Author Topic: M4-1 in Ivory or Black  (Read 3884 times)
Offline didjamatic
« on: Mon, 24 May 2010, 13:28:32 »
BON has some M4-1's in Ivory and Black.
Offline ch_123
« Reply #1 on: Mon, 24 May 2010, 14:05:03 »
Used to sell the black ones for about $30-40...  $60 is a bit too much for what they are.
Offline ch_123
« Reply #2 on: Mon, 24 May 2010, 14:27:18 »
The difference is that something like this is probably a better overall proposition -
Offline ch_123
« Reply #3 on: Mon, 24 May 2010, 17:55:35 »
This is the newer version which, AFAIK, has been quite well received.
EDIT: Sounds like it has some pretty serious issues... One of the reviews tried to refute some of the negative reviews by saying "I'm an average typist who types at 40WPM so I don't think [the above issues] are relative for most people"
Designed by idiots for idiots it seems...
« Last Edit: Mon, 24 May 2010, 17:59:04 by ch_123 »
Offline Laggy-gaga
« Reply #4 on: Mon, 24 May 2010, 19:57:45 »
why he black one is more expensive than the Ivory one?
the cable adress a better condition than the black one
Working: Ducky Dragon Blue
Looking for: 356L
For sale:Benchmark DAC1+Stello U3+Amber,RS1i,GS1000i,HE400,HD650,w4r,se535LE
AU only
Offline J888www
« Reply #5 on: Mon, 24 May 2010, 20:06:49 »
Demand, most poeple prefer the Black.
Often outspoken, please forgive any cause for offense.
Thank you all in GH for reading.
Keyboards & Pointing Devices :-
[/FONT]One Too Many[/COLOR]
Offline kcsaff
« Reply #6 on: Wed, 26 May 2010, 00:42:17 »
Hmm, I think I'll stick to my plan of chopping up an M2 and sticking in a custom controller.
Offline EverythingIBM
« Reply #7 on: Fri, 28 May 2010, 14:58:37 »
« Reply #8 on: Fri, 28 May 2010, 15:02:10 »
Quote from: ripster;187725
Black one sold.
Good taste.
No bad taste. The black ones get shiny easier, they're harder to see, and you waste more money for a mediocre small form keyboard.
Offline ch_123
« Reply #9 on: Fri, 28 May 2010, 15:49:07 »
If anyone wants a black one in good condition, let me know.
« Reply #10 on: Fri, 28 May 2010, 17:25:51 »
Quote from: ch_123;187763
I may consider buying it if you'll sell it like for $10 lol. It wouldn't be worth more than that to me.
Although, isn't unicomp making buckling spring versions of those? You could keep your IBM case and pop buckling spring internals in it.
EDIT: nevermind, I'm just going crazy.
« Last Edit: Sun, 30 May 2010, 19:49:22 by EverythingIBM »
