Author Topic: [help] Problem with keyboard usb enumeration - need to replug the keyboard.  (Read 1760 times)
Offline Quteno
I own a Durgod K320 Taurus, no backlight, pretty sweet keyboard, but it has problem with the usb enumeration, I need to either set the ErP settings in bios to keep delivering power to USB ports even when the PC is powered down, or replug the keyboard after each time I turn on the PC and log to Windows to have it recognized. The ErP setting isn't a problem, but it's more of a work around than a solution, also when you enter the mobo bios it still requires a replug even with the ErP setting.
Sadly the keyboard came from KPRepublic, therefore returning it is not an option.
I am wondering if simply replacing the USB module would fix it? And if yes, any advice where to order one? Would something like this be enough https://kprepublic.com/products/hot-swapping-usb-module-dip-usb-mini-prot-for-keycool-71-84-87-104-108-rgb-usb-bus looks similar to the original https://hd.tudocdn.net/790312?w=660&h=436 ? Or does it need to be specific for the keyboard model?
