Author Topic: What is your favourite keyboard switch sound?  (Read 9830 times)
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« on: Thu, 23 May 2019, 17:51:15 »
What is your favourite sounding switch?
Personally, i cannot get enough of Cherry MX Blues, Cherry MX Reds and Alps(although i never tried them before, have seen people typing on it people and its heavenly  😇.)
Just my thoughts
Offline thearctican
Re: What is your favourite keyboard switch sound?
« Reply #1 on: Thu, 23 May 2019, 17:57:15 »
Holy pandas, creamios.
Offline eyedrop
« Reply #2 on: Thu, 23 May 2019, 18:01:19 »
Creamios = zealios stem in cream switch?
Sent from my Pixel 3 using Tapatalk
Offline Sintpinty
    • My Roblox Profile
« Reply #3 on: Thu, 23 May 2019, 18:01:54 »
I am not really an expert on this thing, so possibly 🤥
Just my thoughts
Offline Sintpinty
    • My Roblox Profile
« Reply #4 on: Thu, 23 May 2019, 18:02:15 »
I might see what "creamios" is
Just my thoughts
Offline Sintpinty
    • My Roblox Profile
« Reply #5 on: Thu, 23 May 2019, 18:02:59 »
Novelkeys Cream switches or Geekmaker Cream switches probably mixed in with zealios
Just my thoughts
Offline Techno Trousers
  • ʘ_ಠ
« Reply #6 on: Thu, 23 May 2019, 18:08:30 »
Based on sound only, SKCM Alps.
Offline Sintpinty
    • My Roblox Profile
« Reply #7 on: Thu, 23 May 2019, 18:09:13 »
Just my thoughts
Offline ArchDill
« Reply #8 on: Thu, 23 May 2019, 18:13:20 »
Lubed topre with Purple silent sliders...
Or... Linear on brass is nice. I am also really enjoying linear on PC.
  • Live long and prosper
« Reply #9 on: Thu, 23 May 2019, 18:24:16 »
IBM Model F
- end of thread -
tp thread is tp thread
Offline thearctican
« Reply #10 on: Thu, 23 May 2019, 18:47:43 »
Nailed it. Long Kailh cream stems in zeal housings. Lubed of course.
Offline eyedrop
« Reply #11 on: Thu, 23 May 2019, 18:49:17 »
So this is the other way around how I thought.  Cream stems in zealios housing.
Offline thearctican
« Reply #12 on: Thu, 23 May 2019, 19:38:02 »
Yep! The longer Kailh stem taps the bottom of the switch housing as you type!
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #13 on: Fri, 24 May 2019, 06:53:46 »
Alps SKCM/SKCL, nothing else even comes close :D .
Offline flurryvelvet
« Reply #14 on: Fri, 24 May 2019, 08:20:47 »
me too, chyros
Offline appaboy
« Reply #15 on: Fri, 24 May 2019, 08:22:44 »
Skcm damped cream is my favourite sounding switch . Not even close to my favourite feeling switch , unfortunately
PC Singa, MIR80, TX84se, g80-3314, g80-0427, g80-5000 + 5700, G80-3700, g81-3000 HBU (og wob)
HASRO keycaps
OG POM keycaps
SAI OG Italian dyesubs
Scarface Fn blank
Offline MafiaButter
  • "A child of the collosus of Armonk"
« Reply #16 on: Fri, 24 May 2019, 09:29:59 »
Any alps SKCM/L (Including the damped ones), Alps SKCP, capacitive / membrane buckling springs, box thick clicks, holy pandas, topre, etc.
There are so many good sounding switches that it's hard to choose between them. But I guess out of all of those nothing compares to SKCM. As Chyros has said, they are the "motherf***ing Beethoven" of mechanical switch designs.
u/Yeet9000 ~ r/mk | MafiaButter ~ Deskthority
Offline Sup
« Reply #17 on: Fri, 24 May 2019, 11:26:53 »
1. Topre
2. Alps
3. Lubed linear Gateron switches.
current
Coming soon
Offline Sintpinty
    • My Roblox Profile
« Reply #18 on: Fri, 24 May 2019, 14:14:14 »
:thumb:
Just my thoughts
Offline ollir_
« Reply #19 on: Fri, 24 May 2019, 15:16:47 »
Clicky alps and Topre please me the most.
Offline phinix
« Reply #20 on: Fri, 24 May 2019, 15:47:48 »
Silenced Topre with SA caps and lately Tealios v2, with ABS cherry keycaps set.
Don't know how brass plate can affect the sound, but I've ordered KBDFANS8X Mk2 with brass plate and will install Tealios on it and will see if that can sound even better.
« Reply #21 on: Fri, 24 May 2019, 21:25:51 »
I love the sound of my hypersphered and krytoxed hhkb bt.
Offline Sintpinty
    • My Roblox Profile
« Reply #22 on: Sat, 25 May 2019, 15:02:00 »
What is a hypersphered anyways?
Just my thoughts
Offline Gabbzan
« Reply #23 on: Sat, 25 May 2019, 16:01:02 »
ibm Beamspring, preferably with a solenoid
Offline packleadercho
« Reply #24 on: Sun, 26 May 2019, 04:23:00 »
It's a silencing method for Topre. Basically identical to Kbdfans' Silence X rings.
