Author Topic: [IC] ePBT SimpleJA - GB has begun  (Read 50434 times)
Offline SuddenlyDonkey
Re: [IC] ePBT SimpleJA - Samples shipped out
« Reply #100 on: Tue, 30 July 2019, 22:06:00 »
Do you know what pricing will be and how long the gb will run for?
I'll be finalizing price once everything is set kit-wise.
GB will likely run for 30 days or so, unless there is significant reason not to.
Are you happy with the samples?  The renders look a lot warmer while the samples look mostly flat gray and white
Offline ai03
  • I do not reply to PMs; contact me via website
    • Website
« Reply #101 on: Wed, 31 July 2019, 01:02:56 »
The samples have yet to arrive
My spec to epbt was to use their generic white/beige colorway, so I'd say it turned out exactly as expected.
Offline forelsket
« Reply #102 on: Wed, 31 July 2019, 04:40:19 »
everything about this set is perfect. count me in!
Offline ai03
    • Website
Re: [IC] ePBT SimpleJA - Samples have arrived
« Reply #103 on: Thu, 01 August 2019, 21:05:26 »
Some quick eyecandy.
GB will begin as soon as pricing is set.
Offline Boy_314
« Reply #104 on: Thu, 01 August 2019, 21:15:53 »
Can you slip in support for the following from top down 65% column: Home, PgUp, PgDn, End
I think it currently supports Home, End, PgUp, PgDn
« Reply #105 on: Thu, 01 August 2019, 21:20:49 »
 ;D woot!  Looks great
Offline Tom_Kazansky
  • Oblivion Knight
« Reply #106 on: Thu, 01 August 2019, 22:06:46 »
look great!!!  :thumb:
we can't have all the combinations, can we? :-\
Offline Boy_314
« Reply #107 on: Thu, 01 August 2019, 22:08:27 »
haha I know, it was offered in kuro/shiro which was also epbt, and also offered in gmk, so I figured I might as well ask :p
Offline hammerbrotha
« Reply #108 on: Thu, 01 August 2019, 22:24:06 »
oh man i can't wait, these samples look awesome.
Offline ai03
    • Website
Re: [IC] ePBT SimpleJA - GB has begun
« Reply #109 on: Fri, 02 August 2019, 06:58:09 »
And out of the blue, the GB has begun.
GB thread prepared; maybe it'll get approved before GB ends.
« Last Edit: Fri, 02 August 2019, 08:27:03 by ai03 »
Offline Sup
« Reply #110 on: Fri, 02 August 2019, 07:26:39 »
Oof this is a special set joined for sure  :)
current
Coming soon
« Reply #111 on: Fri, 02 August 2019, 09:09:38 »
Made my purchase, thanks
Offline rockydbull
« Reply #112 on: Fri, 02 August 2019, 09:24:07 »
on the kbdfans website it says the split spacebars are convex. Does that mean they will be normal spacebar shape and not the shape of shift keys?
« Reply #113 on: Fri, 02 August 2019, 18:03:32 »
GB Prices are lower than i expected, easy buy!! :cool:
Offline 1corazon
« Reply #114 on: Sat, 03 August 2019, 08:17:52 »
PAID !!!!! Cant wait to get this, THANK YOU AGAIN!!!!!!!!!!!
Love this Set!!!
Offline ai03
    • Website
« Reply #115 on: Tue, 06 August 2019, 07:53:07 »
GB thread is approved.
For future discussion, please use the thread located here.
