Author Topic: Best vfm keycaps?  (Read 7190 times)
Offline Cedific
Best vfm keycaps?
« on: Sun, 12 May 2019, 14:48:01 »
Meaning value for money. Looking to get a setup for trying out different switches, going for a hot-swappable and searching for some decent keycaps for it that are going to last through frequent switching around. I'm thinking it's best not to splurge on some 100€+ beautiful SA set for what is essentially a test-bed, so I was wondering what people's opinions on a solid, affordable set might be.
Offline lolafineday
Re: Best vfm keycaps?
« Reply #1 on: Mon, 13 May 2019, 08:57:53 »
Best value is EnjoyPBT, it’s around 100$ for a set and the quality is top. There is tai-Hao which is cheap and ok, but not value. I would get 1 epbt set instead of 2 taihao sets
« Reply #2 on: Mon, 13 May 2019, 21:56:52 »
Tai Hao is surprisingly good, and very low prices.
Try to get a set WITHOUT the anti-biotic coating on it.
Offline Cedific
« Reply #3 on: Tue, 14 May 2019, 00:45:46 »
EnjoyPBT seems the best vfm considering its top quality, but looking for a lower price-point in general. Will keep this excellent advice in mind for the next step which is going to be building a proper custom, no expenses spared.
So Tai Hao seems to be a good budget option. I've read around on this anti-biotic coating and how it takes away from proper cap feel, will look out for that.
I've found some pretty cheap Vortex keycaps which are PBT+POM (eg https://mykeyboard.eu/catalogue/vortex-ansi-pbtpom-double-shot-white-keycaps_41/), the price seems pretty low considering the materials. Is there some catch there?
Edit: Also, thoughts on YMDK keycaps on aliexpress?
« Last Edit: Tue, 14 May 2019, 02:31:10 by Cedific »
Offline Surefoot
« Reply #4 on: Tue, 14 May 2019, 03:48:01 »
I got only an XDA set from them, but was not too impressed with the thickness. Still it's decent quality, the dye sub is good enough, the spacebar is straight (it's a PBT set so it's not a given..).
They make the best keyset boxes though, both cheap and excellent (those 3 layer carboard boxes with neoprene cutouts), i bought a handful of those separately..
Offline Cedific
« Reply #5 on: Tue, 14 May 2019, 11:28:14 »
I see a YMDK set advertised as "1.5mm thickness". Is that thick or thin for a keycap? I've no idea lol.
« Reply #6 on: Tue, 14 May 2019, 22:00:32 »
I keep reading this thread title as "best VIM keycaps" :))
Offline Surefoot
« Reply #7 on: Wed, 15 May 2019, 02:34:56 »
That's about as think as you can go without going high profile (like SA / KAT etc. which can go to 1.6mm or almost 1.7mm). I think they sell various manufacturers outputs...
Offline Cedific
« Reply #8 on: Tue, 21 May 2019, 08:50:57 »
Cool, so as long as they're that thick they should probably be OK for a cheap set. Also, since you touched on high profile - is there such a thing as a cheap high-profile set? I certainly can't find any
Offline Surefoot
« Reply #9 on: Tue, 21 May 2019, 08:59:42 »
You can find some decently priced SA sets on KBDFans (the 'Chalk' set is PBT by the way) and zFrontier (Maxkey SA).