« Reply #25 on: Sun, 26 May 2019, 04:30:51 »
Favorite sound is Cherry MX Green. But favorite to type on / use daily. Topre Silenced Variable. 35/45
Offline befbef
« Reply #26 on: Mon, 27 May 2019, 04:59:39 »
Thought only Kailh Pro have the longer stem. Creams have 4mm travel in contrast to kailh pro with 3.6mm.
Are you sure that the Cream stems are longer or could you compare them to Kail Pro stems?
Offline killyou
« Reply #27 on: Mon, 27 May 2019, 05:57:16 »
I only use MX-type switches and so far I like Kailh BOX Clicky switches best (Pink, Jade and Navy, others not so much). I also like Zealio v2 sound but it's a bit too loud for tactile switch in my opinion.
Offline Aerizu
  • Professional Lurker
« Reply #28 on: Mon, 27 May 2019, 06:05:07 »
Linear: Creamios
Tactile: Topre
All lubed of course.
Offline Sintpinty
    • My Roblox Profile
« Reply #29 on: Mon, 27 May 2019, 10:40:38 »
Usually when you're typing, does it sound more crisp and clean on a mic or actually seeing you type in person?
Just my thoughts
Offline swedishpiehole
« Reply #30 on: Mon, 27 May 2019, 13:08:00 »
In my experience, the keycaps, case, and plate play a huge role in the sound a switch makes while typing. I have a YD68 with aluminum plate in an aluminum Tofu case with Aliaz switches and PMK PBT SA Ice Caps and the sound is *divine*. The switches themselves are quite silent, but the other parts in combination make for a soft, clean popping sound that is addictive. I tried to replicate this on a different aluminum case (enameled), with an aluminum plate and the same switches and keycaps, but it didn't sound nearly as nice. And if I put those same switches/keycaps on my Preonic in a wood case, they sound even worse.
P.S. My HHKB with Silence-X rings is my favorite typing sound though.
Offline macclack
  • The rhythm of the game
    • Macclack
« Reply #31 on: Mon, 27 May 2019, 23:06:59 »
In order: SKCM Alps, lubed Holy Pandas, silenced Topre, Zilents v1, lubed Box Blacks, lubed Cherry Blacks
Offline nelamvr6
« Reply #32 on: Tue, 28 May 2019, 00:25:36 »
I love my Topres, but my favorite sound has to be buckling spring. Mostly my Model F, but I love my Model M also.
Keychron Q6 w/ Zeal Clickiez | IBM Model F AT | Leopold FC660C | HHKB Type S
Offline Surefoot
« Reply #33 on: Tue, 28 May 2019, 04:01:33 »
Sound wise, the Khail Box Pale Blue are quite nice. Love the Gateron Ink and Novelkey Cream too.
Offline xondat
  • i'm not a star
« Reply #34 on: Tue, 28 May 2019, 04:12:43 »
Always wanted to do purple sliders... Never got round to it.
Linears in polycarbonate is super nice too, especially if 5mm.
Offline Sintpinty
    • My Roblox Profile
« Reply #35 on: Tue, 28 May 2019, 05:57:53 »
What does "dome with slider" or other things mean?
Just my thoughts
Offline Wojciech
« Reply #36 on: Mon, 03 June 2019, 03:17:53 »
SKCM Alps :)
« Reply #37 on: Mon, 03 June 2019, 03:26:23 »
Alps are obviously better, Cherry MX Blues sound like plastic Smith-Corona leaf springs.
Offline Warrenified
« Reply #38 on: Sat, 08 June 2019, 17:07:51 »
Topre... if people consider it one.
If not, properly lubed retooled blacks win me over everytime
Offline Sintpinty
    • My Roblox Profile
« Reply #39 on: Mon, 10 June 2019, 09:50:25 »
I also love razer greens for their clickiness. :V
Just my thoughts
Offline Venaros
« Reply #40 on: Fri, 14 June 2019, 10:12:36 »
Beamsprings, Lubed Holy Pandas, Blue Alps
Offline Sintpinty
    • My Roblox Profile
« Reply #41 on: Fri, 14 June 2019, 10:48:00 »
I actually have a deep love for Cherry MX Blues. If you fix the rattling on them they can feel and sound very nice.
Just my thoughts
Offline Venaros
« Reply #42 on: Fri, 14 June 2019, 13:02:45 »
By jailhousing?
Offline Sintpinty
    • My Roblox Profile
« Reply #43 on: Sat, 15 June 2019, 08:43:11 »
By jailhousing?
No just the regular switch. There isn't much for switch options in my area.
Just my thoughts
Offline Aelith
« Reply #44 on: Sat, 15 June 2019, 10:07:44 »
SKCL>SKCM>>Lubed Linears/Silenced EC>>>>>everything else
Especially I don’t like the sound of holy pandas... weird.
Offline Venaros
« Reply #45 on: Mon, 17 June 2019, 07:49:25 »
By jailhousing?
Then how did you fix the rattle on them? Or do you mean the stabs
