Author Topic: source of non-offset MX bottom row double shots?  (Read 5539 times)
Offline ruumis
« on: Wed, 26 May 2010, 11:34:18 »
I recently acquired a Cherry G80-3000LSCRC-2 and wanted to swap its laser-etched keys with double-shots from a black G81-8000HPBUS-2 / 03.
Earlier today I finally completed the swap (my first!). Had a scary little crash course in working with the different stabilizers for both MY and MX, but nothing broke!
The only part that stinks is that the offset double-shot keys on the bottom row don't fit on the G80-3000LSCRC-2. I don't really care about the space bar, obviously. But the Ctrl, alt, windows and menu keys would be nice to have as centered double-shots. Any thoughts on inexpensive sources?
______________________
IBM Model M (82G2383) | IBM Model M (51G8572) | Apple Extended Keyboard 1 (M0115) | ABS M1 (x2) | Dell AT101W white | Dell QuietKey RT7D5JTW black | Cherry G80-3000LSCRC-2 w/double-shots from a G81-8000HPBUS-2 / 03
Offline itlnstln
« Reply #1 on: Wed, 26 May 2010, 16:30:31 »
I like it.  I can't wait to see if Elite can stock some custom caps.
Offline ricercar
  • mostly abides
« Reply #2 on: Wed, 26 May 2010, 17:47:49 »
ripster, did you find double shot control and alt keys in the center post 1.5 wide configuration?
Nevermind. Yes. Duh. I own one of those 8200HPDUS based boards.
« Last Edit: Wed, 26 May 2010, 17:55:38 by ricercar »
Offline ruumis
« Reply #3 on: Wed, 26 May 2010, 19:56:45 »
Quote from: ripster;187193
still no sign of Windows or AppKey double shots.
I guess I should be happy with what I've got. There's no more Chinese lettering anywhere on the board, and 96% of the total key surfaces are now smooth, non-scratchy double shots. Plus, the donor board was a freebie. I can't really complain.
Offline kriminal
« Reply #4 on: Thu, 27 May 2010, 09:01:25 »
The "AntiOtaku Filco Mod" has several Cherry donor boards and their order codes.
Latest rev.
Not cheap though.  And still no sign of Windows or AppKey double shots.
i have the 8200HPDUS like ricercar now i just need backslash, enter and arrow keys..
oh and a spacebar...
Geekhacked Filco FKBN87M/EB modified with Brown, black and blue cherries, doubleshot keycaps
Deck KBA-BL82 with Black cherries
Cherry G84-4100LCMDK-0 Cherry ML switches
Cherry G80-8200hpdus-2 Brown cherries
IBM Lexmark 51G8572 Model M Keyboard
Geekhacked Siig Minitouch KB1948
IBM Model M Mini 1397681
