Author Topic: HHK caps lock key and stop key  (Read 2243 times)
Offline d-blank
« on: Thu, 27 May 2010, 21:28:33 »
anyone knows how to caps lock under the HHK mode?
under the HHK mode, when press fn key what is that stop key for?
Thanks in advance
Offline ch_123
« Reply #1 on: Fri, 28 May 2010, 04:17:04 »
Fn + Tab for Caps Lock
Offline d-blank
« Reply #2 on: Fri, 28 May 2010, 10:35:22 »
does your HKKB come with chart? mine doesn't.
Offline itlnstln
« Reply #3 on: Fri, 28 May 2010, 10:41:06 »
Is your HHKB blank?  If not, the functions are on the front of the keys.  I bought the lettered version for this reason alone.
Offline itlnstln
« Reply #4 on: Fri, 28 May 2010, 12:42:37 »
Mine came with instructions, but I don't remember a chart.  I wouldn't have used it anyway.
Offline ch_123
« Reply #5 on: Fri, 28 May 2010, 12:53:24 »
Sounds like some sort of Mac thing.
Offline d-blank
« Reply #6 on: Fri, 28 May 2010, 18:35:01 »
mine come with instruction, but no chart..
