reducing the amount of space beneath the PCB, blemishes on the brass
are from me and ano banding on the right side of the board is a one-off issue just to this prototype.
Disclaimer: screws will NOT be Phillips, Hex machine/countersunk screws will be used.
Special thanks to Pontus & Dudeship for renders, to Sam Buddy/RMI for the initial PCB design,
to Oggi(GMK Taiga creator), Alessio(DCS Pink alert creator), Octix(GMK Apollo creator), and Ella(GMK Moscow Nights creator) for permission to use their sets for renders on my board.
and thanks to everyone that been supporting me in making this design over the 9+ months this was in development
« Last Edit: Mon, 08 August 2022, 14:55:35 by Lysol_ »
Offline Atr
Re: Lefishe |65xt
« Reply #1 on: Mon, 07 February 2022, 14:16:40 »
Reserved.
« Last Edit: Mon, 22 August 2022, 05:22:53 by Atr »
Offline Sandy
  • Formerly cogitoergofemme
  • Sandy - Peach Tray Maker
    • the peach · studio
Re: Lefishe |65xt
« Reply #2 on: Mon, 07 February 2022, 14:17:47 »
Lysol you been hitting the Lysol you’re over here making dupes of boards and threads is that the joke?
🍑C11🍑KWA.6🍑GPK60 47-GR1RE🍑Vast60🍑Rose60🍑EHKB🍑Viktus Sinne🍑Boop65🍑Jelly60 Pro🍑Fuji65🍑Ginkgo 65🍑S7.7🍑Treasure Type-9 II🍑Thermal R2🍑Jelly 60🍑
Offline hankyul33
Re: Lefishe |65xt
« Reply #3 on: Mon, 07 February 2022, 14:17:53 »
fishe
Offline Pontus
Re: Lefishe |65xt
« Reply #4 on: Mon, 07 February 2022, 14:17:56 »
Sick project!  :cool:
Offline Lysol_
Re: Lefishe |65xt
« Reply #5 on: Mon, 07 February 2022, 14:19:41 »
shhhh you didn't see it.....
Offline Laur
  • Formerly dudeship
  • gmk retro runic
    • wip
Re: Lefishe |65xt
« Reply #6 on: Mon, 07 February 2022, 14:21:17 »
nice bath bro
Offline TRIGOZEN x TAO
  • Kanna + Keybort = Big Weeb
Re: [IC]Lefishe | 65xt
« Reply #7 on: Mon, 07 February 2022, 14:22:11 »
very nice, very based. love to see it lysol
Offline zhol
  • zhol
Re: Lefishe |65xt
« Reply #8 on: Mon, 07 February 2022, 14:22:25 »
women fear me
lefishe wants me
put me in coach, the pink ones calling to me
« Last Edit: Mon, 07 February 2022, 14:24:11 by zhol »
i'm zhol
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
Re: [IC] Lefishe | 65xt
« Reply #9 on: Mon, 07 February 2022, 14:24:00 »
189c enjoyer
Offline nFaiz
« Reply #10 on: Mon, 07 February 2022, 14:24:11 »
* video0.mov (776.31 kB - downloaded 685 times.)
Offline fedoragoose
« Reply #11 on: Mon, 07 February 2022, 14:25:02 »
is this keyboard waterproof
Offline Windy
  • Dumbass
« Reply #12 on: Mon, 07 February 2022, 14:25:34 »
 :D very cool board lysol!!!!
Offline Ella
  • Why is it called an oven
« Reply #13 on: Mon, 07 February 2022, 14:26:36 »
Fishy
Offline plag
  • Formerly pepperonichicken
  • i also go by plag
« Reply #14 on: Mon, 07 February 2022, 14:35:09 »
This is my favorite weight design I’ve seen to this date. Glwic!!!  :thumb:
Offline zea
  • yeh
« Reply #15 on: Mon, 07 February 2022, 14:37:59 »
looks noice but please consider using a C3 daughterboard instead of a custom one for ease of replacement in the future
Offline kameron
« Reply #16 on: Mon, 07 February 2022, 14:38:55 »
so litty but please add wk option :thumb:
« Last Edit: Mon, 07 February 2022, 15:34:18 by kameron »
Offline Alessio
    • YT Channel
« Reply #17 on: Mon, 07 February 2022, 14:41:42 »
so litty but don't force wkl :thumb:
shut up kameron
Offline Juan.
« Reply #18 on: Mon, 07 February 2022, 14:44:58 »
blub blub?
rubber cup
Offline Lysol_
« Reply #19 on: Mon, 07 February 2022, 14:46:26 »
daughterboard files will be open source so easy replacements will be readily available for those that need it via having it made by their favorite pcb fab or going though me since i myself will be stocking them as well.
this daughterboard also uses the same pinout as unified
Offline nu_types
  • Formerly Iredeus
« Reply #20 on: Mon, 07 February 2022, 14:51:05 »
Good **** Lysol
Offline Laur
  • Formerly dudeship
  • gmk retro runic
    • wip
« Reply #21 on: Mon, 07 February 2022, 14:52:02 »
Offline kameron
« Reply #22 on: Mon, 07 February 2022, 15:00:47 »
Offline Laur
  • Formerly dudeship
  • gmk retro runic
    • wip
« Reply #23 on: Mon, 07 February 2022, 15:12:24 »
Offline spedywin
  • Formerly spedywin
« Reply #24 on: Mon, 07 February 2022, 15:13:28 »
how 2 bathe ur keyboard 101
Offline herbologist
  • beige enjoyer. send help.
