Author Topic: [IC] Vintage Cable by SantiGo Updates New Colors Blue and Yellow  (Read 11882 times)
Offline SantiGo
GOOGLE FORM IC  -  https://docs.google.com/forms/d/1j1ry6HjhoogH9uQ40J3jkSN7OL2gvQF8Bf0OP1wGEoc/edit
New colors -
!!!!!!!Updates 25.05.2019 !!!!!!!!!
1. - We are thinking of making colors for Space Cadet, GMK Serik, Laser, Carbon (You can choose which color of coil and which straight end)
2. - We will most likely have new Avia connectors (we will also leave the old ones in R1)
3. Most likely we add our cases to USB from brass (colors will be Platinum Rose Gold and Polished Brass)...
Follow us in social networks and discord thanks
Watch me here:
Discord - https://discord.gg/6aDRytB
Instagram - https://www.instagram.com/santigo_customss/
FOTO - https://imgur.com/a/NXmHsaA
GH R1 - https://geekhack.org/index.php?topic=100009.0
Hello everyone :thumb: :thumb:
 ... And so we finished R1 on vintage cables .... We received a lot of positive feedback and suggestions .... The first thing I want to say is to everyone, thank you who entered the first round.
I will still have updates on the second round so watch me) BUT I CAN SAY EXACTLY WHAT WILL BE "PAUNDE WITH US" LASER cable ….
You motivate me even more to do something unusual.
And so what constitutes our cable.
We are doing it in Italy and wanted for a long time to repeat something like the OG cherry. But OG Chery for me were not flexible and can be said even as very tough…
I started testing the materials, it was a long road _) but I found what I wanted a GOOD thick cable with a good coil robot .... you can look at saw how it comes back without problems and does not stretch.
The size of my cable is Standard: L1 side keyboard connectors 20cm (8 inches)—--— Coil 30cm (12 inches) —--— L2 side PC connectors 1m ( 40 inches). Outer diameter: coils — 25mm  (1 inches), cable — 6.5mm (0.25  inches).
But as I said above, we make them ourselves and can make what size you need….
After 1 GB, a lot of people write what they would like to buy ... but since we produced only 70 of them, they bought out very quickly .. And I would like to do 2 round in the near future .....
the price of this cable will be 28 or 34 euros ... we will specify this later
I appreciate your every feedback and I will be glad if you can help me with this IC..
TEST COILS -
« Last Edit: Sat, 25 May 2019, 07:06:50 by SantiGo »
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
Re: [IC] Vintage Cable by SantiGo New color for LASER set
« Reply #1 on: Mon, 13 May 2019, 10:15:38 »
These are some very nice cables!  ;) Keep up the good work!
Just my thoughts
Offline SantiGo
« Reply #2 on: Mon, 13 May 2019, 12:08:22 »
 :thumb: thx man  )
Offline norb
« Reply #3 on: Wed, 15 May 2019, 11:32:36 »
can you do usb-c connector on the keyboard side? i'm not sure judging from the pictures, but it does look like usb c in some of them.
would def. be interested if i could customize the lenghts in my order.
Offline SantiGo
« Reply #4 on: Wed, 15 May 2019, 13:32:04 »
ye sure ) R1 I did this.....  :thumb: :cool:
Offline ian13
« Reply #5 on: Wed, 15 May 2019, 21:58:57 »
Is it possible to do a collab with other proxies in the US, Asia, and Oceania?
Offline SantiGo
« Reply #6 on: Thu, 16 May 2019, 05:21:47 »
 the United States can be and will do cheaper ...
Offline ian13
« Reply #7 on: Thu, 16 May 2019, 09:17:59 »
Nice! I think more people will be able to join if ever you decide to do it. Hoping that you can make it happen!
Offline iliketimex
« Reply #8 on: Thu, 16 May 2019, 11:04:29 »
In the interest check form ... what does the 1st answer refer to? Sorry if this is a dumb question. I am interested in this GB for a cable for an old NCR keyboard. Also a basic black cable. Nice work, I follow your IG.  :D
Offline Starius
« Reply #9 on: Thu, 16 May 2019, 12:38:17 »
SantiGo, is it possible for dark/navy blue to be an option in the future?
Offline SantiGo
« Reply #10 on: Thu, 16 May 2019, 16:12:41 »
I thought to make a cadet color for R2
Offline Starius
« Reply #11 on: Thu, 16 May 2019, 16:49:27 »
Yes, I think something nice to match Cadet/Symbiosis would be greatly appreciated!
Offline SantiGo
« Reply #12 on: Thu, 16 May 2019, 18:11:28 »
idk ) how pins need for NCR ? my cable have 5 pins
Offline SantiGo
Re: [IC] Vintage Cable by SantiGo Updates 20.05.2019
« Reply #13 on: Sun, 19 May 2019, 17:55:29 »
!!!!!!!Updates 20.05.2019 !!!!!!!!!
  :p :p :p :p
Offline rondg
« Reply #14 on: Tue, 21 May 2019, 20:30:22 »
Is it possible to purchase 1 cable (that connects to the computer) with multiple detachable ends (that connects to keyboards)?
Offline norb
« Reply #15 on: Wed, 22 May 2019, 06:15:43 »
will you also offer the other colors (white?) this time or only new colors?
Offline SantiGo
« Reply #16 on: Wed, 22 May 2019, 06:32:30 »
we will have around 8-10 colors everything that was in round 1 plus a few new pieces :thumb:
Offline SantiGo
« Reply #17 on: Wed, 22 May 2019, 06:34:03 »
Ye sure  i make eith Avia Connectors .. and i can go with all USB (Usb mini, Micro B, Type C 2.0) :cool:
Offline norb
« Reply #18 on: Wed, 22 May 2019, 07:09:04 »
nice, i guess i'll go for two then. looking forward to gb!  :thumb:
Offline SantiGo
« Reply #19 on: Wed, 22 May 2019, 08:15:37 »
Thank you man  :thumb: :cool:
« Reply #20 on: Wed, 22 May 2019, 08:17:34 »
If our board uses fixed cable can we get with just 1 USB end?
Offline SantiGo
« Reply #21 on: Wed, 22 May 2019, 11:17:51 »
Yes you can ) need only pm me  )
Offline Waateva
« Reply #22 on: Thu, 23 May 2019, 07:57:21 »
ok
Offline SantiGo
« Reply #23 on: Thu, 23 May 2019, 09:27:22 »
New Colors Blue and Yellow Add ++  :cool:
« Last Edit: Sat, 25 May 2019, 07:07:20 by SantiGo »
Offline SantiGo
Re: [IC] Vintage Cable by SantiGo Updates New Colors Blue and Yellow
« Reply #24 on: Sat, 25 May 2019, 07:07:35 »
 :thumb:
Offline phinix
« Reply #25 on: Sat, 06 July 2019, 16:51:31 »
It cool awesome, but I think you would need to get some proper plugs for it. Those shrinks look a bit... not professional.
Proper USB plugs would make it perfect.
