Poll
What colors look nice?
Ultramarine Blue
31 (36%)
Grey
18 (20.9%)
Black
6 (7%)
Silver
8 (9.3%)
Magenta
11 (12.8%)
"E-white" (price increase)
12 (14%)
Total Members Voted: 86
Author Topic: [GB][Shipped] Fjell Round 4  (Read 109126 times)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« on: Fri, 31 May 2019, 13:01:58 »
Fjell Classic Round 4
Price
Price $300 including a mirror polished brass plate of your choice(ISO or ANSI).
Extra plates will cost $26 per kit, extra plates without extra kits will cost $40.
Shipping
It does cost a bit to send a 2 kg+ case with express around the world, so there might be some other shipping services available this time around. This will be announced when you go to check out, and find another option for shipping or not.
Updates
You will be able to completely remove the spacebar and middle mounting points. This is to ensure compability with hotswap PCBs, and for those that prefer a more flexible typing experience. The inserts will be made in brass or titanium, depending on results from factory testing.
Other updates:
slight mounting changes
slight USB hole changes
Launching in
June
_______
FAQ
What is this case?
It is a tray mount case for 60 percent mechanical keyboards that follow the standarized Poker mounting. It has a weight of 2kg, or approx. 4.4 lbs.
Why $300 for a tray mount case?
This cost as much, or more to produce than most other 60% cases, tray mount or top mount. The beveled edges takes time to get right, the weight design is complex and the amount of material in this case is quite unique.
How does it sound?
Typing test by Taeha Types
When does it ship?
2 months after GB end
How many units will be available?
About 100 units.
How long will the GB stay open for?
Depending on how fast things sell, usually a week or two.
Colors
Vote, and see.
It will be available on this following link:
https://mekanisk.co/collections/group-buys/products/fjell
« Last Edit: Sat, 08 February 2020, 14:44:25 by LeandreN »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [GB] Fjell Classic Round 4
« Reply #1 on: Fri, 31 May 2019, 13:07:45 »
Denne posten er reservert :D
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
« Reply #2 on: Sat, 01 June 2019, 05:26:20 »
Approved! Lykke til :D
Offline jaang
« Reply #3 on: Sat, 01 June 2019, 05:30:08 »
Very excited for this!
Offline Nevermore012
« Reply #4 on: Sat, 01 June 2019, 05:41:32 »
what pcb that you suggest for the case, is the dz60 rgb fit with the case??. Thanks
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #5 on: Sat, 01 June 2019, 06:08:54 »
Yes, it should fit fine.
Other PCBs that'll work:
Zeal60
GoN NERD60
GH60
I will compile a list of known PCBs in the OP later.
Offline Full
« Reply #6 on: Sat, 01 June 2019, 06:51:39 »
So hot <3
Hi!
Offline babooshka
« Reply #7 on: Sat, 01 June 2019, 08:02:41 »
Super excited for this!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #8 on: Sat, 01 June 2019, 08:03:03 »
Great, can't wait to launch this!
Offline HPE1000
  • Keycap Paparazzo
« Reply #9 on: Sat, 01 June 2019, 08:09:08 »
Looks great! Those removable mounts are really cool, even just from the standpoint that if you accidentally strip one of them they can just be swapped out without trying to retap.
« Reply #10 on: Sat, 01 June 2019, 08:18:18 »
thank you
Zeal60
GoN NERD60
GH60
Offline b3nkei
« Reply #11 on: Sat, 01 June 2019, 08:18:46 »
Do you have a sample of the clear anodizing? Is it similar to the silver one?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #12 on: Sat, 01 June 2019, 08:19:44 »
It's exactly the same.
Offline clik_clak
« Reply #13 on: Sat, 01 June 2019, 09:00:07 »
So its not actually clear? Clear ano would show off all the imperfections and markings from the manu process instead of covering them like a silver ano would.
It's probably going to make quite a difference between it actually being clear or actually being silver.
« Last Edit: Sat, 01 June 2019, 09:11:09 by clik_clak »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #14 on: Sat, 01 June 2019, 09:01:07 »
It's probably going to be matter quite a difference between it actually being clear or actually being silver.
I will change it so it's *clear* what I mean.
Thank you
Offline clik_clak
« Reply #15 on: Sat, 01 June 2019, 09:13:04 »
Thank you
no offense, but that doesn't clarify what it is...
Is it a clear or a silver anodizing? Is it going to cover the imperfections or is it going to show them off? Clear is not the same as a silver.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #16 on: Sat, 01 June 2019, 09:14:05 »
Thank you
It will be silver and without imperfections.
Offline vision-quest
« Reply #17 on: Sat, 01 June 2019, 10:12:00 »
All in! Will the pro be released at the same time? I don't know whether to wait for the pro because I don't exactly know what it is yet.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #18 on: Sat, 01 June 2019, 10:13:58 »
No it won't. The pro has no release date, but I will make an interest check later this week.
Offline clik_clak
« Reply #19 on: Sat, 01 June 2019, 10:35:54 »
Is there going to a limited edition like with the Klippe by chance?
« Reply #20 on: Sat, 01 June 2019, 10:37:26 »
Ok thank you, are you able to give any details about what separates the classic and the pro? I'm definitely going to be grabbing one, but I'd be hesitant to buy the classic in case the pro is more what I want..
