Author Topic: [GB] BIOI G60BLE 60% PCB  (Read 71254 times)
Offline PlayKeyboardTW
    • Shop
« on: Fri, 28 June 2019, 08:49:25 »
Hello community!
Introduce you another bluetooth 60% custom PCB by Scott Wei.
BIOI G60BLE PCB was originated from Scott's G60 keyboard kit. The bluetooth PCB was combined with a mother board and a daughter. After some modifications, it become a bluetooth PCB with general specifications suitable for stock 60% keyboard parts.
Full Album: https://imgur.com/a/KnU0SdR
Content:
  • PCB
  • Two SH to PH adapter cables with inverted sequences
  • SMD LED for a charging indicator position
Features:
  • QMK firmware
  • USB C connector
  • BT4.0, available on most devices and systems like Win10, iPad and iPhone. Super power saving.
  • 1.0mm SH connector for battery socket
  • VIA Configurator supported (Thanks for help from Wilba and Olivia)
BIOI G60BLE PCB will come with two PCB versions in this groupbuy. A default one which you have to solder switches, and a hotswap one for easier installation.
Default (55USD):
  • South facing LED position
  • Multi layout support
Hotswap (60USD):
  • North facing LED position
  • Kailh hotswap sockets
  • 7u Spacebar layout only
GB link: https://play-keyboard.store/products/copy-of-play-keyboard60-pcb
GB Period: 2019.6.24 ~ 2019.7.10
Scott Wei's Instagram: https://www.instagram.com/scott_wei
PS.
  • If you have joined G60 custom keyboard kit groupbuy and you want to purchase this item, please contact scot.wei@gmail.com directly.
  • If you need assembly service for getting a full built board with this PCB, please contact our customer service.
Please feel free to leave comments if you have any question to this product.
Thanks! :thumb:
« Last Edit: Mon, 01 July 2019, 08:56:31 by PlayKeyboardTW »
    • Shop
Re: [GB] BIOI G60BLE 60% PCB
« Reply #1 on: Sun, 30 June 2019, 03:39:08 »
Reserved.
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
« Reply #2 on: Sun, 30 June 2019, 11:13:11 »
Approved, best of luck with the GB!
Offline nguyenhimself
« Reply #3 on: Sun, 30 June 2019, 12:00:12 »
My kingdom for Alps support.
That:d be my endgame.
Just... think about it.
Offline KingOfMemes
« Reply #4 on: Sun, 30 June 2019, 12:47:15 »
What batteries do I need to use with this
Offline TuCZnak
« Reply #5 on: Sun, 30 June 2019, 13:07:37 »
Your hotswap layout picture is wrong...
Offline pan
    • Massdrop
« Reply #6 on: Sun, 30 June 2019, 15:29:50 »
Yeees, I've been wishing I had ordered an extra PCB with the G60 GB, and now I can
Sent from my Pixel 3 XL using Tapatalk
RAMA U80-A Milk, Holy Panda, GMK9009
Waiting on:
G60 NCR
Offline dhb82
« Reply #7 on: Sun, 30 June 2019, 15:30:21 »
Maybe im an idiot who can't find this information, but does the hotswap version also support ISO ?
Offline 8six753o9
« Reply #8 on: Sun, 30 June 2019, 16:10:16 »
I think the Bluetooth layout is supposed to be this:
Offline Lyle88
« Reply #9 on: Sun, 30 June 2019, 17:05:31 »
I am also confused about what the hotswap version supports.
Will I be able to use it with HHKB G60?
Offline Hotsauce
« Reply #10 on: Sun, 30 June 2019, 17:56:05 »
Also curious what kind of battery this will support and if you have tested it in any cases.
Offline scottwei
« Reply #11 on: Sun, 30 June 2019, 19:56:21 »
3.7v Li-Po Battery with PH plug
    • Shop
« Reply #12 on: Sun, 30 June 2019, 20:27:36 »
Edited. Sorry.
One layout only for HS version. :)
Offline joe405
« Reply #13 on: Sun, 30 June 2019, 23:30:26 »
Any particular reason why 2u backspace for the hotswap layout? Hhkb/wkl is usually split backspace.
Offline spyruf
« Reply #14 on: Mon, 01 July 2019, 00:01:23 »
I wonder if this will work with the grid 600.
    • Shop
« Reply #15 on: Mon, 01 July 2019, 00:17:36 »
Yes it does as grid600 supports most 60% customs PCBs.
