Author Topic: Keyboard Beeping When Num Lock Pressed.  (Read 2007 times)
Offline Dennis90
  • Tech Geek
« on: Tue, 18 June 2019, 08:24:04 »
Hi friends,
My keyboard start to beep when the num lock is pressed. What might be causing the issue? Seems funny, but it's kinda annoying.
Re: Keyboard Beeping When Num Lock Pressed.
« Reply #1 on: Tue, 18 June 2019, 08:49:31 »
Check your ease of access settings, make sure 'Turn on Toggle Keys' is unchecked.
Offline Dennis90
  • Tech Geek
« Reply #2 on: Wed, 19 June 2019, 07:17:26 »
Thanks for the quick response. Any idea if this [redacted] might be of any use?
« Last Edit: Wed, 19 June 2019, 09:42:04 by HoffmanMyster »
