Author Topic: Any keysets that would go with a gray case that have 2u + 1u shift keys?  (Read 6938 times)
Offline mta
Trying to pick a set that would go well with a gray-case Tina-B (using Plate-A) which only supports e.g. 2u left shift with 1u right shift.
Any advice for which sets would fit the bill?
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
Maybe just DSA or DCS Blanks.
Just my thoughts
Offline Lanrefni
Kbdfans has a Dolch dye sub set that includes both 2u and 1 u Shift keys,should look great in a gray case.
Offline Sup
Why not get plate b  :-X?
current
Coming soon
Offline mta
Would need to buy another plate and introduce other compatibility issues (namely with the ? key since that spot becomes 1.75u).
Offline Sup
Ah you want that weird layout with the arrow keys. 2U Shift is like the rarest of rare of unusual key shapes. You can't find them in base sets only in separate kits and mostly are not widely available. Can't really think of one then getting blank DSA key caps. I would recommend to get a 65% if you want to have arrow keys and a good choice of key caps.
current
Coming soon
I know that G80-11900 and possibly also the Cherry G80-11800 have been manufactured with doubleshot white-on-black keycaps, and those two keyboards have a 2u right Shift.
I know I have had one from such a set, but I think I must have sold it a long time ago.
A 1u WoB Shift could be available from an Ortho kit in a more recent group buy.
« Last Edit: Wed, 22 May 2019, 08:28:37 by Findecanor »