« Reply #25 on: Mon, 07 February 2022, 15:15:54 »
wkl good, nice rectangle lysol.
Sent from my Pixel 6 Pro using Tapatalk
Offline puggo69
« Reply #26 on: Mon, 07 February 2022, 15:20:20 »
this is beautiful, this is better then art, glwic  :thumb:
Offline Cipulot
    • Website
« Reply #27 on: Mon, 07 February 2022, 15:30:27 »
I absolutelly LOVE it. Great work Lysol  :thumb: keep up the fantastic work and best of luck for the project (uwu acrylic option in my mailbox plz  :cool: )
« Last Edit: Mon, 07 February 2022, 15:32:24 by Cipulot »
Offline C10ckwork
« Reply #28 on: Mon, 07 February 2022, 15:39:19 »
tempted to cancel my freebird tkl order for this...
ah **** it i'll probably buy both
Offline ankit
  • Formerly ankit-sachdeva
« Reply #29 on: Mon, 07 February 2022, 15:40:08 »
Very nice.
Offline linell
« Reply #30 on: Mon, 07 February 2022, 15:47:09 »
 :thumb: good blockers
1u + 0.5u is terrible
bro this a **** set, just be thankful you even getting 1 base running fr
Offline treeleaf64
    • treeleaf64
« Reply #31 on: Mon, 07 February 2022, 15:49:07 »
How do i mute dudeship and kameron from this conversation
Everyone must pay the cat tax
Offline unusuaL_
« Reply #32 on: Mon, 07 February 2022, 15:57:37 »
niice sides
collection: hibike 1/1, garderie tkl, casper60, hhkb pro2, matrix 2.0additional, f1-8x og
Offline snicket
  • Formerly lucalink
« Reply #33 on: Mon, 07 February 2022, 16:24:37 »
nice weight design.
Offline IMZO
  • Matrix shill, and TKL WKL Lover
« Reply #34 on: Mon, 07 February 2022, 16:36:36 »
i love it, the pink tickles my fancy. :) good job mr lysol!
Current boards: Jane V2 CE , Matrix 1.2og Silver WKL , Matrix 2.0add coating black WKL, Matrix 2.0add WKL Coating yellow, Satisfaction75 R1 Cloud white, Korno65, Bloop65, HHKB Pro 2 white,Lin Whale Pink WKL, Gok 7v White, Gok 7v Black, Orion V3 Silver WKL, Orion V2.5 Red WKL, Geon F1-8x Silver WK, Haus65 BlueGray, Plume65, Vertigo, Frog TKL WKL GreenF13
Offline Nurseh
  • Sorry for always apologizing
« Reply #35 on: Mon, 07 February 2022, 16:46:09 »
Its waterproof!?  :thumb:
Offline powwu
    • Discord
« Reply #36 on: Mon, 07 February 2022, 16:53:29 »
good
Offline Pyroo
« Reply #37 on: Mon, 07 February 2022, 17:13:12 »
Finally, le fishe my beloved
Bunny enthusiast
Offline TypeSaucy
  • meign
Re: [IC] LeFishe | 65xt
« Reply #38 on: Mon, 07 February 2022, 17:38:02 »
 :cool: :cool: :cool: :cool:
Offline denibhoxha
  • cock and balls technology
« Reply #39 on: Mon, 07 February 2022, 18:01:18 »
i aint even gon hold you bout it chief, this definitely is one of the keyboards of all time
Offline Extra Fox
  • quis qui sais
« Reply #40 on: Mon, 07 February 2022, 18:25:39 »
I dig this, I also believe that's likely going to be one of the best lead in images I've ever seen.
I'm going to go out on the limb-o-cringe here and suggest that it would be nice to put a rotary encoder in the top left of the Macro columns. I personally get a lot of utility at having one close at hand.
A-a-ron
Offline PizzaForce
  • Eat me.
« Reply #41 on: Mon, 07 February 2022, 19:17:05 »
Colors good, price good, mount good, DB good, layout good. Board is good.
Fixed layout bottom row lets go.
Offline Kinesiologist
« Reply #42 on: Mon, 07 February 2022, 19:35:43 »
le nice
Offline Zeelobby
« Reply #43 on: Mon, 07 February 2022, 20:46:18 »
I like
Sent from my Pixel 3 XL using Tapatalk
Offline jubei
« Reply #44 on: Mon, 07 February 2022, 20:51:26 »
Topo weight oof le like
Offline JomiKarloz
« Reply #45 on: Mon, 07 February 2022, 21:18:15 »
Love the keyboard, love the name
GLWIC
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #46 on: Mon, 07 February 2022, 22:49:32 »
         me when i see le fishe
       //                        ___   ___
     (*)     "O"                /  _   _  \
   (*)    "O"                    |   |   |    |\
  //                             |O  |O  |___/  \     ++
 //                               \_/ \_/    \   | ++
//                              _/      __    \  \
/     /|   /\                  (________/ __   |_/
     / |  |  |                   (___      /   |    |\
    / /  /   |                     \     \|    |___/  |
   |  | |   /                       \_________      _/   ++++
/   /  |   |                               ++ /__/
Offline Tet
« Reply #47 on: Tue, 08 February 2022, 00:56:50 »
looking forward to this  :D
Offline Botty212
[IC] LeFishe | 65xt
« Reply #48 on: Tue, 08 February 2022, 01:13:08 »
shut up kameron
shut up hipster. just because you have no use for the key doesnt mean that others dont need it.
Offline xef
« Reply #49 on: Tue, 08 February 2022, 02:30:33 »
this makes me feel like a fish