Only be careful to the plate you are going to use. You might want to choose an acrylic one or carbon fiber one to avoid signal blocking.
Offline IvarLJ
« Reply #16 on: Mon, 01 July 2019, 05:10:05 »
Just to clarify - and apologies if I am the only one confused by this:
[-] Does the hot swap version have or doesn't it have winkeys?
The description clearly says WKL, but then the layout diagram for the hot swap version shows the winkeys as available.
Sent from my iPad using Tapatalk
    • Shop
« Reply #17 on: Mon, 01 July 2019, 08:58:35 »
I've changed the name. Sorry for misunderstanding. :)
Might be because 2u backspace is more general. Scot didn't really focus on split it to two keys.
Offline Lyle88
« Reply #18 on: Mon, 01 July 2019, 16:01:34 »
I am of the understanding that it supports layouts with bottom row 1.5, 1, 1.5, 7, 1.5, 1, 1,5 (WKL), but as long as your layout uses those key sizes it should be fine.
For example Scott has told me that it will be fine with my hhkb g60
Offline oldcat
  • 65% is Life
« Reply #19 on: Mon, 01 July 2019, 18:07:48 »
very nice!
Offline lac29
« Reply #20 on: Mon, 08 July 2019, 16:29:10 »
More Bluetooth customs please! I hope this is successful so that a 65% and other layouts with Bluetooth can be developed.
I'll say it as many times as possible. I think anything under 60% (and possibly including 60%) should be wireless.
Offline Vadurr
  • Valar Morghulis
« Reply #21 on: Mon, 08 July 2019, 16:38:46 »
Would be interested in this if the hotswap pcb had split backspace!
Offline Lyle88
« Reply #22 on: Mon, 08 July 2019, 18:01:27 »
If you are comfortable removing and re-attaching the backspace HS socket the holes for split BS are there I believe - you would need an extra HS socket though
Offline KingOfMemes
« Reply #23 on: Mon, 08 July 2019, 18:52:11 »
Is this something that is easily fit into a typical 60% case (especially other customs)? I've never worked with something like this before, and I guess I'm not fully grasping my options. Would I be able to charge it via the PCB being plugged in?
    • Shop
« Reply #24 on: Tue, 09 July 2019, 04:56:26 »
No it's not workable. There is only one layout for HS version, which means only one position for backspace.
You will need to measure the space you have in your case.
I suggest you get a battery with a thickness lower than 5mm.
Offline lightingghost
« Reply #25 on: Tue, 09 July 2019, 12:53:17 »
Which BT chip/solution are you using? How long it will last? Does it support device switching like filco TKL ?
Offline _BlueNote_
« Reply #26 on: Wed, 10 July 2019, 19:18:08 »
Anyone have a link to the battery for this?
Offline bball2
« Reply #27 on: Wed, 10 July 2019, 22:18:24 »
Group buy over? Says sold out on the site
Offline lac29
« Reply #28 on: Thu, 11 July 2019, 00:32:43 »
Damnit I didn't notice this was active. GB seems like it's over.
Offline rooski15
« Reply #29 on: Thu, 25 July 2019, 11:16:44 »
Any chance at extras on this one? Im sorry to have missed it.
Offline Justin_aka_OsP_SSJ4
  • Chellow... it's me...
    • My Twitch
« Reply #30 on: Fri, 02 August 2019, 22:56:27 »
Images show a split BS hotswap PCB also...
https://play-keyboard.store/products/copy-of-play-keyboard60-pcb?variant=29155775545462
DC60 w/ DZ60 PCB & Steel plate w/ 3mm neoprene foam - 68g Chellows Lubed w/ 3204 - Find me on twitch/twitter Osprey_SSJ4
Offline Lyle88
« Reply #31 on: Fri, 02 August 2019, 23:50:04 »
This is totally unconfirmed, but I get the feeling that for the HS version in this GB it is fixed layout to keep things simple but if you have joined the G60 GB and added this on via email you can select the layout (provided it fits within 7u bottom row layout)
Edit: spelling
Offline slxdegrees
  • Nerds With Keebs
    • Donate to Room To Read!
« Reply #32 on: Sat, 03 August 2019, 03:09:26 »
Hey, are there any updates for the pcb, @PlayKeyboardTW? Or should we be expecting delays? Thank you!
Sent from my LYA-L29 using Tapatalk
    • Shop
« Reply #33 on: Sun, 04 August 2019, 02:24:23 »
Hi guys, production is done.
