Author Topic: CA66 .dwg plate file to .stl for Printing  (Read 8333 times)
Offline EvilemX8
« on: Thu, 20 June 2019, 17:49:13 »
Hey all,
I have a CA66 plate.dwg file that I am trying to convert to an .stl file for 3D printing. However, I'm having a lot of trouble actually making it a 3D object in AutoCAD and printing it out. I was wondering if anyone could help me out with this? Thanks!
Offline Kilgarah
Re: CA66 .dwg plate file to .stl for Printing
« Reply #1 on: Thu, 20 June 2019, 18:01:13 »
Import it into Fusion360 and then extrude it. Convert the body to a component and export the component as an STL.
Offline Legonut
« Reply #2 on: Fri, 12 July 2019, 23:45:19 »
To expand on Kilgarah, you'll probably need to split the plate into two halves to fit it into your printer. I also recommend adding some reinforcement bars to the plate, you can make a grid of 4mm thick bars vertically and horizontally to make the plate much stronger (up to 5mm total thickness).
