Author Topic: [IC] ePBT SimpleJA - GB has begun  (Read 50433 times)
Offline ai03
  • I do not reply to PMs; contact me via website
    • Website
« on: Fri, 31 May 2019, 19:23:32 »
SimpleJA
Current status: GB is live; GB thread here.
SimpleJA attempts to recreate the vintage "cross-positioned" legends which were common on many vintage Japanese keyboards.
Many hours of research were conducted to create legends that are as genuine to the originals as possible.
Historically used legends from vintage boards were implemented wherever possible; those that did not exist were crafted carefully to match the others.
Design Decisions
The basic white/beige color scheme was chosen as a neutral colorway that matches both the vintage style of the keyset as well as newer sleek keyboards.
The modifier keys were kept all-Japanese for a uniform look.
Kits
Base Kit
Enough keys to fill most form factors below TKL size.
Spacebars Kit
1x 6U Convex
2x 3U Convex
1x 2.75U Convex
1x 2.25U Convex
1x 2U Convex
2x 1.5U Convex
2x 1U
Numpad Kit
Keys to fill a numpad, whether regular, all-1U, or part of a 1800 layout.
The order of the 1U modifiers are based on the style found on the NEC PC-8801 and PC-9801 series.
Ortho Kit
Many 1U keys which can help fill ortholinear and smaller ergonomic boards.
Function Kit
Includes both a vertical M1-M10 cluster for XT/AT inspired layouts, as well as a F13-F24 cluster for 122-key inspired battleships.
Renders
The legends in the renders appear a tad thinner than the source graphic for some reason.
Timeline
Once samples are confirmed and pricing is set, GB will begin.
Push updates
If you would like to receive push updates for the project, please join my Discord server and obtain the simple-ja role by running the following command: .iam SimpleJA
« Last Edit: Tue, 06 August 2019, 07:52:33 by ai03 »
Offline ai03
    • Website
Re: [IC] SimpleJA - Vintage-Styled Japanese Keyset
« Reply #1 on: Fri, 31 May 2019, 19:23:46 »
FAQ
Q. Who will produce this keyset?
A. Likely EnjoyPBT. I still need to get quotes and all if there is enough interest.
Q. How much will it cost?
A. Unknown as of now, although I'll guesstimate that it'll be close to existing ePBT sets. If there seems to be enough interest, I'll grab a quote and report back.
Q. What keyboards did you reference for the legends?
A. Quite a few. Mainly the NEC PC-82/88/9801 series, Sharp X1/68000, Fujitsu FM-Towns, Oasys, and various others.
Q. I don't like the winkeys. Can I use something else in its place?
A. The 拡張機能 (Extended Functionality) keys will likely be the best replacement.
Q. Why are there so few convex keys in the spacebar kit?
A. Mainly due to ePBT mold limitations.
Q. Will there be other colorways available for the legends later?
A. Possibly in the future, but for now I'll stick to the milk white/beige coloring.
Q. Why is the row numbering on the kit images reversed?
A. For some reason, ePBT numbers them that way, reverse of the usual.
Q. Why are <insert keys> missing?
A. Because I'm terribly uneducated regarding keyset compat beyond the typical ANSI. If I'm missing something obvious, please let me know and I'll add it in ASAP.
Q. What boards are those in the renders?
A. Polaris and KBD8X MKII.
Q. Are the F13-F24 keys in the function kit really necessary?
A. Yes.
« Last Edit: Fri, 31 May 2019, 19:30:10 by ai03 »
Offline Pwner
  • soon™
« Reply #2 on: Fri, 31 May 2019, 19:24:27 »
Yes
Offline fcoury
« Reply #3 on: Fri, 31 May 2019, 19:26:40 »
Love it. There's a Leopold vibe to the legend proportions that I really dig.
Offline Paddel06
  • Klugscheißer
« Reply #4 on: Fri, 31 May 2019, 19:27:02 »
Finally a set with the bottom ろ!
This is a signature.
Offline jaang
« Reply #5 on: Fri, 31 May 2019, 19:28:13 »
Excited for this, can't wait!
Offline KawabataLuis
« Reply #6 on: Fri, 31 May 2019, 19:33:01 »
Count me in :D
Offline InvidiousIgnoramus
« Reply #7 on: Fri, 31 May 2019, 19:33:23 »
I'm setting aside money immediately. That function kit is an absolute deal breaker for me, finally being able to have function columns with proper rowing. Accurate legends is a major plus too!
I long for the day when I find a beamspring. (At a not insane price)
Offline .Udon
« Reply #8 on: Fri, 31 May 2019, 19:38:32 »
GB when
Offline _ODIN_
« Reply #9 on: Fri, 31 May 2019, 19:56:16 »
Very nice, highly interested.
