Author Topic: HHKB pro Bluetooth - Black or White?  (Read 2585 times)
Offline donnghia
« on: Thu, 13 June 2019, 12:13:23 »
I prefer the look of White over Black since it look brighter and more attractive,
but the problem is that many of HHKB White case I saw on photo get stains and the bright-white colour become Yellow after 1-2 years using. Anyone here facing the same problem? do you recommend to buy the White Case or Black Case?
or just buy the black and then change the White keycap to avoid stain in the future? I wanna keep it for long time using..
thanks alot.
Offline barcher
Re: HHKB pro Bluetooth - Black or White?
« Reply #1 on: Thu, 13 June 2019, 14:18:03 »
That is what I did.  I bought black keyboards..changed them to bluetooth and put white caps on them...I have 2 of them!!  I might even consider selling one!
Offline rxc92
« Reply #2 on: Thu, 13 June 2019, 15:20:37 »
I'm not sure what causes the stains, it could be smoking or just keeping dirty stuff around the keyboard. I've had a white Realforce for a long time now and it hasn't changed in color at all, still ivory.
Offline ArchDill
« Reply #3 on: Thu, 13 June 2019, 16:52:08 »
I travel with my hhkb bt a lot so I opted for the black. I have beige EnjoyPBT JP caps on it and I love the way it looks.
« Reply #4 on: Thu, 13 June 2019, 20:13:26 »
I've always preferred black hhkbs with white printed caps.
Offline nguyenhimself
« Reply #5 on: Fri, 14 June 2019, 00:01:52 »
Buy the black one, then buy the white keycap set from eBay (60 bucks or so IIRC).
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #6 on: Mon, 17 June 2019, 08:58:34 »
thanks alot.
White on black looks cool...
Doesn't really matter tbh, but black is a "humble flex" to confuse co workers that you have a regular keyboard
Just my thoughts
