Author Topic: Swapping Razer Green stems with Cherry MX  (Read 1605 times)
Offline cheethamz17
« on: Thu, 30 May 2019, 20:53:00 »
Hi
So i have a Razer Orbweaver Chroma with Green switches, I bought cheap Chinese MX Cherry Brown switches and swapped in the stems, I wasnt 100% pleased with they way they felt so I bought some Cherry MX Red switches and tried swapping the stems again but found the stems sticking, as in totally stuck down when pressed. is it a dud batch/slightly wrong size etc or are the metal leaves different because it is made for green switches which are tactile and clicky vs red which are just linear.
Thanks in advance!
Re: Swapping Razer Green stems with Cherry MX
« Reply #1 on: Thu, 30 May 2019, 21:17:42 »
How did you swap the stems?
