Author Topic: IBM Model M - Keyless  (Read 1281 times)
Offline caiko
« on: Thu, 16 May 2019, 08:42:10 »
Hi all,
Wondering if / how it would be possible to trigger keystrokes off of a IBM Model M without using the keys i.e. just the membrane connected to the logic board?
This does not seem to work just trying to finger the membrane!  :blank:
Greets
Caiko
Offline Techno Trousers
  • ʘ_ಠ
Re: IBM Model M - Keyless
« Reply #1 on: Fri, 17 May 2019, 06:38:39 »
If you look at the underside of the flipper, you'll see that there is a small nub. That nub tapping into the membrane in a certain spot is what triggers the keystroke. Maybe you could simulate it with a blunt pointed object of some kind.