Gesendet von meinem H8416 mit Tapatalk
Offline Capsy
« Reply #10 on: Fri, 31 May 2019, 20:17:57 »
Well that's some entry into keyset design Ai
Offline Tom_Kazansky
  • Oblivion Knight
« Reply #11 on: Fri, 31 May 2019, 20:30:40 »
vertical functions keys...
Numpad: 1u Enter, "," key
 :eek: ohohohohohohoh
this set match so well with my upcoming board
guess I'm buying everything except ortho...  :-X
« Last Edit: Sat, 01 June 2019, 02:42:17 by Tom_Kazansky »
Offline ullr
« Reply #12 on: Fri, 31 May 2019, 21:49:00 »
I'm in, looks great OP. Love the JIS support.
Offline barkerjames
« Reply #13 on: Fri, 31 May 2019, 22:30:42 »
LOVE
Offline macclack
  • The rhythm of the game
    • Macclack
« Reply #14 on: Fri, 31 May 2019, 22:34:06 »
So clean. Definitely in.
Offline pixelpusher
« Reply #15 on: Fri, 31 May 2019, 22:37:14 »
I mean, if I can get like 4 of each stabilized key included in the base set for when they don't fit properly on the stabilizers
P.S... can we get these in GMK instead? :)
« Last Edit: Fri, 31 May 2019, 22:40:45 by pixelpusher »
Offline ai03
    • Website
« Reply #16 on: Fri, 31 May 2019, 22:51:46 »
Sure; if you pay the several hundred thousand dollars for the molds, I'll happily do it for you
Offline pixelpusher
« Reply #17 on: Fri, 31 May 2019, 22:55:18 »
I wish there was some way to fix the darn stabilized keys.  I've got 3 sets of ePBT that I can't use.  They look and feel nice, but I kinda need my space bar to come back up after I press it down :(
Offline ai03
    • Website
« Reply #18 on: Fri, 31 May 2019, 23:20:51 »
1. Heat spacebar with hairdryer until somewhat pliable
2. Ever so slightly overbend beyond neutral
3. Dunk into cold water or under running water, retaining the shape
4. Dry completely. Enjoy
Offline smoian
« Reply #19 on: Sat, 01 June 2019, 00:21:22 »
I really like this!
Offline nguyenhimself
« Reply #20 on: Sat, 01 June 2019, 00:22:37 »
Heh, accidental kaomoji.
I'm in. This is the sort of wacky-yet-classic sets that ẸnoyPBT should be known for. Keep it weird!
« Last Edit: Sat, 01 June 2019, 01:24:55 by nguyenhimself »
« Reply #21 on: Sat, 01 June 2019, 01:29:55 »
[deleted upon reconsideration]
« Last Edit: Sat, 01 June 2019, 12:33:32 by nguyenhimself »
Offline hpdung99
« Reply #22 on: Sat, 01 June 2019, 07:20:23 »
Finally JIS support xD
Offline ddnomad
« Reply #23 on: Sat, 01 June 2019, 09:03:03 »
Do like the keyset! Looking forward to the GB.
Offline Nigolski
« Reply #24 on: Sat, 01 June 2019, 16:23:02 »
very interested!
Offline pixelpusher
« Reply #25 on: Sat, 01 June 2019, 19:53:26 »
The space bars I have from my slate set are all perfectly flat. If you measure from stem to stem they are about ~1mm off.  Flatness isn’t the issue for me
Offline hpdung99
« Reply #26 on: Sat, 01 June 2019, 23:33:07 »
Since this is kind of a JIS support set, is there any chance that we can get a 4.5u spacebar?
Also because I'm not so sure, is the current set fully support a minila air JIS?
Offline ai03
    • Website
« Reply #27 on: Sat, 01 June 2019, 23:39:21 »
I'm pretty sure that EnjoyPBT doesn't own all of the molds required for full JIS bottom row.
Offline senryo
  • Problems are challenges.
    • Thic Thock
« Reply #28 on: Sun, 02 June 2019, 00:32:50 »
Will there be 9009 themed accents to match this color?
Offline RSC
« Reply #29 on: Sun, 02 June 2019, 05:20:54 »
101% in for this! Looks amazing.
Offline stoic-lemon
« Reply #30 on: Sun, 02 June 2019, 08:51:55 »
This is really cool.
Offline dantambok
« Reply #31 on: Sun, 02 June 2019, 09:29:49 »
100% in baby!
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
Offline voight-kampff
« Reply #32 on: Sun, 02 June 2019, 09:41:57 »
very nice
Offline equalunique
« Reply #33 on: Sun, 02 June 2019, 11:45:30 »
This set meets so many of my requirements, it's pretty amazing!