Now Scott is flashing firmware to each PCB, then we will be ready to pack them and send them to our place.
Offline Little4Real
« Reply #34 on: Sun, 04 August 2019, 02:32:01 »
Will there be any extra PCBs, would like to get one or two.
« Last Edit: Sun, 04 August 2019, 02:45:38 by Little4Real »
Offline lac29
« Reply #35 on: Sun, 04 August 2019, 23:08:34 »
I would possibly pick up an extra as well if they become available.
Offline slxdegrees
  • Nerds With Keebs
« Reply #36 on: Wed, 14 August 2019, 03:20:46 »
How do I flash using QMK Toolbox? There are some features (e.g. LCtrl_T(Caps_Lock)) that are not present in VIA yet.
« Last Edit: Fri, 16 August 2019, 03:38:35 by slxdegrees »
Offline Lyle88
« Reply #37 on: Fri, 16 August 2019, 03:09:56 »
Can someone tell me what case is shown in the OP picture?
Offline caonv
« Reply #38 on: Sat, 17 August 2019, 03:01:09 »
it seems that the GB is over now  :(
I'm looking for a wireless 40 or 60% keyboard kit with HHKB layout.  :p
Unfortunately, such a keyboard does not exist, then I'm considering a separated bluetooth PCB and an universal 60/40 with a battery slot.  ;D
I found this GB, but it's over.
Is there any chance this GB will be opened again in the future?
One more question, is this PCB compatible with popular 60 case such as XD60, DZ60 or GH60?
Could you guys give some recommendations for my above interests? Thank you!  :-[
    • Shop
« Reply #39 on: Wed, 21 August 2019, 23:28:10 »
Took a couple more days in custom clearance than we expected, but they are finally here. :)
We will start to test them before shipping them out. Thanks for all the patience. :thumb:
224872-0
    • Shop
« Reply #40 on: Wed, 21 August 2019, 23:29:33 »
It's compatible with 60% cases with battery slots.
We will have some extra in stock after GB orders are sent.
Please follow our Instagram for latest updates. :thumb:
Offline caonv
« Reply #41 on: Sat, 24 August 2019, 07:50:40 »
Great,
Looking for your update  :p
Hope the PCB works perfectly  :cool:
Offline caonv
« Reply #42 on: Sat, 24 August 2019, 08:23:33 »
I have same question as the above guy  :'(
    • Shop
« Reply #43 on: Mon, 26 August 2019, 03:53:35 »
We'll come back to answer above questions when shipping is all done. ;)
Offline menuhin
« Reply #44 on: Mon, 26 August 2019, 04:10:33 »
Does the hotswap actually feature a split backspace - a full Tsangan layout?
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
« Reply #45 on: Mon, 26 August 2019, 18:44:08 »
Excited to receive this, will finally be able to finish the build that its been waiting for.
Offline ogroves
« Reply #46 on: Wed, 28 August 2019, 17:49:15 »
I missed out on the GB but I'm really interested in one of these, if there are any extras available please let me know.
Offline KevlarBear
« Reply #47 on: Tue, 03 September 2019, 18:06:56 »
Just got mine delivered today and was wondering if there is any instructions or documentation available? Specifically, how to make it enter bluetooth pairing mode and re-pairing for another system. Also, which version of VIA Configurator will this be supported on? The latest version available (0.3.6) does not recognize this.
« Last Edit: Tue, 03 September 2019, 18:16:21 by KevlarBear »
    • Shop
« Reply #48 on: Fri, 06 September 2019, 05:24:36 »
Hi. A quick update here.
We are glad to see most of you guys got PCBs.
Since this is a new product, the maker, Scott, is now trying to make an instruction for everyone to have an idea about how to play with this board.
BIOI G60BLE PCB is now only able to be editing on VIA Configurator: https://github.com/olivia/via-config/releases
And for pairing, all you need to do is turn on the switch besides spacebar key. Search the board on your device, then pair them.
We were about to put some extra PCBs for stock selling, but found that there are just a few of them.
So we are now discussing with Scott to hold another pre-sale of this product.
If there's any update, we will post it in here, reddit, and our Instagram.
Thanks everyone. :thumb:
    • Shop
« Reply #49 on: Fri, 06 September 2019, 05:26:55 »
Normal backspace, but there are split backspace positions reserved.
Please keep an eye on our Instagram for any update. ;)
Answered in last reply. :)