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #21 on: Sat, 01 June 2019, 10:40:29 »
Yes there are major differences, I'll write a proper explanation for you tonight! Major difference is top mount vs tray mount.
« Reply #22 on: Sat, 01 June 2019, 11:29:26 »
Ok thanks, look forward to it  :thumb:
Offline Taurunil
« Reply #23 on: Sat, 01 June 2019, 14:32:50 »
big hype aaaaaaaaaaa
Offline juliandoucette
« Reply #24 on: Sat, 01 June 2019, 14:34:32 »
It's June now, but it's "NOT AVAILABLE" on your website. Has the exact release date not been announced yet or has it sold out already?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #25 on: Sat, 01 June 2019, 14:36:03 »
It will launch sometime in June and run for atleast 1-2 weeks.
Offline chive_
« Reply #26 on: Sat, 01 June 2019, 14:44:51 »
Super excited to grab one of these! Hoping grey ends up being one of the choices.
Offline Taurunil
« Reply #27 on: Sat, 01 June 2019, 15:01:21 »
« Reply #28 on: Sat, 01 June 2019, 16:19:14 »
What kind of grey is it? I always prefer the dark greys, lighter greys can look too silver.
Offline babooshka
« Reply #29 on: Sat, 01 June 2019, 16:21:25 »
Are there any renders available for these color choices?
Offline ProlificPanda
« Reply #30 on: Sat, 01 June 2019, 17:17:41 »
Bring back the purple!  :thumb:
Offline xondat
  • i'm not a star
« Reply #31 on: Sat, 01 June 2019, 17:20:58 »
Clear is silver. Silver is clear.
Cases are sandblasted and cleaned before anodizing, and that's when tool marks are removed.
Offline dav1k
« Reply #32 on: Sat, 01 June 2019, 17:46:33 »
I can't wait to own one of your products.
You literally cannot take my money quick enough my friend!
Looking forward to this one especially!
Offline chriszhu
  • (* ̄(エ) ̄*)''
« Reply #33 on: Sat, 01 June 2019, 18:06:10 »
Looking forward to this!
Offline ywcsam
« Reply #34 on: Sat, 01 June 2019, 23:34:03 »
Is the first render in Ultra Marine Blue? Or is it some kind of blue-green?
Offline loopaddiction
« Reply #35 on: Sun, 02 June 2019, 02:46:52 »
The Fjell in that popular Taeha video with GMK Oblivion...that's the black color, not grey, correct?
I hope black is available as an option regardless, can't really beat it compatibility wise. It works with nearly everything.
Originally I was going to wait for the Fjell Pro but it doesn't sound like that's coming out any time soon, so will definitely pick up a Classic. Excited.
Offline babooshka
« Reply #36 on: Sun, 02 June 2019, 02:50:37 »
I believe it was grey R1. But grey R1 is different from R2 or R3 i believe
Offline BigBabyJesus
« Reply #37 on: Sun, 02 June 2019, 02:52:28 »
I'm new to this. How can I vote? Or is it closed?
On topic:
Can't wait for the release! I've had your page open in a tab for a few weeks.
« Reply #38 on: Sun, 02 June 2019, 02:55:25 »
Thanks, I probably should of read the video description as it says it right there.
My #1 choice is black but if for whatever reason it's not going to be an option, a nice dark grey would be a good substitute.
Offline MuchXD
« Reply #39 on: Sun, 02 June 2019, 03:18:36 »
Id love to see the grey in its R1 colour. That being said, I don't see how I can vote.
Offline caronte0
« Reply #40 on: Sun, 02 June 2019, 05:46:07 »
Yes please bring it back!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #41 on: Sun, 02 June 2019, 05:55:55 »
Okay, R1 grey will return under the color name "dark grey". Will try to get it as similar as possible.
« Last Edit: Sun, 02 June 2019, 06:02:55 by LeandreN »
Offline caronte0
« Reply #42 on: Sun, 02 June 2019, 06:09:21 »
YAAAAAYYYYYYY. I LOVE YOU
Offline MuchXD
« Reply #43 on: Sun, 02 June 2019, 06:14:17 »
Your the best!
« Reply #44 on: Sun, 02 June 2019, 06:29:50 »
Thanks LeandreN!
Offline victorpre
« Reply #45 on: Sun, 02 June 2019, 06:42:00 »
So excited about this!!
Offline Extraxyz
« Reply #46 on: Sun, 02 June 2019, 10:32:42 »
This makes it an absolute no-brainer for me, will buy this the minute it opens.
« Reply #47 on: Sun, 02 June 2019, 10:44:19 »
<3
This and black would be amazing.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #48 on: Sun, 02 June 2019, 10:50:06 »
Some people have asked me if the R2, and later weight(top) is less difficult to manufacture than the R1 weight(bottom), and if it was done as a cost measure.
Not only is it really kind of similar, it has more material and more difficult machining.
Answer is, it is not cheaper to manufacture, it was done because I think it looks better and opens for more details on the weight.
« Last Edit: Sun, 02 June 2019, 10:56:01 by LeandreN »
Offline Mekuno
« Reply #49 on: Sun, 02 June 2019, 10:59:19 »
Possibility of a blue-gray fjell?