To completely work on Filco JIS boards, it's gonna need a 4.5u spacebar: https://imgur.com/a/kBFKi7j
Sent from my LG-H918 using Tapatalk
Offline ullr
« Reply #34 on: Sun, 02 June 2019, 12:02:33 »
Unfortunately I don't think that Enjoy PBT has 4.5u or 2.5u space bars that so many JIS boards use. I wonder if there isn't some other manufacturer they could be sourced from, though.
Offline equalunique
« Reply #35 on: Sun, 02 June 2019, 12:44:20 »
Well, maybe they'll see the interest here, and decide to make some? They went ahead and created 3u convex spacebars. Both 2.5u & 4.5u would follow a similar process.
If not then I will go with SA 128K since SP already has the necessary molds for a bottom now - they've done it already for Filco's fullsize and TKL JIS boards. The likleyhood of compatibility is higher, but unfortunately not cherry profile.
« Reply #36 on: Sun, 02 June 2019, 13:18:10 »
I imagine, ROI-wise, it’d be a hard sell for them.
The 3.0u’s mold exists because the Filco Minila Air is a big hit in various Asian countries, including China.
It’s practically the main reason why every set needs a 3.0u keycap.
Only Japanese folks use JIS, and judging from the recent Tokyo meetup, they don’t seem to mind non-JIS layouts.
« Last Edit: Sun, 02 June 2019, 19:59:49 by nguyenhimself »
Offline Genuine.Senpai
« Reply #37 on: Sun, 02 June 2019, 14:16:41 »
Bookmarked this thread for an hopeful update. I'd buy it.
Offline Emir
  • icon mods
  • Bandit
    • Discord
« Reply #38 on: Sun, 02 June 2019, 14:38:58 »
Kind of difficult to pass up, let's get it
Offline Blank
« Reply #39 on: Sun, 02 June 2019, 15:23:43 »
must have
Offline ai03
    • Website
« Reply #40 on: Sun, 02 June 2019, 17:06:49 »
Seems like there's enough positive feedback so far to go ahead; I'll tune up the kits and send it into ePBT for a quote.
Offline barrel
« Reply #41 on: Sun, 02 June 2019, 17:32:09 »
Surely in such a beautiful Japanese Keyset we can't be missing out on JIS Support, can we? There's basically two kinds of JIS You'd actually have to cater to; Realforce JIS (Proper JIS) and HHKB JP (Lots of 1Us)
Here is a picture of a Realforce JIS Board, I'll get accurate key sizes in a little bit.
Meanwhile, here is a picture of a HHKB Type JP, something I know a few people here have with Novatouch stems who would most likely love your set.
Generally you need a 1U backspace, a Yen key on the top row, two 1.25U keys for changing scripts and 4.75U Spacebar (I think) for JIS.
Offline vexl
« Reply #42 on: Sun, 02 June 2019, 17:45:48 »
this looks awesome, i'm interested
« Reply #43 on: Sun, 02 June 2019, 20:00:48 »
This is not a Topre set though?
Offline ullr
« Reply #44 on: Sun, 02 June 2019, 21:30:41 »
Customs occasionally support JIS right shift (GH60, Clueboard, Noxary 268 pcb but not plate - off the top of my head) but much more rarely a bottom row with enough keys for a JIS layout, and the vast majority of mass produced JIS keyboards have spacebars that don't really exist in custom sets (2.5u, 4.5u). To me it makes sense to compromise most on the bottom row for this reason. It appears that there are at least just enough 1u and 1.25u keys though? There aren't enough 1.5u keys for some other Realforce layouts on the other hand.
« Reply #45 on: Mon, 03 June 2019, 00:29:27 »
Regarding the colours, personally I would prefer a greyish set, there are guite a few beige kits with japanese sublegends already.
Sent from my MIX using Tapatalk
Offline stoic-lemon
« Reply #46 on: Mon, 03 June 2019, 06:16:07 »
I'd say ai03 is pretty familiar with Japanese keysets.
Offline Pheyn
« Reply #47 on: Mon, 03 June 2019, 11:06:12 »
+1 for this. I mean, I'm probably still in even if it ends up beige. But if you look at all the epbt sets out there, like 90% are beige so I'd be down for a more granite/muted look instead.
Offline barrel
« Reply #48 on: Mon, 03 June 2019, 11:44:33 »
Plenty of people use Novatouch or JTK MX Compatible stems on those boards and wat something that fits into a Japanese aesthetic, it's also more options in terms of split spacebar layouts, I just happened to choose Topre boards because they're what I wanted to show it off on.
Offline riesz
« Reply #49 on: Mon, 03 June 2019, 18:34:24 »
Very interested if this stays PBT.
